Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
19 registered members (FordCapriDriver, anndel, bachman, dishdude, bmod305, Char Baby, 1 invisible), 534 guests, and 17 spiders.
Topics303,255
Posts5,232,687
Members71,032
Ruger .22 SA - not a good show #5351898 02/16/20 04:48 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I’ve owned a Ruger Single six for a long while now. Took it out today along with a 6.5” S&W 617. Set a cheap target (garbage pull because it was minimally used and the diagonal opposite targets were unused) at 25yds. CCI mini mag round nose 40gr. Not good with the Ruger.
[Linked Image]
Then the 617.
[Linked Image]
Nothing to be proud of, but I did shoot about half DA, they all generally went where they should (it was a windy day fwiw).
It’s been almost a year since I had time to shoot. It was the second time with the 617, and I haven’t fired the Ruger in years. Both were cleaned and lined the same.
I know I can get good groups with my M1917, 686, 15-3. I’m most practiced with the M1917 and can hit all in the small circle on that type of target, at my outdoor range, with consistently in reasonably tight groups, running Federal Syntech. I use that as a basis because it has similar (not very good) sights to my Ruger. All of this is standing freehand too, fwiw.
The grip is obviously different... is the Ruger suspect or am I?
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5351903 02/16/20 04:52 PM
Astro14 Offline
Some of the .22 revolvers that have convertible cylinders (like our Single Sixes) don’t do well at all with .22LR... The bore is a thousandth or two bigger to allow 22 magnum, so they often do much better with .22 Mag.
Try it with the magnum cylinder and magnum ammo. I think you’ll see a big difference in accuracy.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5351922 02/16/20 05:06 PM
justintendo Offline
you can never judge any .22 from one type of round. all 22 rimfires have preferences, and some are downright picky. standard velocity should always be used for trying to get accuracy, unless you have a reason for using high velocity, usually hunting or pest control.
of course the single action ruger has a much different grip that most pistols..and i would bet that s&w has a nicer trigger.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5351936 02/16/20 05:15 PM
H
HangFire Offline
H
Try different ammo. MiniMags are rarely the most accurate round.
Various musings: http://hangfire.net
Re: Ruger .22 SA - not a good show [Re: Astro14] #5351952 02/16/20 05:30 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I recall reading about that long ago. Great idea, thanks!
Re: Ruger .22 SA - not a good show [Re: justintendo] #5351953 02/16/20 05:31 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Yeah, it was literally a half-used 100 round box I had sitting in my trunk for a while. Got it.
I’d actually like to try the poly-coated 22LR.
Re: Ruger .22 SA - not a good show [Re: Astro14] #5351962 02/16/20 05:38 PM
spasm3 Offline
I have the same issue with the novelty heritage arms.22 with the 16 inch barrel. It is high and right with .22lr. I'm going to buy the 22wmr cylinder for it.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5351968 02/16/20 05:45 PM
Slick17601 Offline
If you want accurate ammo, forget the poly coating. Get yourself some standard velocity. 22
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5351972 02/16/20 05:47 PM
CourierDriver Offline
Set your targets at 7 yards, you will do fine...
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
Re: Ruger .22 SA - not a good show [Re: CourierDriver] #5352058 02/16/20 07:23 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I can shoot fine at 7 yards. But I’d like to work on skill at longer distances.
Re: Ruger .22 SA - not a good show [Re: Slick17601] #5352068 02/16/20 07:30 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
The blue poly coated is 1070 FPS, same as standard velocity. Supposedly much cleaner.
I heavily use Federal Syntech for 9/45 and am a believer.
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5352090 02/16/20 07:57 PM
Z
ZeeOSix Offline
Z
What's the barrel length on the Ruger Single Six? Shorter sight radius perhaps?
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5352341 02/17/20 06:20 AM
M
Mainia Offline
M
The Ruger looks like it has a 25lb trigger pull.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Ruger .22 SA - not a good show [Re: JHZR2] #5352351 02/17/20 06:49 AM
demarpaint Offline
Trigger pull and the ammo play a big part of it with that gun. You're going to have to experiment a bit.
God Bless Our Troops
Re: Ruger .22 SA - not a good show [Re: Mainia] #5352450 02/17/20 08:51 AM
Astro14 Offline
It's single action - so, I'm guessing it's a bit below that...
Mine breaks at about 2-3 lbs (never put a scale on it). Very easy pistol to shoot accurately.
I suppose that I got lucky with my Single Six. At ten yards (my usual pistol shooting range), it prints about 3/4" groups with regular .22 LR ammo. A couple of cylinders of shooting, and there is just a ragged hole where the bullseye used to be. One of the things I like about that little pistol (aside from the fact that it was a gift from Mrs. Astro) is how accurate it is.
32 Packard 15W40
05 MB S600 0W40 M1
