Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
102 registered members (53' Stude, 4WD, 762fermeandyou, 92saturnsl2, 007, 5AcresAndAFool, 6 invisible), 2,167 guests, and 19 spiders.
Topics303,306
Posts5,233,690
Members71,038
Page 1 of 4 1 2 3 4
Oil choice for highly modified Japanese turbo 4cyl #5352540 02/17/20 10:18 AM
N
nick470 Offline OP
N
So guys and gals, I'm looking to step into some engine oil a little higher quality than the Rotella T6 I've historically used on my car. The car is a turbocharged Japanese 4 cylinder and runs anywhere from 15 to 25 psi of boost, up to 8,000rpm, and will see sustained high load driving (road course, autox, canyon carving) as well as street driving. It is a highly modified engine, bored larger than stock with all forged internals. It is not a daily, and I'm happy to shell out more for top quality oil simply because it's cheap insurance. Ideal oil weight is probably 40, but I might consider a 50 weight for any track time it will see in 90*+ weather depending on what clearances I end up running. I would like to run full synthetic, and the car never sees more than about 250* oil temps, typically sitting in the 200-220* range thanks to a very large oil cooler. I change oil after almost every track event.
The primary reason for looking to upgrade the oil that I run in this engine is that it is currently torn down being rebuilt after finding some excessive bearing wear. While basically any old synthetic oil in the right viscosity *should* be fine for my uses, given the nature of the car and the fact that it's currently torn down to rebuild after some accelerated wear, I simply want to fill it with whatever is objectively the best oil I can. The engine sees some excessive forces well beyond what the manufacturer intended - MUCH higher cylinder pressures (the engine makes 3-4x the power of a stock example), higher RPM, a turbocharger, alcohol based fuels, sustained high load+high temp driving, etc. Some oils are certainly going to be more up to the task of dealing with this than others. This is the third time this engine has been out, and I'd really like it to be several years and many thousands of miles before it has to come out again smile If I end up paying a decent bit more for oil changes with a marginal improvement in engine protection, that peace of mind is worth it to me to shell out for something like Amsoil or Schaeffers.
I'm considering options such as LiquiMoly, Motul, Schaeffers, Redline, and Amsoil but I am certainly happy to add other options to that list. I'm sure the car would probably be happy with any of those, but I'm hoping to find some rationale that might bring one or two brands or formulas to the forefront of my consideration. Engine protection is my primary concern here.
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352543 02/17/20 10:20 AM
R
robertcope Offline
R
I'm guessing any of them would do fine and I doubt anyone can provide concrete, scientific data otherwise. Red Line is what I use in my motors, never had an issue. Certainly interested in hearing the discussion, though!
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352546 02/17/20 10:23 AM
CT8 Offline
The engine has some serious mods ,I would ask the builder of the engine.
2015 F150 2.7
2018 F350 6.2
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: CT8] #5352550 02/17/20 10:26 AM
G
Gebo Offline
G
Agreed. thumbsup
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352569 02/17/20 10:45 AM
A
avi1777 Offline
A
in my 550whp sti i used the motul 300v,u cant go wrong with this oil.
btw the build quality,right parts and tune is the most important in keeping your engine alive.
many oils will do the job but if the engine was assembled bad,or with weak parts and bad tune
the engine will die regardless of the oil used.
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352574 02/17/20 10:52 AM
A
A_Harman Offline
A
If you're having bearing problems, I would look into tightening the clearances. Tighter bearing clearances lead to lower peak film pressures. The highest-end racing engines such as F1 are built with such tight bearing clearances that they are locked up at room temperature and must be preheated to get enough bearing clearance to start.
If you are running alcohol based fuels, maybe you are getting excessive fuel dilution, and the oil is thinning.
Have you been taking oil samples? Maybe you could find adverse conditions before it leads to real engine damage again.
If you have a really good intercooler, I would say stop running the alcohol fuel. I can't remember ever seeing anybody running alcohol fuels in 30 years of track driving. Yes, IndyCar does it, but the engines are designed from the start for it.
If you have a really big oil cooler, and oil temp never gets above 250F, you should not need 50-weight oil. 40 should be sufficient.
Do you have data logging on the car so that you can see if oil pressure is stable at all points on a race track? Reading between the lines of your post, you have been having repeated bearing failures in short time intervals, and you are using good oil and changing it after almost every event. Maybe your problem is more related to crankcase venting and breathing. The best oil in the world isn't going to protect your engine if it can't get back to the sump to be picked up by the pump to ensure stable gallery pressure. Loose bearing clearances mean higher oil flow, so more oil is flying around the crankcase. High boost pressure means higher crankcase pressure, making it impossible for oil to return by gravity to the sump.
What engine and what car are you working on?
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352578 02/17/20 10:56 AM
A
avi1777 Offline
A
many shops uses the t6,like switzer performance which builds some nasty gtr׳s.
if its my motor id go with the 300v or redline.(cant get the t6 or penrite oil here which i saw being used in some 2000whp gtrs as well.)
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: avi1777] #5352591 02/17/20 11:10 AM
P
PowerSurge Offline
P
This. I run 300V in my boosted Si (spends A LOT of time above 4500 RPMS) and has never let me down. The inside of the engine is as clean as can be.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352592 02/17/20 11:15 AM
K
ka9mnx Offline
K
Unfortunately with an engine like yours, and driving style, frequent rebuilds are part of ownership.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352603 02/17/20 11:35 AM
L
Lasthope05 Offline
L
Are you running an accusump? What oil pan are you running? I'm almost willing to bet if it's not an extra capacity/baffled pan then that's your issue with wiped out bearings. Oil starvation.
Also if you have an inadequate PCV/catch can system, at high rpms, all that oil is getting backed up in the head as the crankcase gases are impeding the oil drains in head. Lots of different things can come into play here.
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: ka9mnx] #5352604 02/17/20 11:37 AM
A
avi1777 Offline
A
+1
been thru 3 engine my self,thats the game.
build,race,brake,repeat.
in general try to use as little boost as possible.
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352614 02/17/20 11:43 AM
L
Lasthope05 Offline
L
I'm on my same engine for over 4 seasons. 850whp, 4 cylinder, 45psi and everything looked fine last time I broke it down for inspection. I run 20w50 vr-1. Engines last if they're built and tuned properly for their intended application.
Also what engine are you running and what clearances? Mains/rods, PTW...
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: Lasthope05] #5352619 02/17/20 11:46 AM
A
avi1777 Offline
A
+100
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: avi1777] #5352622 02/17/20 11:47 AM
L
Lasthope05 Offline
L
4 cylinder. 4g63.
Re: Oil choice for highly modified Japanese turbo 4cyl [Re: nick470] #5352677 02/17/20 01:17 PM
B
benjy Offline
B
real synthetic Ester based oils are the gold standard for sure!! as noted everything must be RIGHT when engines are pushed to extremes. Redline my fav notes a break in with conventional oil when using their real synthetics + they have REAL hard core oils for RACING, no additives for longer drains but extreme zddp etc for the most protection!!
Page 1 of 4 1 2 3 4
