Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
56 registered members (4WD, Amkeer, Astro14, 1foxracing, 53' Stude, 5 invisible), 964 guests, and 21 spiders.
Topics303,303
Posts5,233,548
Members71,038
Castrol edge 0w40 #5353459 02/18/20 09:32 AM
V
VQLT Offline OP
V
My neighbor gave me a 5 quart container of this oil. I have a 2018 Subaru Forester, 1999 saab 93, 2006 scion XA, and a 92 Nissan Pathfinder. Can I use this oil in any of these vehicles? I’m located in Southern California
Re: Castrol edge 0w40 [Re: VQLT] #5353463 02/18/20 09:36 AM
J
jeepman3071 Offline
J
You could probably use it in all of those vehicles without any issue.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: Castrol edge 0w40 [Re: VQLT] #5353484 02/18/20 10:05 AM
A
ARCOgraphite Offline
A
I would only use it in the saab or the pathfinder.
The other engine are viscosity sensitive due to the VVT cam phasers and light reciprocating components AND oil cooling requirement.
My Subaru FB engine didn't really like a thick 5W 20 grade in it during the summer
This is tried and tested, not sitting around a keyboard just guessing
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Castrol edge 0w40 [Re: VQLT] #5353493 02/18/20 10:20 AM
M
Miller88 Offline
M
I ran a 0w-40 in my FB25 Forster and it didn't seem to be too happy once the temperature cooled down. Had some weird stuttering and part throttle cruise misfires until the temperature was all the way up
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Castrol edge 0w40 [Re: VQLT] #5353496 02/18/20 10:25 AM
T
Trav Offline
T
In your location it will be fine in any but the pathfinder would be the one I use it in. The old Saab iron ecotec really like higher viscosity oils and a higher level of zinc if you want the cam chain to live a longer life.
I run Delo LE 5w40 or Mobil Delvac 1 ESP 5W40 or Mobil 1 Turbo Diesel Truck in these and Mobil 1 5w30 ESP or Castrol 0w40 in the later aluminum block engines.
Re: Castrol edge 0w40 [Re: VQLT] #5353512 02/18/20 10:52 AM
Quattro Pete Offline
Is the Forester still under warranty? If so, I'd probably use whatever the OM calls for in that one. Not because I think Edge 0W-40 will cause any issue, but to avoid any potential warranty claim hassles.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Castrol edge 0w40 [Re: VQLT] #5353522 02/18/20 11:05 AM
T
TurboTristan Offline
T
Use it on your SAAB, it's the same oil I used on my 9-5 smile
Keep on SAABin'
2008 SAAB 9-5 SportCombi - Castrol Edge 0W40/MAHLE OC981
1994 SAAB C900 Turbo CE - Castrol Edge 10W30/MANN W712/80
1989 SAAB 9000 Turbo CD - Castrol Edge 10W30/MANN W712/80
Re: Castrol edge 0w40 [Re: TurboTristan] #5353541 02/18/20 11:25 AM
T
Trav Offline
T
Your 08 is a later aluminum block engine with a later version of the cam chain tensioner to say nothing about the difference in location.
Re: Castrol edge 0w40 [Re: VQLT] #5353813 02/18/20 05:35 PM
dogememe Offline
I'd use it in the Saab or Pathfinder.
2010 Ford Escape 2.5 ~103K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~291K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Castrol edge 0w40 [Re: ARCOgraphite] #5353821 02/18/20 05:48 PM
J
jbutch Offline
J
In the summer time, there is no way a 5w-20 would behave differently than a 0w-20.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Castrol edge 0w40 [Re: VQLT] #5353942 02/18/20 08:32 PM
Skippy722 Offline
I’m using it in both my 3.6 Pentastar v6’s. I cannot tell a difference between it and 0w20 or 5w20 other than it is slightly quieter. I’d use it and not think twice.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Castrol edge 0w40 [Re: jbutch] #5354258 02/19/20 09:28 AM
A
A
Here we go with blanket statement again with no data or experience.
I just TOLD you it did.
I drove the car, ride in the car on trips an I noticed the difference. It was easily drivable, but didn't rev as eagerly, a little bit sluggish - but quieter running when hot.
Are you aware that Japanese 0W20 are directed at fuel conservation and high efficiency? Moreseo than 5W?
They tend to be formulated closer to the BOTTOM of the 20 grade range. whereas 5W20 are near the TOP of the 20 grade range.
Suabru idemitsu KV40 is ~ 37 cSt
KV100 is ~7.8
Here is (plain vanilla) Mobil 1 5W20
Viscosity @ 100ºC, cSt (ASTM D445) 8.9
Viscosity, @ 40ºC, cSt (ASTM D445) 49.8
Viscosity Index 160
Recall that this engine oil temp runs well below boiling; Around 77C
Re: Castrol edge 0w40 [Re: jbutch] #5354521 02/19/20 02:17 PM
A
A
I apologize, I was too harsh in my reply above.
I had just finished a double tea an got a bit irritated. Canada + USA
Re: Castrol edge 0w40 [Re: VQLT] #5354748 02/19/20 06:32 PM
V
VQLT Offline OP
V
I'm not sure when 0w40 was first introduced but in my research and reviewing my owners manuals, not one of my cars recommends 0w40. Saab recommends 10w30 or 40, Nissan 5w30 or 10w30, scion 5w30, forester 0w20. I think I will pass along the Castrol 0w40 to someone that can use it.
thanks for all the replies
Re: Castrol edge 0w40 [Re: VQLT] #5354752 02/19/20 06:36 PM
Bryanccfshr Offline
It will run fine in any of the vehicles in Southern California.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
