Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
56 registered members (4WD, Amkeer, Astro14, 1foxracing, 53' Stude, 5 invisible), 928 guests, and 20 spiders.
Topics303,303
Posts5,233,545
Members71,038
Page 1 of 3 1 2 3
Removing mold from washing machine door seal #5351597 02/16/20 11:08 AM
grampi Offline OP
We have a front load washer and the rubber ring door seal has mold on it. Where it is has turned that portion of the seal black. I have scrubbed it with a green scrubby pad and bleach, but the black doesn't come off. It appears to have permanently discolored the rubber. I'm wondering if scrubbing it with the bleach would have killed off the active part of the mold, the part that's bad for us, and the black that's still there is now just a harmless stain.
Re: Removing mold from washing machine door seal [Re: grampi] #5351604 02/16/20 11:12 AM
A
ArcticDriver Offline
A
I have researched this topic and my layman opinion would be that the active mold is killed by the bleach; however, the mold spores could also be in other locations within the washer obscured from view. I have even removed the rubber door seals for cleaning.
Multiple Diesel and Gasoline vehicles
Re: Removing mold from washing machine door seal [Re: grampi] #5351621 02/16/20 11:31 AM
KJSmith Offline
You can always replace the seal.
They tear and leak after awhile.
Re: Removing mold from washing machine door seal [Re: grampi] #5351630 02/16/20 11:38 AM
M
Mainia Offline
M
Go to the appliance discount online stores and order one up. One or two of the big stores have videos on how to do it. You will just have to spend time finding the seller who does that video. It is an easy replacement.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Removing mold from washing machine door seal [Re: grampi] #5351661 02/16/20 12:07 PM
M
Mad_Hatter Offline
M
The bleach killed all living mold, what you're seeing is harmless discoloration from the mold. Better question is, why is your seal molding?
Re: Removing mold from washing machine door seal [Re: grampi] #5351686 02/16/20 12:28 PM
J
JC1 Offline
J
It takes some time for the mold to get scrubbed off.
What I've done is run the washer on high heat with 1 cup of bleach thrown into the machine. Then I've taken wet rags that were soaking in bleach and put them around the rubber ring and let them stay there for a while to loosen stuff up.
You can also used powdered detergent and scrub the rubber to get it off. This should be done when the rubber gasket is wet.
Going forward make sure you leave the door open more than a crack to get that gasket dried out between uses.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Removing mold from washing machine door seal [Re: grampi] #5351690 02/16/20 12:33 PM
M
Mad_Hatter Offline
M
Isn't borax a natural fungicide? (it's actually a detergent booster as well by softening the water, I believe).. If I'm right maybe adding some in a wash cycle every now and then might be worth a try. A box of 20 Mule isn't too expensive. But airing it out is probably the cheapest (free) tried and true approach to controlling it.
Re: Removing mold from washing machine door seal [Re: grampi] #5351702 02/16/20 12:45 PM
U
user52165 Offline
U
Another reason to not buy a front load model.
Re: Removing mold from washing machine door seal [Re: grampi] #5351713 02/16/20 01:06 PM
JohnnyJohnson Offline
On a front loader you will greatly reduce this problem if after you empty the washer you leave the door open and let it dry out.
2004 Corolla 139577
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Removing mold from washing machine door seal [Re: JohnnyJohnson] #5351722 02/16/20 01:15 PM
K
kstanf150 Offline
K
Amen 👍
Re: Removing mold from washing machine door seal [Re: grampi] #5351725 02/16/20 01:19 PM
H
hallstevenson Offline
H
Bleach isn't a "cleaner". Clean the soil with a detergent and scrub if you want, then apply bleach to kill any exposed bacteria, mold, etc. The bleach should remove the stain as well but might take a while.
Re: Removing mold from washing machine door seal [Re: grampi] #5351780 02/16/20 02:27 PM
R
RazorsEdge Offline
R
There's tutorials online for removing the mold, etc.
For preventing mold, etc. I run a combination of baking soda in the drum of the washer with vinegar in the dispenser. Run this combo with hot water once a month.
I don't have any problems using this method. Leave the door open a crack after washing your clothes also.
2cents
Schaeffer Oil 👍😎
Re: Removing mold from washing machine door seal [Re: user52165] #5351794 02/16/20 02:46 PM
X
xxch4osxx Offline
X
That was my first thought. Never understood the appeal of front loading washers.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Removing mold from washing machine door seal [Re: RazorsEdge] #5351797 02/16/20 02:52 PM
M
Mad_Hatter Offline
M
2cents
Baking soda and vinegar together, at the same time? Isn't baking soda a base and vinegar an acid? crzy
Re: Removing mold from washing machine door seal [Re: Mad_Hatter] #5351798 02/16/20 02:54 PM
R
RazorsEdge Offline
R
2cents
Nope, look it up it's a common method that's safe and effective.
Schaeffer Oil 👍😎
Page 1 of 3 1 2 3
