Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
97 registered members (2015_PSD, 2002 Maxima SE, 53' Stude, 4WD, 2004tdigls, 2oldtommy, 7 invisible), 2,710 guests, and 21 spiders.
Topics303,643
Posts5,238,956
Members71,105
Step Shift Transmission #5352548 02/17/20 10:24 AM
G
Gebo Offline OP
G
I was reading a thread and it talked about a "Step Shift Transmission."
What exactly is that? In 6th Grader terms.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Step Shift Transmission [Re: Gebo] #5352558 02/17/20 10:33 AM
P
Pew Offline
P
Basically an automatic where you have the option of selecting gears. Think of driving a normal 6-speed automatic torque converter car, and you get to slide the stick over from P-R-N-D and hit the + or - to make the car shift gears.
Re: Step Shift Transmission [Re: Gebo] #5352562 02/17/20 10:40 AM
G
Gebo Offline OP
G
Wow! Thank you. I got that option in several cars I drive. Like those little thumb paddles on the steering wheel. Or where I can move the console shifter over and pretend I am driving an automatic.
I never use it, obviously.
Thanks!
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Step Shift Transmission [Re: Gebo] #5352628 02/17/20 11:56 AM
M
miden851 Offline
M
In other words a multitronic, my Mazda have it and I use it occasionally
2008 Mazda6i GT; @240K miles
2016 Honda CR-V EX-L; @56K miles
Re: Step Shift Transmission [Re: Gebo] #5352673 02/17/20 01:09 PM
J
JustN89 Offline
J
Or Shiftonic, or manumatic, or whatever different brands call it. Pew summed it up best. Operates like a traditional automatic, but allows you to shift gears manually as well.
Re: Step Shift Transmission [Re: Gebo] #5352680 02/17/20 01:26 PM
MolaKule Offline
Global Moderator
Global Moderator
Not a manual transmission, CVT, or an automated Manual.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Step Shift Transmission [Re: MolaKule] #5352733 02/17/20 02:26 PM
R
Rand Offline
R
actually it can be a cvt or automated manual.
Quote
there are certain truths that are understood when it comes to Continuously Variable Transmissions. They are extremely fuel efficient and they’re great for climbing hills, but they feel unresponsive and they sound rather unpleasant. Nissan is looking to appease those who want CVT efficiency without the shiftless feeling by introducing D-Step Shift Logic to the 2015 Versa, Versa Note, Sentra, Altima V6, Pathfinder, and Quest.
D-Step Shift Logic is a software update that will give drivers the feeling that their vehicle is shifting gears like a regular automatic transmission. Once the vehicle reaches 4,000 RPMs, the software will manipulate the Xtronic CVT to fabricate a drop in driving force and follow it up with a jump ahead, creating a sensation similar to that of shifting gears.
Subaru CVT also will do fake gears.(at least on some models such as outback)
Quote
Lineartronic® CVT Transmission
In Automatic Mode, the Lineartronic® CVT adjusts instantly to match your acceleration, eliminating the need to shift and preserving the vehicle's momentum — often lost with conventional automatic transmissions. In 6-Speed Manual Mode, paddle shifters are mounted for fingertip control, giving you the power to select the gear ratio that best suits your driving situation. The result is a sharper and sportier driving experience.
Re: Step Shift Transmission [Re: Gebo] #5352775 02/17/20 03:03 PM
MolaKule Offline
Global Moderator
Global Moderator
A Step-Shift transmissions is an automatic transmission with Fluid coupling (Torque Converter) and is sometimes referred to operationally as a "step gear" automatic transmission (AT) because of stepping from one gear ratio to another automatically instead of a continuous ratio (such as a CVT) or having to manually shift a transmission with a mechanical clutch.
Quote
...In the transmission area, emerging technologies [1] such as continuously variable transmission (CVT), dual clutch transmission (DCT), automated manual transmission (AMT) and
electrically variable transmission (EVT) have appeared in the martket, which is traditionally dominated by step gear automatic transmission (AT) and manual transmission (MT)...
http://folk.ntnu.no/skoge/prost/proceedings/acc05/PDFs/Papers/0582_ThC14_2.pdf
Re: Step Shift Transmission [Re: Rand] #5352905 02/17/20 05:20 PM
CR94 Offline
That's only a fake step-shift. MolaKule is correct.
2011 Toyota Prius now at 110K
Re: Step Shift Transmission [Re: Gebo] #5352936 02/17/20 05:52 PM
G
Gebo Offline OP
G
Is this a step shift?
[Linked Image]
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Step Shift Transmission [Re: Gebo] #5352967 02/17/20 06:35 PM
R
Rand Offline
R
so by that guy's definition every Automatic transmission with a torque converter is a step shift transmission?
even the ones you cant manually shift.. got it.
and CVT's arent a step shift transmission they can only simulate one.
by using "step shift logic"
Re: Step Shift Transmission [Re: Gebo] #5353089 02/17/20 08:39 PM
K
Kibitoshin Offline
K
"Step Shift" is a marketing name for using paddle shifters or flick of a lever way of commanding gears in an automatic transmission whether CVT, dual clutch, automated or torque converter.
Because manually selecting gears in an A/T is not new (lever, pushbutton, kickdown button) it's having a less clunker way to command gear selection.
Shin Gekiretsu Shin'ou'hou
02 Chevy Silverado C1500 V8 5.3L
Penske Freightliner M2-106 Reefer Box Truck ISB6.7
Re: Step Shift Transmission [Re: Kibitoshin] #5353101 02/17/20 08:49 PM
B
bbhero Offline
B
I think this is right ^^^^^^
I did like the paddle shifter on the Audi a5 I had last year as a rental...
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Step Shift Transmission [Re: Rand] #5353240 02/17/20 10:42 PM
CR94 Offline
so by that guy's definition every Automatic transmission with a torque converter is a step shift transmission? ...
Usually, but not necessarily. Most conventional automatics with a series of several (2-10) fixed gear ratios. (Usually associated with a torque converter, although some early ones used a fluid coupling instead).
Not a CVT attached to a torque converter.
