Fast Food Specials Dissapeared
by 007 - 04/08/20 04:17 PM
Amber Alerts at 5am
by rekit - 04/08/20 03:16 PM
MC FL-910S cut open
by kstanf150 - 04/08/20 03:12 PM
Cartridge Weight Question
by Gebo - 04/08/20 02:54 PM
Auto insurance rate cut
by Wolf359 - 04/08/20 02:18 PM
Do you "correct" your service technician or not?
by SevenBizzos - 04/08/20 02:07 PM
How to keep glasses from fogging up?
by Chris142 - 04/08/20 01:58 PM
1.6 EB ,RL 5w20,18175 miles OCI,TAN>TBN
by ovidiu - 04/08/20 01:02 PM
cut ADBV in Mobil1 oil filter
by RavenTai - 04/08/20 12:55 PM
Oil shopping USA vs France
by M119 - 04/08/20 11:50 AM
Blackstone labs... open??
by researcher - 04/08/20 11:41 AM
Hyundai 2.4 Engine Issues
by Hallj49803 - 04/08/20 11:36 AM
Do old style centrifugal filters do anything?
by atikovi - 04/08/20 11:34 AM
NAPA oil deals
by Oildudeny - 04/08/20 11:17 AM
Oil weight spec thinning over time?
by MontePrix28 - 04/08/20 10:12 AM
High Performance Lubricants PDS
by High Performance Lubricants - 04/08/20 10:11 AM
13 Hyundai Sonata 24 vs 12 Jetta 2.0 TDI
by Hallj49803 - 04/08/20 10:09 AM
Mustang 4.6L spark plug change
by kstanf150 - 04/08/20 10:03 AM
Cutting Cable-Roku?
by PontiacHO - 04/08/20 09:59 AM
LMVLS1, Jotorobi, jhoffy22, EcoBoosted, mmich187
71126 Registered Users
100 registered members (762fermeandyou, AC1DD, 2015_PSD, 2009Edge, 007, 53' Stude, 9 invisible), 2,560 guests, and 20 spiders.
Topics303,777
Posts5,241,752
Members71,126
Oil Advice For 1990s Era Yamaha ATVs #5354863 02/19/20 08:42 PM
DockHoliday Offline OP
I have taken ownership a fleet of circa 1990 Yamaha quad bikes with air cooled 350cc single lung motors. Bikes had been sitting in a garage unused for 15+ years. Usage prior is unknown, as is the maintenance history. I had a local shop clean the carbs, adjust valves, replace all fluids, lube all things that take lube, replace all wear items, etc. All are running well now. Shop used no-name 10W40 Dino oil.
Machines will be used in all seasons in WI, so they will see a variety of temps (winters here can get down to -25F).
My question is should I consider switching to a synthetic oil? If so, what vis and flavor? So many people say no to switching to synthetic on older engines, but I thinking this is an old wives tale.
Thanks in advance.
[Linked Image from boatingabc.com]
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5354903 02/19/20 09:39 PM
1
14Accent Offline
1
Even being air cooled, wouldn't 10w-40 be a bit thick at -25? I'm thinking a 0w-40 below, say, 10 degrees and a 5w-40 up to about 60 degrees. After that, a 10w-40 should be fine. Synthetic shouldn't hurt it at all, if anything it will give you that little bit of extra protection.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5354916 02/19/20 09:53 PM
V
Vern_in_IL Offline
V
any JASCO rated oil would work, I prefer synthetic for anti shearing.
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: Vern_in_IL] #5354927 02/19/20 10:02 PM
K
kschachn Offline
K
Synthetic would be more shear resistant if it uses less VII, but neither synthetic nor conventional base oil will shear.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5354952 02/19/20 10:37 PM
Any concerns with synthetic causing oil leaks after decades of Dino oil? Or is that an old wives tale?
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5355020 02/20/20 01:02 AM
BusyLittleShop Offline
Understanding synthetics means more refining to remove less desirable
elements from crude until what’s left is mostly higher-performing
molecular structures. Waxy stuff had to go because it made oil congeal
at winter temperatures. Aromatics had to go because they lost
viscosity too rapidly when hot. Unsaturates had to go because they
were vulnerable to heat-driven gumming and sludging. And so on.
What you are paying extra for are uniform sized molecules that don't
exists naturally in abundance...
[Linked Image]
Yamaha offers a 0w40 synthetic...
[Linked Image from maxsled.com]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5355127 02/20/20 07:08 AM
K
krismoriah72 Offline
K
Nah not really. What you have to watch for on used ATVs are consumption rather than leaks. Dirt gets past the air filters and 'dusts' the engines causing ring wear which leads to consumption.
So with that being said I would run the universal favorite Rotella 5w40 and keep an eye on the oil level every few hours of usage.. to weed out the oil burners.
“Diesel oil has the widest performance range with 5W40,” says Mark Betner of Citgo. “Its starting temperature range is down to minus 22 F (compared with 15-plus with 15W40) up to 122 degrees F (same as 15W40). That tells you a couple things: There’s a 37-degree cold cranking advantage (from minus 22 to plus 15) to a 5W40 and the same benefit on the high end.”
https://www.overdriveonline.com/through-thick-and-thin/
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5355463 02/20/20 01:08 PM
sunruh Offline
where is the P66 TropArtic ?
speaking of old school
motorcycle oil myth buster
Re: Oil Advice For 1990s Era Yamaha ATVs [Re: DockHoliday] #5367321 03/04/20 04:50 PM
DGXR Offline
Yes it's an old wives' tale. The idea was, conventional oil is not as good at keeping engines clean as is synthetic oil. So if you have an engine that's been running conventional for a long time, then start using a synthetic, it might clean out some bits of buildup/sludge that were keeping a leak at bay. In other words, synthetic could potentially reveal a problem that was already present. This has not proven to be the case.
The truth is that synthetic as significantly better flow than conventional and will find its way through tiny cracks and other spaces where the conventional would not wander, causing seepage. But not leaks.
I agree with the 0w40 recommendation, considering your anticipated ambient temperatures.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
