0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
5 and 10 30 valvoline conv 1.49 a qt at TS
by Chesterr - 04/04/20 02:34 AM
Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Larrylehman, Dan1424, Tony1234, Peacock, Agauth12
71089 Registered Users
55 registered members (53' Stude, 65convertible, 4WD, AndyB, Astro14, 1foxracing, 6 invisible), 1,572 guests, and 17 spiders.
Topics303,562
Posts5,237,450
Members71,089
Ultrasonic carb cleaning problems #5353956 02/18/20 09:05 PM
A
atikovi Online Content OP
OP Online Content
A
This has happened on the last two carbs I've done. The pot metal has gotten a black coating of something, all over it. I can rub it off with a finger, but I assume it's also on the internal passages. This is a Nikki generator carburetor and I'm using Meguiars Super Degreaser for the fluid.
[Linked Image from fototime.com]
For reference, a carb I did a few years ago came out great.
What's going on and how to prevent it?
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5353977 02/18/20 09:30 PM
T
Trav Offline
T
Try simple green 25% in water. 10 min cycles and do not leave it in overnight.
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354003 02/18/20 10:03 PM
P10crew Offline
I use Krud cutter in mine.
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354006 02/18/20 10:04 PM
A
OP Online Content
A
Ok, will get some. Trying a cycle with plain water first right now.
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354013 02/18/20 10:12 PM
T
Trav Offline
T
A couple of drops of dish soap will help, don't go overboard and make a bubble bath.
Re: Ultrasonic carb cleaning problems [Re: Trav] #5354018 02/18/20 10:16 PM
B
bunnspecial Offline
B
Further to that, I was taught to always use a small amount of some sort of surfactant(soap is easiest as long as it won't cause problems) to maximize the efficiency of a US.
Most of the time when I use US, I'm using a beaker or some other secondary container(often with solvent in it) but still follow this rule for the water bath surrounding my secondary container. A drop or two of Dawn does the trick most of the time as well as anything else.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354021 02/18/20 10:21 PM
P10crew Offline
Go with Trav’s recommendations because I have not done any carb parts. Mostly rocker arms and bolts.
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354022 02/18/20 10:23 PM
P10crew Offline
double post
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354126 02/19/20 03:12 AM
Spktyr Offline
I would suggest using the new Simple Green product that's aluminum safe - regular Simple Green is corrosive to aluminum if left on too long (which is why the FAA banned it as an aircraft fuselage wash in the US). If you use regular Simple Green on the unprotected aluminum carb body, SG has this to say about it: "Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation."
https://simplegreen.com/faqs/
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354135 02/19/20 04:04 AM
Spktyr Offline
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354157 02/19/20 06:37 AM
O
Olas Online Content
Online Content
O
chemdip
Cable ties should hold it
Re: Ultrasonic carb cleaning problems [Re: Spktyr] #5354176 02/19/20 07:10 AM
T
Trav Offline
T
You can use the original on aluminum for a short cycle then rinse with water thoroughly, you mix it 25% in water further reducing the possibility of corrosion.
If you change the fluid in the tank often like you should then the aviation stuff is more than double the price and it is not as effective on varnish in the brass parts inside.
I do a lot of large body aluminum injectors found in marine application that have corrosion inside from sea water, after using the regular simple green as described I don't see any repeat corrosion if the part is not subjected to sea water again.
Re: Ultrasonic carb cleaning problems [Re: Olas] #5354289 02/19/20 10:02 AM
T
Trav Offline
T
Originally Posted by Olas
chemdip
+1 for small carbs like that its probably the best option, leave it overnight.
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354294 02/19/20 10:04 AM
W
WyrTwister Offline
W
Berryman B12 is a pretty good carb cleaner w/o the US .
Wyr
God bless
Re: Ultrasonic carb cleaning problems [Re: atikovi] #5354315 02/19/20 10:36 AM
A
ad244 Offline
A
Pine Sol
