Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
64 registered members (4WD, atikovi, 53' Stude, Amkeer, Astro14, 5 invisible), 1,033 guests, and 18 spiders.
Topics303,303
Posts5,233,548
Members71,038
Daytona 500 engine related question #5352115 02/16/20 08:37 PM
O
OilUzer Offline OP
O
I was watching Daytona 500 and one or 2 of the cars were steaming a little at one point.
1-
One of the announcers said not much air is getting in since they are drafting ...
I can understand this one.
2-
Later another guy said they tape off the grill or parts of it to go faster.
Is this for aerodynamics or for keeping the engine hot? it kind of contradicts #1
3-
Later they said the temperatures are dropping so the cars would be able to go faster.
Does this have to do with tires and the track and/or increased amount of oxygen? otherwise colder air is denser if we are talking aerodynamics and cooler engine temps (if any and/or significant) contradicts #2.
I can't connect some of the dots. Please help! LOL
Re: Daytona 500 engine related question [Re: OilUzer] #5352136 02/16/20 08:52 PM
M
mk378 Offline
M
Closing off the grille makes the car more aerodynamic. They tape as much as they can without overheating the engine.
Cooler air is denser, meaning there will be more mass of oxygen in the cylinders for a given pressure and volume. Since there is no turbo or supercharger, the engine has to operate at atmospheric pressure.
Re: Daytona 500 engine related question [Re: OilUzer] #5352191 02/16/20 09:43 PM
V
Vern_in_IL Offline
V
Yup, that's why a corn dog wrapper getting sucked onto the radiator will totally ruin your day as a driver. wink
Re: Daytona 500 engine related question [Re: OilUzer] #5352197 02/16/20 09:51 PM
J
JasonC Offline
J
Its that fine balance between just enough airflow and restriction. That is why you always see them cleaning the grille on every stop and either adding or removing tape. This new generation engine can withstand super high water temps much better than the older designs.
2012 Buick Verano 2.4
2006 Ford Mustang GT Convertible
Re: Daytona 500 engine related question [Re: OilUzer] #5352212 02/16/20 10:10 PM
M
MrHorspwer Offline
M
Great article with a bunch of video links about this very topic:
https://jalopnik.com/the-fascinating-reason-why-nascar-engines-run-so-hot-1835071544
Highlights:
Coolant temp is a product of how much air flows through the radiator and nothing else
Engines do not run a thermostat of any type
290 F is a totally normal coolant temperature; teams start pulling tape when coolant temps are above 300 F and adding tape when temps are below 280 F
Oil temps are 300+ F
Cooling systems are pressurized to 100 PSI
Qualifying is done with the radiator opening fully taped; 330 F during qualifying is typical
A cool down unit is plumbed to the car in between qualifying attempts to keep temps in check
Re: Daytona 500 engine related question [Re: OilUzer] #5352220 02/16/20 10:22 PM
RDY4WAR Offline
It's pretty crazy how they operate. The oil sump temp is ~280*F with a 60-75*F temperature rise through the bearings. The oil is a light 0w-20 / heavy 0w-16 (KV100 = ~7.5 cSt) that is mostly group III with a good bit of PAO/mPAO and POE to push the flash point higher and help it take the heat. It's also a low detergent oil (<500 ppm Ca) with Zn/P in the 800-1000 ppm range and Mo in the 1000-1800 ppm range.
The Sonny Bryant crankshafts for those engines is a true masterpiece. The machining is incredibly precise and smooth.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Daytona 500 engine related question [Re: RDY4WAR] #5352304 02/17/20 01:44 AM
sloinker Offline
I hear they run even lower viscosity oil for qualifying, only has to last a couple laps and from a near stone cold engine.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Daytona 500 engine related question [Re: sloinker] #5352362 02/17/20 07:17 AM
K
kstanf150 Offline
K
They may run an even lower viscosity oil for qualifying to gain a hp or two, but the engine they qualify with is same engine they race with. If they change engines then they start last. And also if you notice there’s a small cart looking box behind each race car while on pit road waiting to qualify, that’s a heater to keep the fluids up to normal operating range
Re: Daytona 500 engine related question [Re: OilUzer] #5352417 02/17/20 08:29 AM
K
krismoriah72 Offline
K
I havent watched NASCAR in awhile.. i used to enjoy it though. Are there even any chevy, ford, dodge or toyota parts on these vehicles or just sponsorship stickers?
Re: Daytona 500 engine related question [Re: RDY4WAR] #5352442 02/17/20 08:46 AM
G
Gebo Offline
G
Very interesting info. Thanks!
Do we know who makes their engine oil, transmission and differential fluid? Or the specs of the transmission and differential fluids?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Daytona 500 engine related question [Re: Gebo] #5352549 02/17/20 10:26 AM
RDY4WAR Offline
Driven supplies the oils and fluids for about half the field.
Re: Daytona 500 engine related question [Re: OilUzer] #5352564 02/17/20 10:41 AM
A
A_Harman Offline
A
1-
2-
3-
2. Lower aero drag from blocking off the radiator.
3. Lower track temperatures improves grip.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Daytona 500 engine related question [Re: MrHorspwer] #5352671 02/17/20 01:07 PM
FADEC Offline
Highlights:
Didn't know a lot of that!! Thanks for sharing!
Re: Daytona 500 engine related question [Re: krismoriah72] #5352772 02/17/20 03:02 PM
F
faltic Offline
F
wonder that myself
19 Tacoma 3.5 2wd AT. Under 3k
17 Highlander 3.5 2wd AT 20k+
19 Suziki S40 Boulevard 4 miles
07 EX250 21k+
11 PCX 125 5K+
Re: Daytona 500 engine related question [Re: faltic] #5353020 02/17/20 07:33 PM
bdcardinal Offline
wonder that myself
Certain body parts come from the manufacturers. The spoiler is a spec part from Richardson Racing Products. The Toyota engines are built by TRD, Ford engines by Roush Yates, and most of the Chevrolet engines by either Hendrick or ECR/RCR.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
