Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
43 registered members (caprice_2nv, Char Baby, 53' Stude, 4WD, 1foxracing, 6 invisible), 696 guests, and 15 spiders.
Topics303,303
Posts5,233,538
Members71,038
Page 1 of 3 1 2 3
New gaming build shutting down on Metro 2033 #5353053 02/17/20 08:09 PM
Cujet Offline OP
Yesterday, I put together the following: i9 9900KF, Nvidia RTX 2080, Gigabyte Z390 Aorus Ultra MB, 32GB ram, 2ea. 2TB Samsung 970 plus M.2 hard drives.
The video card and PS are fairly new, as they were used for a few weeks in my i7 2700K build. That one shut down too on Metro 2033.
Both the new and old builds shut down, hard and cold, on Metro 2033 and occasionally on Prey, but not in regular use. GPU temps get WAY up there at times, but I turned the fans up and resolution down, GPU temps stay below 60c and still shuts down.
Previous build w/old PS (one I can't use on the RTX 2080 card) shut down too. So, I don't know what to think, other than to blame the game.
CPU temps are low, no fault codes recorded in Windows.
Any thoughts on troubleshooting?
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353090 02/17/20 08:39 PM
K
KrisZ Offline
K
Is the video card on the latest drivers? Is it stock or overclocked?
What's the size of the PSU? Should be at least 650W for a GTX 2080.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353094 02/17/20 08:43 PM
W
wkcars Offline
W
Are you manually setting the 3D settings in the Nvidia control panel, if so try turning off some settings. Usually I have these set to off on my 1080. DSR - Factors, Low Latency Mode, Max Frame Rate, Multi-Frame Sampled AA, Shader Cache. I read alot about shader cache as being possible culprit in crashes in a number of games. I normally set Power management mode to Adaptive. You can play with other settings like setting the aniosotropic filtering and overriding the game's antialisaing mode which I normally set manually in the nvidia control panel.
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353178 02/17/20 09:53 PM
Danno Offline
What's the PS model? How old is the PS?
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353206 02/17/20 10:12 PM
J
jayjr1105 Offline
J
Model and wattage of power supply? 9900K and RTX2080 are going to pull some serious juice. You should have a high quality 750w power supply. Something like this
https://www.amazon.com/EVGA-Supernova-Modular-Warranty-220-G5-0750-X1/dp/B07WGQT8CC
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: New gaming build shutting down on Metro 2033 [Re: Danno] #5353207 02/17/20 10:13 PM
Cujet Offline OP
PS is a Corsair CX 750 M. It's a month old.
Re: New gaming build shutting down on Metro 2033 [Re: KrisZ] #5353210 02/17/20 10:15 PM
Cujet Offline OP
Yes, built the unit yesterday. Drivers are the latest.
The RTX 2080 is on all stock settings. Nothing is overclocked or tweaked. However, I did install "afterburner" so I could turn the video card fans all the way up. Did not help.
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353213 02/17/20 10:16 PM
J
jayjr1105 Offline
J
Corsair CX is a middle of the road/budget minded unit. You spent a small fortune on CPU/Cooling/GPU and you bought a $80 power supply.... tisk tisk.
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353215 02/17/20 10:17 PM
J
jayjr1105 Offline
J
Also, use DDU to remove all drivers and start from scratch
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353234 02/17/20 10:35 PM
DrDanger Offline
Check you dont have both 12v connectors for the 2080 on the same cable/rail or sharing a line with the cpu.
Even if the PSU is a single rail design each 8 pin connector is rated around 100W if memory serves. Get HWinfo64 and use the log feature to check voltages during load.
Re: New gaming build shutting down on Metro 2033 [Re: jayjr1105] #5353246 02/17/20 10:56 PM
Cujet Offline OP
Any suggestions as to a better brand/unit?
I have a spare PS, maybe I'll hook the spare only to the video card and see what happens.
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353259 02/17/20 11:16 PM
G
GZRider Offline
G
Seasonic PSU's are top notch for gaming or rendering, but they aren't giving them away.
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353308 02/18/20 12:44 AM
R
rubberchicken Offline
R
I had the exact same power supply, and ran a big water cooled system with dual Nvidia 980 in SLI. I had the same behavior if I left the Nvida cards in SLI mode and ran a game. I upgraded the power supply and the problem went away. The Corsair is an OK power supply, but I think it gets choked on the power rail that goes to the card. See if this is the behavior- game is running for 1-10 minutes in heavy graphics demand, and machine just powers off- no errors, no warning, no nothing. You may have to unplug or power off at the power supply to reset it. If so, that is even further pointing to the power supply. You can also try underclocking (way serious underclock) the graphics card to see if the problem goes away. In my case I had a Kill-A-Watt meter and was only drawing about 450 watts, but it just exceeds the capacity on the VGA rail.
There are power supply testers available, but I do not think the cheap ones will tell you much in this situation. Look for a bigger, newer power supply that will support SLI , and donate the Corsair to another PC or eBay. Try putting in your config into https://pcpartpicker.com/ and see if it throws any errors on the power supply (I probably will not, but it might).
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353433 02/18/20 08:39 AM
03s Offline
Best Power Supplies for RTX 2080 & RTX 2080 Ti Builds
Link
2005 Chevrolet Optra
Mobil 1 Extended Performance High Mileage 5W30, MotoMaster OE Plus MOPH3387A
Re: New gaming build shutting down on Metro 2033 [Re: Cujet] #5353434 02/18/20 08:40 AM
B
BMWTurboDzl Offline
B
PSU.
435i
Page 1 of 3 1 2 3
