If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
48 registered members (bbhero, bachman, berniedd, Bailes1992, 14Accent, avi1777, 2 invisible), 835 guests, and 16 spiders.
Topics303,496
Posts5,235,115
Members71,061
I Did Buy the 4Runner 3.4 V6 w/253,000 miles #5352460 02/17/20 08:59 AM
Speak2Mountain Offline OP
1) Previous owner kept detailed records and was truly OCD about maintenace
2) OCI's at 6k using 5w30 Castrol syn-blend
3) Transmission rebuilt at 130k and fluid has 30k miles (never heard of transmission in Taco or 4runner needing rebuilding)
4) Water pump and TB replaced 20K miles ago
5) Coils, plugs, and plug wires, O2 sensors, MAF sensor replaced last month
6) New tires
7) AC compressor, expansion valve, receiver dryer replaced in 2016
8) New battery...last year
9) I checked and rechecked..no rust anywhere
There's a new niggling things: gotta get a new antenna (yes, I still listen to the radio), visor w/Homelink needs replacing...very hard to find, big scratch on passenger door in rear, and lastly....clear coat coming off roof (in places) and small place on hood.
Otherwise, its a sound truck
He provided me 2 OCI's of oil, never used Castrol but its free and 5, yes 5 Toyota oil filters
I'm seriously thinking of using HM semi-syn heavier oil when the free oil runs out.
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352475 02/17/20 09:14 AM
T
tig1 Offline
T
Heavier oil??? Why would you do that??
2007 Ford Fusion 255,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352487 02/17/20 09:27 AM
G
Gebo Offline
G
Do the fluid changes.
And if that 4Runner had only used the Castrol its entire life, I'd tend to stick with it.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352504 02/17/20 09:37 AM
T
Triple_Se7en Offline
T
What was the out-the-door price you paid?
Sounds like it's been well kept-up overall.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352514 02/17/20 09:43 AM
A
ARB1977 Offline
A
I did 30K sevice intervals with Amsoil or Maxlife ATF back when I had my beloved 2002 Tacoma. 190K at trade in with not issues. I did put a external transmission cooler on it.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352556 02/17/20 10:30 AM
stockrex Offline
I had a honda accord with 210k miles,
The ONLY thing that failed was alternator (delphi) changed with a Denso
couple of wheel bearings and rotors and timing belt once wtih spark plugs, that is it.
How was this 4runner used? not of failure of parts, what could be the root cause?
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352649 02/17/20 12:41 PM
E
eljefino Offline
E
Wonder what he was chasing, bad performance or MPG?
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352694 02/17/20 01:45 PM
J
JimPghPA Offline
J
If the power-steering fluid has not been changed within the last 3 years, do multiple drains and fills. Fresh fluid reduces the probability of the power-steering system having problems such as the seals for the pump or other parts leaking.
Get a old container to put the used power-steering fluid in. Get a funnel, Pep-Boys sells a nice very long funnel. Buy two big bottles of power-steering fluid and some kind of suction device. I used a low cost bottle that normally ketchup or mustard is put in and put a small diameter brass tube in the top to extend the ability to pick up to about 10 inches. Suck out all the power steering fluid you can from the pump, then fill the pump with new fluid, and put the cap back on the pump. Start engine and turn wheel all the way to right, then all the way to left, the all the way to right, then all the way to left, then back to center, and stop engine and repeat suction and fill and turning with engine running until you use all of the two bottles up.
Repeat every 3 years.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Triple_Se7en] #5352757 02/17/20 02:51 PM
3850.00 otd
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: JimPghPA] #5352786 02/17/20 03:12 PM
T
T
Thank You for the tip.
I wonder if my wife's turkey baster would work too for suction?
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Triple_Se7en] #5352818 02/17/20 03:41 PM
T
Toh1 Offline
T
It will work.
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352847 02/17/20 04:18 PM
J
john_pifer Offline
J
Mississippi climate?
Ideal for a 10W-30.
I’d run whatever 10W-30 full-synth you can get on sale.
Platinum is a good one.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Speak2Mountain] #5352864 02/17/20 04:41 PM
T
Toy4x4 Offline
T
I would use a syn ATF instead of power steering fluid. It is the OEM fluid. I don't know about the PS system on the 3.4, but on the 3.0 I had, it needed two rebuilds within 100K. I think something to do with getting too hot. I switched to Redline D4 ATF sometime after the second rebuild and it never had an issue after that. Sold it at 206K with occasional reservoir drain and fills. It actually made the steering more easy to turn, too. I do the drain and fills on by current 4Runner...still using the D4.
2007 Toyota 4Runner Ltd V8 Titanium Metallic
M1 0w40
2018 Mustang GT Premium Ingot Silver A10 PP1
M1 5W30
Gone:
1993 Toyota 4x4 3.0 owned 20 years
1969 Chevelle
1989 Civic Si HB
1981 Civic DX HB
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Toy4x4] #5352875 02/17/20 04:49 PM
A
aquariuscsm Offline
A
If a vehicle specs power steering fluid,can atf be used in its place? What exactly is “power steering fluid”? My Accord specs Honda branded power steering fluid,but my 300ZX spec’d atf?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: I Did Buy the 4Runner 3.4 V6 w/253,000 miles [Re: Triple_Se7en] #5352892 02/17/20 05:06 PM
G
Gebo Offline
G
It will work. I just went to a Vet's office and purchased the biggest syringe they had and attached some clear tubing to the nozzle.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
