Originally Posted by motech
I've got a 2017 VW Tiguan that's almost out of warranty: almost exclusively short-tripped so I do the oil changes at 5k. Engine requires 502 spec oil. Would switching to a 504 be 'better', or not worth it with my short OCI?
You can choose from two types of service regimes, depending on your driving methods.
Fixed Service (Time and Distance)
We recommend this service if you are likely to drive less than 10,0001 miles in a year, and if you tend to drive in the following way:
Mainly city centre driving, short journeys with frequent cold starts
High engine loading activities, e.g. frequent hill climbs, driving with your vehicle fully loaded and towing
Uneconomical driving using high rpms with heavy acceleration and heavy braking.
Flexible Service Regime (LongLife Service)
We recommend this service if you are likely to drive more than 25 miles a day, and if you tend to drive in the following way:
Regular long distance driving
Driving at a constant speed with minimum vehicle and engine loading, and minimal towing
Economical driving
Fixed service is the one for you. VW502.00 is the best fixed service oil for your car.
