Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
61 registered members (53' Stude, 4WD, Amkeer, Astro14, 1foxracing, 5 invisible), 987 guests, and 20 spiders.
Topics303,303
Posts5,233,548
Members71,038
Generator Hour Meter #5351793 02/16/20 02:44 PM
spasm3 Offline OP
My toro zero turn mower has an hourmeter, soI decided to add a meter to my small generator. It only has about 7-8 hours on it. That way i won't for get how many are on it , and i can jot down hours and the oil change. I ran the wire around so its not on the muffler, used some gray double sided tape to attach. About $13 on amazon.
I also added a magnetic dipstick. I ran this about 10 minutes or so, and there was a bit of ferrous coating on it. Since there is no filter on this little 4375 until, I think its a good idea.
The only down side is the dipstick is aluminum, and will get hotter than the plastic dipstick. I generally check it before startup anyway. This unit has low oil shut down, so I don't see a problem, unless you forget and grab it hot!
IMG_20200216_142653883.jpgIMG_20200216_142657166.jpgIMG_20200216_142704195.jpgIMG_20200216_143003567.jpgIMG_20200216_143028532.jpgIMG_20200216_142750107.jpg
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Generator Hour Meter [Re: spasm3] #5351881 02/16/20 04:34 PM
J
JohnG Offline
J
I like it!
I'm a fan of magnetic drain plugs, and usually make my own out of those STRONG little magnets that i scrounge up from various things. Neodium? Never thought of putting one on a dipstick though.
Have you determined when you are going to change your oil based on the hour meter yet?
Honda has some pretty good recommendations regarding fuel storage for generators on their website, maybe they have some oil change suggestions as well.
Re: Generator Hour Meter [Re: JohnG] #5351892 02/16/20 04:43 PM
spasm3 Offline OP
Originally Posted by JohnG
I like it!
The manual says every 20hrs, but the predator 3500 with the same engine and similar oil capacity says 100hrs. The same engine sold as a stand alone engine states every 20, 100, 300 hrs. So something got lost in translation on the predator stand alone engine.
I'm running amsoil HDD 5w 30 in mine. I feel comfortable doing 50hrs. 100 might be fine with the high quality syn, but again there is no filter and the sump is 0.6 quarts, so i'll go 50hrs.
Re: Generator Hour Meter [Re: spasm3] #5352063 02/16/20 07:28 PM
J
JC1 Offline
J
I bought a cheap hour meter from Ebay for my snowblower. Was less than $6 CDN. Worked so well I bought another one for the lawnmower that I will install this spring.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Generator Hour Meter [Re: spasm3] #5352898 02/17/20 05:11 PM
A
Astro_Guy Offline
A
Is there a way to set the initial hours one one of these? In other words, if you have an enstimated 50 hours on a machine, is there a way to start from 50?
'01 Volvo V70XC, 251k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Generator Hour Meter [Re: Astro_Guy] #5353027 02/17/20 07:46 PM
spasm3 Offline OP
I found some re settable ones, but not ones you could input some hours. My new little generator only has about 10 hours before adding the meter.
Re: Generator Hour Meter [Re: spasm3] #5353376 02/18/20 05:53 AM
dlundblad Offline
To increase hours, you could possibly install it on a push mower or car to speed up the hours. Not sure if the latter is possible though.
I’ve though about getting one for my Honda powered log splitter since I have no idea on the hours. The digital ones are nice, but they could literally fail at any given time and lose the hour count. Then again, with what they cost, it’d nearly pay for itself by preventing premature oil changes.
It’d help to keep an eye on it of course, but also in the event of a failure, you’re back to square one in terms of catching it up to the actual hours.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Generator Hour Meter [Re: spasm3] #5353706 02/18/20 03:10 PM
sw99 Offline
That was the first thing I did to my Predator 5500/6500 also. I had to look twice I thought that was mine at first glance. Nice job!
Re: Generator Hour Meter [Re: spasm3] #5353710 02/18/20 03:15 PM
K
kschachn Offline
K
This one appears to allow it:
https://www.amazon.com/Runleader-Tachometer-Maintenance-replaceable-Generator/dp/B0811MB9KV
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Generator Hour Meter [Re: spasm3] #5353983 02/18/20 09:43 PM
Z
ZebRuaj Offline
Z
I have one laying around in the tool box. Used it to check rpms of the freebie mowers I pick up to flip tho. Quick and easy way to check.
~I fix stuff.
Re: Generator Hour Meter [Re: spasm3] #5354040 02/18/20 10:48 PM
M
motor_oil_madman Offline
M
I have your meters on everything that needs an oil change. Otherwise I wouldn't be able to keep track.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Generator Hour Meter [Re: dlundblad] #5354056 02/18/20 11:25 PM
spasm3 Offline OP
Yes you would lose original hours with mine. I was adding it to keep up with the hours on each oil change , so i don't for get.
Re: Generator Hour Meter [Re: kschachn] #5354057 02/18/20 11:26 PM
spasm3 Offline OP
Nice! I did not see that one! It says you can preset hours! The nice thing too, is you can replace batteries. Mine is just doa when the sealed battery dies. Wish i had gotten the one you posted.
Re: Generator Hour Meter [Re: spasm3] #5354253 02/19/20 09:24 AM
Duffyjr Online Content
Online Content
Does anyone know if you can extend the wire, most of them seem to come with 43 inches which isn't enough the way I would want to mount it on a mower. I can't see any place on the engine or deck that would work due to all the bushes I mow around, I'm sure it wold get ripped off so I want to mount it up on the handle.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Generator Hour Meter [Re: Duffyjr] #5354464 02/19/20 01:03 PM
A
Ausfahrt Offline
A
Just hook a small 2amp charger to the leads. I did that for three days to approximate the 72 engine hours on my generator.
'14 Subaru Crosstrek MT 70k
'15 Tacoma 4x4 MT 30k
'03 Camry AT 148k
'07 BMW R1200GSA 71k
'98 Electra Glide 52k
