New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
Castrol edge vs Valvoline synthetic?
by BTLew81 - 04/04/20 10:16 PM
My 1997 Ford Aspire 1.3 beater has me stumped
by IMSA_Racing_Fan - 04/04/20 09:50 PM
Baldwin B5134 Coolant Filter Cut Open
by FordFETruck - 04/04/20 09:32 PM
Pros vs Cons of upgrading to better filter
by PantherFan88 - 04/04/20 09:23 PM
Touch up paint
by WhyMe - 04/04/20 08:31 PM
Hemi plug change - plug covered in oil
by BigD7 - 04/04/20 07:16 PM
2020 M340i - CQuartz UK 3.0 & Gliss
by gofast182 - 04/04/20 07:14 PM
What VPN do you Recommend?
by Gebo - 04/04/20 06:39 PM
Email Service
by Gebo - 04/04/20 06:38 PM
Mobil 1 15W50?
by Realfine69 - 04/04/20 06:36 PM
3+ weeks in, and no TP
by MrQuackers - 04/04/20 06:20 PM
Cruise ship vs littoral navy ship, 1:0
by vavavroom - 04/04/20 06:19 PM
MOPAR MO-285 CUT OPEN
by 53' Stude - 04/04/20 05:53 PM
UOA, DexronVI, 26k miles, GM 6L80
by jetman - 04/04/20 05:37 PM
2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
northestPM, dgvu89, Kevin1987, Thetrashman33, YLK
71099 Registered Users
41 registered members (carlprop, clinebarger, Bailes1992, blufeb95, Black_Thunder, CELICA_XX, 3 invisible), 1,425 guests, and 20 spiders.
Topics303,611
Posts5,238,305
Members71,099
Page 1 of 3 1 2 3
Do new Jeeps have death wobble? #5352404 02/17/20 08:21 AM
supton Offline OP
Had a new-ish looking Jeep pass me this morning, only to slow down. I thought it odd, then realized a front wheel was shaking--then realized it was both, and that was why he had slowed down. I stopped to make sure he was fine, he was, he'd been driving it as a rental for the last day.
It wasn't a Cherokee, it was... Wranger? dunno, not a Jeep fan. Not one of the FWD things but a regular 4x4 setup, but not one of the upscale ones either.
Anyhow, death wobble or just flogged rental?
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Do new Jeeps have death wobble? [Re: supton] #5352407 02/17/20 08:25 AM
diyjake Offline
Sounds like a death wobble, not a fun experience.
Re: Do new Jeeps have death wobble? [Re: supton] #5352412 02/17/20 08:27 AM
P
PowerSurge Offline
P
Death wobble. Common with Jeeps and Rams with 4x4 and solid front axle.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Do new Jeeps have death wobble? [Re: supton] #5352419 02/17/20 08:30 AM
Spktyr Offline
Either or both. You can get death wobble in brand new factory setup rigs that have no wear (and don't have a design defect), and of course a worn rig can have death wobble.
IIRC, there *were* a couple recent lawsuits about the Wrangler, alleging that recent versions have a design defect that causes death wobble and FCA released an updated steering damper to 'fix' it. I didn't ever look into the issue far enough to see if it was a "we're going to bandaid it with this damper" fix, "the damper is needed and will actually permanently correct it" fix, or if it was "there isn't a problem with the system, we're fitting a damper to make you idiots shut up" kind of fix.
It's pretty common in any solid front axle setup, some more than others - but it can affect IFS vehicles too. 4Runners like mine have a highly stressed lower ball joint setup that can cause death wobble when it wears. Uppers too, but they're less likely.
Re: Do new Jeeps have death wobble? [Re: supton] #5352420 02/17/20 08:31 AM
Driz Offline
The older ones 90s - 2000 early types I had the displeasure to deal with I’ll head a shimmy damper under the front center of the fan area. It looks like a small shock absorber mounted laterally. Whenever that thing wore out you knew it because it felt like the front end was going to fall off the thing. The only thing I ever saw worse for shaking it self to pieces and those grand Cherokees when The damper went out was a Cessna. Same sort of thing gets to a certain speed and you think that [censored] thing is going to fly apart.
Anyways if it’s got any miles on it and it has one of those things you probably just wanna go ahead and change it because you’re only like 35 $40 and real easy to put on. Jeeps are the only trucks that have those things and they all seem to have that same death wobble when it’s worn out issue. I’ve pulled a few of them off and throw them away and they felt just fine but for whatever reason internally they weren’t working right so if you’re gonna bother taking it off just replace it
Re: Do new Jeeps have death wobble? [Re: Driz] #5352435 02/17/20 08:41 AM
Spktyr Offline
Jeeps are definitely not the only trucks that have steering dampers, my F-350 had one from the factory. Not even the only vehicles - the last GM B-body cars had them from the factory.
Re: Do new Jeeps have death wobble? [Re: supton] #5352437 02/17/20 08:42 AM
M
Miller88 Offline
M
If they stick with a proper leaf sprung front end, they wouldn't death wobble. But anything that relies on the panhard bar for both lateral location and to keep the steering geometry in line is going to deathwobble. At least with leaves, the springs locate the axle.
If everything is in good shape, you do NOT need a steering stabilizer. My 2000 Cherokee with 214K miles doesn't even have one.
There's 2 ways to get out of death wobble. Stand on it and power through or slow down.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Do new Jeeps have death wobble? [Re: supton] #5352439 02/17/20 08:43 AM
Chris142 Offline
Mine got death wobble when it was new. Replacing the rubber bushings with neoprene ones fixed it. Never has it done it again.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Do new Jeeps have death wobble? [Re: supton] #5352449 02/17/20 08:49 AM
supton Offline OP
Cool, at least I didn't give the guy bogus info. It was a rental and I'm pretty sure I know how it'll get fixed.
Re: Do new Jeeps have death wobble? [Re: supton] #5352478 02/17/20 09:22 AM
J
jeepman3071 Offline
J
Death wobble is common on solid front axle vehicles like the Wrangler when steering or suspension components are worn. Being a fairly new rental, it's likely it has been abused or someone hit something causing play in the steering.
Steering dampers are not the correct way to fix death wobble, and will only mask it for a short period of time.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: Do new Jeeps have death wobble? [Re: Miller88] #5352480 02/17/20 09:22 AM
Spktyr Offline
My F-350 had front leaf springs. It had death wobble issues, so leaf springs aren't the answer either. It can help, buuuuut....
Re: Do new Jeeps have death wobble? [Re: jeepman3071] #5352510 02/17/20 09:42 AM
P
PowerSurge Offline
P
Negative. Its not from just when parts are worn. It’s happening to Jeeps under warranty.
Re: Do new Jeeps have death wobble? [Re: supton] #5352532 02/17/20 10:06 AM
demarpaint Offline
According to the Jeep Wrangler forum I moderate on, yes right up to the 2019's and IIRC a few 2020 owners have reported problems. Are all of them impacted? No... Some people have had repair attempts which didn't help either.
God Bless Our Troops
Re: Do new Jeeps have death wobble? [Re: supton] #5352623 02/17/20 11:49 AM
sloinker Offline
Many Mercedes have the front stabilizers on them. Macpherson strut front end. Doubt they are there for anything except to firm up reaction feedback into the steering wheel. Never had any death rattle on my Mercedes, even when I got it up to 145 MPH once. My knees rattled though. Published reports stated its top speed at 150+ mph and I believed it but never found that limit. There are a million videos on youtube showing fixes for the death rattle.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Do new Jeeps have death wobble? [Re: Spktyr] #5352640 02/17/20 12:16 PM
O
OVERKILL Offline
O
This.
It's a well-known artifact on anything with a solid front axle, but not exclusive to them.
Here's an article on the RAM heavy duty truck death wobble, he mentions he experienced it in a Lincoln Continental:
https://www.thurenfabrication.com/tech/death-wobble-in-depth.html
Here's a company selling a kit to eliminate the Super Duty death wobble:
https://www.superdutywobble.com/
And a Truck Trend article noting that while Death Wobble is more prevalent on Ford and Dodge/RAM trucks, it does happen on IFS trucks:
http://www.trucktrend.com/how-to/ch...death-wobble-tightening-up-your-steering
And here's a thread about it happening in an old 4Runner:
https://www.4runners.com/threads/1987-4runner-death-wobble-where-to-look-first.11827/
Page 1 of 3 1 2 3
