Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
68 registered members (BobS, b1amgm47, amh, AandPDan, BlakeB, 8 invisible), 2,331 guests, and 43 spiders.
Topics306,039
Posts5,285,412
Members71,572
Larger fuel filter on Riding mower? #5353518 02/18/20 11:03 AM
dedonderosa Offline OP
i currently have an older scotts (john deere) S1742 with a single cylinder 17hp INTEK engine and i wanted to replace the fuel filter and the manual says to use
AM38708 which is the small disc type fuel filters with no paper media in them.
i wanted to know if i could run a larger clear inline filter like this one with no issues like this one https://www.amazon.com/iFJF-Diameter-Motorcycle-Craftsman-Large-Displacement/dp/B07BS875L7 or something in that style.
thanks
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353525 02/18/20 11:10 AM
samven Offline
Yes you can but make sure the exit to the carb is at the bottom. If it sits horizontal or tipped exit up you will suck air once in a while. The old disc ones are just a filter screen. I run the same one on a Swisher field mower and a small 18 hp Troy Bilt yard tractor.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353535 02/18/20 11:17 AM
cb_13 Offline
Maybe. I always did that exact thing on older Briggs powered Murray riders with no issues. I tried on a Kohler powered John Deere and it could not get enough fuel to run in certain conditions. Both of those were gravity fed fuel systems, the Cub Cadet I have currently has a fuel pump and is not picky about fuel filters at all.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353540 02/18/20 11:20 AM
Dave9 Offline
Assuming all are the same 1/4" nipple, yes, but do you need two questionable quality filters and the hose, or just get the one they referenced in the listing which is B&S 691035?
That B&S is what I have on my 19HP Intek mower engine. It has more pleats, and based on the picture of the one you linked, looks like better quality too, before even considering the tubing which if made from chinesium rubber, may have a shorter life ahead of it than your existing fuel line. I'd sooner get some fuel line from an auto parts store by the foot before using generic chinese line.
https://www.amazon.com/Filter-Replaces-Briggs-Stratton-691035/dp/B0032LY2G2
You might be able to get this at same or lower cost from a local parts dealer. It's a very common filter.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353543 02/18/20 11:27 AM
J
JTK Offline
J
Just to add to the above, you can go as big as will fit and and fine filtering as the fuel system will tolerate. Like said, some gravity feed systems and vac/pulse driven fuel pumps can't pass fuel through too restrictive of a filter. I've run into that with Kohler Command V-twins with teh vac/pulse pump.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353547 02/18/20 11:34 AM
M
mattwithcats Offline
M
I would use a Wix 33031 fuel filter...
Metal can, 1/4 inlet/outlet...
https://www.wixfilters.com/Lookup/PartDetails.aspx?Part=230354
https://www.rockauto.com/en/parts/wix,33031,fuel+filter,6200
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353552 02/18/20 11:40 AM
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353555 02/18/20 11:45 AM
M
M
Also Dorman 55240...
https://www.rockauto.com/en/tools/fuel+&+air,fuel+filter,fuel+filter,6200
The plastic filters tend to dissolve/ melt...
2009 Smart Pure
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353560 02/18/20 11:53 AM
R
ragtoplvr Offline
R
The screen is plenty good, the debris will settle in the bottom of the float bowl. This you should remove and drain float bowl every so often so water does not accumulate if you are using pure gas. With ethanol it does not matter.
If you could mount an old style glass bowl sediment filter that would be best. Stens 120-030 or equivalent these are the best you can get.
Re: Larger fuel filter on Riding mower? [Re: mattwithcats] #5353568 02/18/20 12:01 PM
Dave9 Offline
?? Mine came originally with the B&S all plastic filter I linked, and lasted 20 years with E10 fuel before I replaced it just for the sake of doing so (still wasn't clogged enough to interfere with engine operation).
No melting or dissolving at all, though I can't speak for whatever mystery chinesium plastic that a generic brand might use.
Just wait though... eventually, the greenies will mandate that all plastics be formulations that turn to dust within 10 years... to save the planet... by adding to landfills at record paces due to product failures then more mining and oil to manufacture new products to replace them.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353574 02/18/20 12:05 PM
i dont know if its true or not, i was just reading but i heard that paper media filters are not good in gravity fed applications ? as it could starve the mower? and the disc types are recommended
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353575 02/18/20 12:07 PM
K
kschachn Offline
K
Yeah, the little plastic filter on my garden tractor is 20 years old and the one on my ancient Toro push mower is much older than that. No melting here in Southeastern Wisconsin where we haven't been able to buy non-RFG since 1995.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353576 02/18/20 12:08 PM
dwendt44 Offline
Fram G-1 gas filter. Less than $4.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353578 02/18/20 12:10 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Carburetors aren't as picky on cleanliness as fuel injection. Small particles that get past the filter will likely pass through the jets. Plus, the mesh screen filter can be cleaned with a reverse wash.
If you want to replace it with a paper media, go ahead, I see no harm, but it may be overkill.
Re: Larger fuel filter on Riding mower? [Re: dedonderosa] #5353583 02/18/20 12:19 PM
W
WyrTwister Offline
W
When I was a young Pup , I drove a car with a fuel filter that screwed directly into the carburetor . The other end of the filter had a bib , which a short section of rubber fuel hose attached to .
Said filter stopped up , on the highway , one day . Hitched a ride into town , purchased a new filter , got a ride to the car & replaced the filter .
When I got home , I purchased an inline filter , clamps and a short section of hose . Installed this filter , ahead of the one screwed into the carb . Figured , it the inline filter ever stopped up , I could take it out of the system and proceed with the original filter , in an emergency .
The in line filter never stopped up .
The car had the old style mechanical pump mounted on the engine .
Wyr
God bless
