Originally Posted by dave1251
Originally Posted by edyvw
Originally Posted by charmer37
Originally Posted by slacktide_bitog
You can use Maxlife
Maxlife works in ZF 6 speed transmissions?
Yes it does. But take into consideration that ZF6 is true synthetic gear oil. It is expensive, but IMO it is worth.
Unless you are doing flush (which you should not) use ZF6 so you do not mix oils. It is transmission oil and you are not changing it often.
ZF6 is not a synthetic. Where are you finding this Malarkey?
ZF6 is sold in Germany as full synthetic gear oil.
I could be wrong about it (as far as I know, their law about composition of base oil applies to gear lube too). However, why mixing oils? Yes Maxlife is good, and yes it si way cheaper, but it is not like one is changing gear lube every 5k.
