5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
101 registered members (2010Civic, 2003f7, 4WD, 55hambone, ABomb369, 69GTX, 6 invisible), 1,598 guests, and 22 spiders.
Topics303,461
Posts5,235,582
Members71,074
Page 1 of 3 1 2 3
Toyota Sienna #5353520 02/18/20 11:05 AM
cb_13 Offline OP
Looking into a mini van as my family is just outgrowing the wife's Ford Edge. The Edge has been a spectacular vehicle for us but two rear facing car seats and a booster are not going to fit comfortably in the back. Had considered a Chrysler Pacifica but it seems like everyone I've talked to that has had one has had issues with it. I would be looking in the
2016 and up age range. So is there any common issue with the Sienna I should be looking for? Is it a good vehicle overrall? I'm not too familiar with Toyota as I've always owned and worked on Fords and GM products.
Our second choice would be to move up to a Ford Expediton as I'm familiar with what to look for on those. The fuel mileage difference is pretty significant between the two and we both feel that a mini van just has the advantage over a truck based suv when it comes to people hauling.
Re: Toyota Sienna [Re: cb_13] #5353528 02/18/20 11:11 AM
J
jayjr1105 Offline
J
Sienna, Odyssey, Pilot, Highlander, all good vehicles. Sienna might have a slight leg up on the Odyssey but we love our Odyssey.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Toyota Sienna [Re: cb_13] #5353563 02/18/20 11:58 AM
J
JMJNet Online Content
Online Content
J
I have a 2017. There was a problem with the transmission but they replaced it under warranty.
Toyota ended up extending the transmission warranty for all Sienna.
They sent a letter to be kept if transmission ever fail.
Mine is around 51K now, the transmission was replaced at around 19K.
No problem so far.
It is not perfect van but so far the engine has been very reliable, there is nothing to replace on my part except oil.
  • 2017 Toyota Sienna
Re: Toyota Sienna [Re: cb_13] #5353567 02/18/20 12:01 PM
diyjake Offline
2015-2016 Sienna is a great choice. In 2017 or 2018 they went with a 8 speed transmission and there was been some issues with that. 2015-2016 is a solid year.
Re: Toyota Sienna [Re: cb_13] #5353592 02/18/20 12:38 PM
M
Mangos86 Offline
M
I have a 13 Sienna that just turned over 100k. Other than recall work, it has been flawless. It chews through tires. We love it.
2015 BMW 535i X-Drive Castrol Edge 0W-40
2013 Toyota Sienna SuperTech 0W-20
Re: Toyota Sienna [Re: cb_13] #5353596 02/18/20 12:45 PM
M
mbacfp Offline
M
Our 2012 Toyota Sienna just had the alternator go out. New accessory belt and alternator. 95,000 miles. My mechanic said he has been seeing this around 100k on these. Otherwise been flawless.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Toyota Sienna [Re: cb_13] #5353598 02/18/20 12:45 PM
N
nthach Offline
N
The Sienna seems more trouble free compared to the Odyssey, no VCM to worry about - the 8-speed can be finicky.
The usual Camry/Avalon/ES and Highlander/RX caveats apply to the Sienna but the 2GR-FE/FSE in the newer ones has proven to be a relatively solid motor.
Re: Toyota Sienna [Re: cb_13] #5353607 02/18/20 12:56 PM
B
bepperb Offline
B
We have a 2011 with the 6speed transmission that's been great up to 135,000. This was the first year of the body style they still make now. It is much larger than my Pilot on the inside, and no timing belt, but not nearly as nice in the interior. Would buy again to haul kids.
One other note, the third row folds flat but the middle row you have to remove. This is easy for me, I'm not sure my wife has the upper body strength.
2016 Honda Pilot
2011 Toyota Sienna 3.5
Recently Gone:
2004 Highlander 2.4
Re: Toyota Sienna [Re: cb_13] #5353608 02/18/20 12:57 PM
T
Trav Offline
T
Sienna by a long shot for all the reasons posted.
Re: Toyota Sienna [Re: bepperb] #5353611 02/18/20 01:00 PM
N
nthach Offline
N
The ones on the 3rd gen 2011-on models are almost Lexus-like and heavy on the Limited models. I've always called the Sienna a Lexus in soccer mom drag, it does drive, sound and mostly felt like a Lexus ES or RX.
Re: Toyota Sienna [Re: mbacfp] #5353612 02/18/20 01:00 PM
E
exranger06 Offline
E
I had to replace the alternator on mine at around 135k.
I bought mine last year at 132k miles and aside from the alternator, it's been perfect. I have 140k now. I chose a Sienna because I wanted AWD, and the Sienna is the only minivan built within the last 15 years with AWD (although Chrysler will be offering AWD on the Pacifica next year). It's excellent in the snow.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Toyota Sienna [Re: cb_13] #5353615 02/18/20 01:00 PM
dtownfb Offline
2013 Sienna XLE with 107k miles only issue was the sliding door which was repaired as part of a recall. Brakes have lasted over 60k miles. Tires won't last their full warranty period but that is a minivan issue not a Sienna.
Coming from my 2004 Quest, this van has been a welcome pleasure.
2006 Toyota Camry
2013 Toyota Sienna
2015 Toyota Camry
Re: Toyota Sienna [Re: exranger06] #5353627 02/18/20 01:15 PM
M
mbacfp Offline
M
We have the limited no AWD. Ours doesn't burn any oil...so I'm hoping to get to 140k and beyond. Recently did a drain and fill of transmission fluid. OP, we drive this car everywhere and our kids watch TV, etc. Not babied and has been great up to 95k miles (alternator actually shorted out).
Went through the pain of airbag recall and sliding door recalls...but it is a great vehicle.
Re: Toyota Sienna [Re: cb_13] #5353634 02/18/20 01:25 PM
N
nthach Offline
N
The Sienna sliding door system is fairly robust and doesn't seem too terrible to service unlike the Odyssey. Aisin-sourced, the motor that works the main cable is in the door. Unlike the Odyssey, you don't need to discharge the HVAC or drain coolant since the working bits aren't in the rear quarter panels.
The actuator motor tends to be the thing that goes out the most, if you're comfortable taking it part the small 12V motor is replaceable.
Re: Toyota Sienna [Re: mbacfp] #5353644 02/18/20 01:36 PM
diyjake Offline
[/quote]
Went through the pain of airbag recall and sliding door recalls...but it is a great vehicle.[/quote]
Did you do the drain and fill yourself? I know it's not so easy on newer Toyota's because they don't come with a dipstick anymore.
Page 1 of 3 1 2 3
