Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
27 registered members (Black_Thunder, bmod305, AAIRCraig, 97prizm, 4WD, bachman, 2 invisible), 584 guests, and 20 spiders.
Topics303,254
Posts5,232,677
Members71,032
Wider rear tires? #5353747 02/18/20 04:07 PM
drop Offline OP
Hello there, I own a Toyota Camry and it needs new tires. I want to buy wider tires for it, from 215/55/17 to 233/50/17.
Is it of any logic using wider tires rear and slim tires in front, in front wheel drive vehicles?
Re: Wider rear tires? [Re: drop] #5353755 02/18/20 04:13 PM
A
andreigbs Offline
A
Logic?
No.
Stick with OEM size, that way you can rotate the tires and get more of your money out of them.
MB GLK250 Bluetec // 120,xxx miles // 32 MPG // M1 ESP 5w30
BMW X3 x28d // 55,xxx miles // 35 MPG // PP Euro L 5w30
Re: Wider rear tires? [Re: drop] #5353758 02/18/20 04:17 PM
AZjeff Offline
What is your logic for considering wider tires on the back of front wheel drive?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Wider rear tires? [Re: drop] #5353766 02/18/20 04:24 PM
A
atikovi Offline
A
Unless you do frequent high speed cornering, you should be fine.
Re: Wider rear tires? [Re: atikovi] #5353769 02/18/20 04:27 PM
W
Wolf359 Offline
W
Yeah, in high speed cornering in bad weather, the rears would probably lose traction and you'll just spin out. Otherwise you'd have a hard time rotating the tires. There's actually no good logical reason to do what's proposed. You'd have to get a degree in engineering to really understand why.
Re: Wider rear tires? [Re: drop] #5353810 02/18/20 05:26 PM
J
JOD Offline
J
No, if anything you'd want wider tires in the front. There are a few FWD and FWD-based AWD performance cars that are set up this way. You definitely don't want wider tires on the back. You'll lose traction and increase understeer even more.
Re: Wider rear tires? [Re: drop] #5353814 02/18/20 05:35 PM
K
Kira Offline
K
Go stock size on all 4 wheels. Be reminded, it's a Camry. You'll look like a buffoon driving down the road.
Messing around with odd tire sizes is a ridiculous, unoriginal idea steeped in childish copycatism and ignorant consumerism.
It'll cost you more and disadvantage you in the event any insurance claim is involved.
There's nothing to be gained by what you're considering.
Re: Wider rear tires? [Re: drop] #5353834 02/18/20 06:06 PM
X
XCIDMigs Offline
X
PLEASE SIR can you tell me where you have found those 233/50/17 tires and how much they want to ship them to the USA?
coffee
Re: Wider rear tires? [Re: Kira] #5353880 02/18/20 07:08 PM
A
atikovi Offline
A
You guys know the OP is in Mexico? As long as the belts aren't coming through the rubber, any tire that fits the rim is fine.
Re: Wider rear tires? [Re: drop] #5354049 02/18/20 11:10 PM
P
Pew Offline
P
If you're just daily commuting and driving smart, I don't see a problem, especially if you're trying to save money. If you're thinking of a performance aspect, then no you don't want it like that.
Re: Wider rear tires? [Re: drop] #5354079 02/19/20 12:22 AM
E
edyvw Offline
E
So you want to add more to already excessive understeer in Camry?
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Wider rear tires? [Re: drop] #5354091 02/19/20 12:50 AM
U
userfriendly Offline
U
Wider tires need wider wheels. 235/45/17s on 17X8" wheels or 235/40/18s would be a nice upgrade.
Re: Wider rear tires? [Re: drop] #5354158 02/19/20 06:38 AM
O
Olas Offline
O
keep the size constant, use a better compound for more grip and use geometrey to compensate understeer/oversteer
Cable ties should hold it
Re: Wider rear tires? [Re: AZjeff] #5354284 02/19/20 09:59 AM
JohnnyJohnson Offline
THIS thumbsup
2004 Corolla 139577
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Wider rear tires? [Re: AZjeff] #5354380 02/19/20 11:19 AM
Quattro Pete Offline
It's the coolness logic. smile
2002 530i   2015 Q5 3.0T   2018 Charger SRT
