Originally Posted by Chris142
Like I said maybe 50 miles max on the oil.
Does time effect the oil filter in any way? Make the paper brittle?
No, the oil is NOT bad after 50 miles, even if it has been two years.
All of the guys saying "Change it!!!" can assuredly provide *ZERO* evidence whatsoever that the oil is no longer perfectly fine.
Oil filters do NOT go bad from age, or at all under "normal" use. I have some larger (4 cyl gas) OPE that still has the same oil filter for 10 years now.
