Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
75 registered members (bcossa2001, 4WD, BAJA_05, atikovi, 2009Edge, 94astro, 11 invisible), 1,074 guests, and 17 spiders.
Topics303,303
Posts5,233,562
Members71,038
Moog wheel bearing and knuckle assy #5352116 02/16/20 08:37 PM
I
Imp4 Online Content OP
OP Online Content
I
Looking for information from people that have tried the Moog complete wheel bearing / hub / knuckle assemblies.
I'm looking at one for an '09 Camry beater.
Currently $217 from Rock Auto.
For comparison, an SKF wheel bearing and hub is $127.
I don't have access to a press so getting the old bearing out and the new one in would likely cost me an extra $50.
The Moog comes with a 3 year / 36000 mile warranty which would likely outlast the lifetime of the vehicle.
Please don't just post to hate on Moog. I know their quality has been spotty the last several years.
Just looking for impressions from someone who has used one of these.
Thanks!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5352125 02/16/20 08:45 PM
spasm3 Offline
The difference in price covers 2/3 of the price of a 20 ton press from hf. I have the 12.
If you have room for a press, get the press( $140 with coupon) and the skf bearing.
https://www.harborfreight.com/20-ton-shop-press-32879.html?ccdenc=eyJjb2RlIjoiMzYxOTM5NDgiLCJza3UiOiIzMjg3OSIsImlzIjoiMTQ5Ljk5IiwicHJvZHVjdF9p%0D%0AZCI6IjQ1MyJ9%0D%0A&utm_source=go&utm_medium=referral&utm_campaign=shortener&utm_content=couponimage&cid=go_social
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Moog wheel bearing and knuckle assy [Re: spasm3] #5352127 02/16/20 08:48 PM
I
OP Online Content
I
I don't have room for the press.
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5352128 02/16/20 08:49 PM
T
Trav Offline
T
I have no first hand experience with them but IMO you would be better served with the SKF and a press job, you know the OE knuckle fits and most importantly it aligns.
I had Moog LCA that would not align properly and had a real fiasco returning and redoing the job with more bum parts until I got sick of it and tossed it and bought an OE unit which aligned perfectly first shot.
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5352129 02/16/20 08:49 PM
E
eljefino Online Content
Online Content
E
When I was in your situation I did well just getting junkyard spindles for $25.
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5352180 02/16/20 09:34 PM
M
maxdustington Offline
M
https://www.amazon.ca/Astro-Pneumatic-Tool-78825-Installer/dp/B01JBK2OJOI've used this for three wheel bearing replacements now, it works pretty well. I've broken two air impacts using it, though. One of which was a 231g which are supposed to be indestructible.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Moog wheel bearing and knuckle assy [Re: maxdustington] #5352211 02/16/20 10:10 PM
spasm3 Offline
I like the looks of that set. Not to pull bearings, but to use as different bearing size press plates for my press!
Re: Moog wheel bearing and knuckle assy [Re: eljefino] #5352217 02/16/20 10:20 PM
I
OP Online Content
I
Hmm... I didn't even consider the alignment aspect.Thanks for the insight. I think I'll stay away from the Moog's on your recommendation.
Didn't think of this either. I'll have a look around locally and see what I can find.
Thanks everybody!!!
cheers
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5352253 02/16/20 11:14 PM
spasm3 Offline
Spindle route is a good idea, or call some machine shops, and ask what they would charge if you bring the knuckle and new bearing.
Re: Moog wheel bearing and knuckle assy [Re: spasm3] #5352275 02/17/20 12:00 AM
Chris142 Offline
$40 here.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Moog wheel bearing and knuckle assy [Re: spasm3] #5352318 02/17/20 03:43 AM
B
Black_Thunder Offline
B
this is a route I have done and usually only costed about 30 to 35 bucks at the carquest/advance auto machine shop, depends what labor is these days or the area but agreed I don't think it would exceed 40 dollars
also you don't need a replacement hub as it can be be pressed into the new bearing.
looks like you can get just the bearing for 30 to 40 bucks, so the whole process of taking the spindle off and to the machine shop etc shouldn't exceed 100 bucks.
I'd buy Callahan autoparts if I could.
Re: Moog wheel bearing and knuckle assy [Re: eljefino] #5352332 02/17/20 06:02 AM
Spktyr Offline
I am doing this with my Toyota 4Runner - going to have those salvaged spindles rebuilt with new seals and bearings, then install them. I also currently have all the front control arms pulled from a junked 4Runner that I'm having rebushed because of bad experiences with recent Moog and other aftermarket control arm assemblies.
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5354777 02/19/20 07:06 PM
I
OP Online Content
I
OP here. So here's an update on what I decided to do.
Forum member Eljefino suggested that I look for junkyard spindles.
I started looking around and found spares from a 2008 Camry at a yard about an hour away.
The car had been hit in the rear and totaled with only 21,000 miles on it.
I ended up grabbing both the right and left spindles for $50 each.
So for a grand total of $107 I ended up with the following, all OEM parts:
Steering knuckles
Wheel bearing and hubs
Ball joints
When the bone yard pulled them, they just yanked the CV joints apart.
Had I known, I would have gladly payed for both axles and just put them on the shelf.
Anyway, I just wanted to thank the members here, especially Eljefino for the junkyard suggestion and Trav for steering me clear of the Moog parts I was originally looking at.
Cheers!!!
cheers
[Linked Image]
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5355258 02/20/20 09:58 AM
M
MarkM66 Offline
M
That is strange they pulled the axles like that. You'd think those would be sell-able too.
Re: Moog wheel bearing and knuckle assy [Re: Imp4] #5355346 02/20/20 11:16 AM
F
Farnsworth Offline
F
Junk yards can be a great place to get parts. I must be a nightmare for a large company like MOOG to have people saying things about their parts. If a MOOG part isn't fitting it likely is a counterfeit. Here is a video I saw and it is too wordy but I think it represents what is going on out there.
https://www.youtube.com/watch?v=OpDJNDb6b9A
