Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
113 registered members (55hambone, ANokesPDX, 10ecfarmer, 1978elcamino, 928, 2015_PSD, 16 invisible), 2,113 guests, and 19 spiders.
Topics303,501
Posts5,235,304
Members71,063
Page 4 of 4 1 2 3 4
Re: EBC Brakes [Re: littlehulkster] #5354011 02/18/20 10:10 PM
SouthDakotaDad Offline
Originally Posted by littlehulkster
FWIW I wouldn't necessarily be afraid of Chinese made rotors. This is a country with a space program, after all, a brake rotor is nothing compared to that. As long as EBC requires tight QC from the manufacturer they'll be fine.
The Chinese are capable of manufacturing just about anything you want, you just have to make sure you specify you want a quality product instead of junk.
I have purchased Chinese rotors on numerous occasions, for different cars in the past 10 years. Haven't had an issue with any of them. No pulsating, warping, etc.
I always go with a middle or high quality brake pad though for sure.
2015 Corolla LE, 1.8, QSUD 0w-20, Fram Ultra, 55K miles
2012 Scion XB 2.4, QSUD 0w-20, Fram Ultra, 21K miles
2017 Mitsubishi Outlander Sport--Can't wait to get rid of it
Re: EBC Brakes [Re: littlehulkster] #5354161 02/19/20 06:41 AM
H
hatt Offline OP
H
I'm not afraid of China stuff. I'm trying to not give them any money I don't have to. Obviously they can make good stuff.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: EBC Brakes [Re: hatt] #5354163 02/19/20 06:49 AM
O
Olas Offline
O
its not the country, its the manufacturer. every country has firms that make junk and firms that make excellence (GM Vs Lockheed is a good example)
Cable ties should hold it
Re: EBC Brakes [Re: Olas] #5354478 02/19/20 01:23 PM
CKN Offline
The beloved Michelin Company also has a tire plant in China-and ships tires all over Europe from it.
Re: EBC Brakes [Re: cronk] #5354593 02/19/20 03:37 PM
P
Pew Offline
P
Originally Posted by cronk
Those pads appear to have been pretty severely overheated.
I have taken pads off that looked like that, and the vehicles they came off had sticking calipers or hung up slides, of the caliper bracket had rusted to the pad, not allowing it to retract.
I ran a set of EBC Ultimax pads on my old Saturn and really liked them. Nice stopping power, no noise, low dust, and they held up well for the 30k or so I put on them before I sold the car.
Other than the backing plate and giant crack in the pad, it actually doesn't looks abnormal to me. It just looks like bad luck or bad QA/QC. Friction material shouldn't come off the backing plate like that, but EBC did have QA issues with their pads before doing exactly this. When I think of overheating I'm thinking of below (credit to corvetteforum.) Although it would be easier to see if the pad overheated with a picture of the rotor too.
[Linked Image]
Re: EBC Brakes [Re: hatt] #5354670 02/19/20 04:48 PM
H
hatt Offline OP
H
The pads and rotors came today. I can't see anything related to country where the front rotors where made. The machining looks excellent however. I didn't open the rear rotors yet.
Re: EBC Brakes [Re: CKN] #5355095 02/20/20 06:23 AM
O
Olas Offline
O
Yes they do, which reinforces the point that the country doesn't matter, its the factory. Michelin make good tyres no matter which bit of soil their factory sits on.
Re: EBC Brakes [Re: FlyNavyP3] #5356134 02/21/20 02:12 AM
B
BBDartCA Offline
B
Originally Posted by FlyNavyP3
Originally Posted by hatt
I just ordered EBC rotors and pads for the 2010 Camry. Did I waste money? It looks like the choices were China rotors or EBC for not too much more.
Where are the EBC rotors made? I've always wondered if their entry level stuff was also cast in China.
Here is an EBC rotor discussion covering the COO question. To me they are very vague on COO and it appears are importing significant rotor volumes from China.
https://www.bobistheoilguy.com/foru...328665/re-ebc-rotor-pictures#Post5328665
Former lube industry insider...now vehicle OEM engineering insider.
Re: EBC Brakes [Re: hatt] #5356150 02/21/20 03:38 AM
O
Olas Offline
O
EBC products in the EU have a bad reputation - Friction material delaminates from backing pads and discs crack.
Stick to Brembo/Zimmerman/Pagid wherever possible.
Re: EBC Brakes [Re: Olas] #5357794 02/23/20 05:27 AM
F
Falcon_LS Offline
F
That was a problem which was later addressed, particularly on the Ultimax OE replacement series. Personally I've never had a problem, and I'm running their products in all my vehicles with no issue. None of the vehicles are driven gingerly.
All the discs I bought had approvals from ABE and TÜV, and all the pads had ECE R90 approvals.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: EBC Brakes [Re: Olas] #5358536 02/24/20 01:41 AM
E
edyvw Offline
E
I never had issues with them, and I am also running it on Land Cruiser Prado in Europe with Ultimax rotors and Green stuff. Unlike Toyota OE, these do not vibrate after 10,000km.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: EBC Brakes [Re: hatt] #5358560 02/24/20 03:31 AM
O
Olas Offline
O
Itspossibletht they use a better supplier, or a better production technique, but I still maintiain that I will never use them again. Ive been changing brakes since before I had a license, and I've NEVER seen delaminated pads from any manufcaturer, ever, except the EBC pads I took out that 'make a noise and feel funny'.
You only need food poisoning once to never go back to that restaraunt,
You only need to be in one airplane crash to always get the train or boat for the rest of your life,
and you only need to see one delaminated brake pad to never buy from that company again.
Re: EBC Brakes [Re: Olas] #5359422 02/25/20 01:39 AM
E
edyvw Offline
E
I had Ferodo split in half.
Re: EBC Brakes [Re: hatt] #5361176 02/27/20 01:06 AM
F
Falcon_LS Offline
F
It's an extremely competitive marketplace, where manufacturers are under extreme pressure for market share. This is especially true for a company like EBC, given their size, with so many huge players in the brake segment. While I don't deny every manufacturer is going to have their own share of problems, not doing anything about it will do nothing but land them in all sorts of trouble.
Brake pads, like all wear items, have a set lifespan depending on use. Wear can be further accelerated when problems like partially seized calipers or corroded caliper pins are present, not necessarily related to the pads or rotors themselves. A simple search will reveal many folks have experienced issues with disintegrating pads, with brands ranging from Volvo OE to Textar pads on a Porsche.
I've had Bendix CT-3 pads crack and disintegrate on me 2 years after installation, and when I contacted Bendix about it, I was sent a replacement set - no questions asked - which I never had any problems with over the course of its lifespan (4 years/34,000 miles). Perhaps they had a bad batch, but they absolutely did the right thing and that's exactly what instills confidence, when a manufacturer backs their product.
While it's understandable some folks will be left with a bad taste in their mouths, that didn't put me off Bendix products, considering various OE brake parts on my vehicles, like the master cylinders, are supplied by them. Quite the opposite in fact, especially given the problem occured 2 years and roughly 15,000 miles after installation with 75% life left in them, when they quite well could have told me to go pound sand.
EBC has an article on their website dedicated to cracking rotors, as well as an article on choosing the right pads for your application. While OEM pads/rotors tends to cover the needs of most drivers, as Edyvw pointed out, they don't cover everyone. From experience, I'm not a fan of most OE brake setups on Japanese SUVs; primarily Toyota, Nissan and Mitsubishi with pads supplied by Sumitomo (FF edge codes in most cases). In my case, the EBC Yellow Stuff pads have been the answer, covering a niche where other manufacturers haven't really offered an alternative to OE spec. Good luck finding Brembo or Otto Zimmermann for those. At the end of the day, it's your money, your time, your vehicle.
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
Motorcraft 5W-50:
Re: EBC Brakes [Re: hatt] #5361325 02/27/20 09:26 AM
doitmyself Offline
Brembo also has a few skeletons in their closet. I agree with you Falcon FS. Is you ban every manufacturer that you (or others) had one bad experience with, you will quickly run out of alternatives.
Page 4 of 4 1 2 3 4
