Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
82 registered members (bbhero, ArrestMeRedZ, 2009Caraman, alchargo, aquariuscsm, 3Dperf, 10 invisible), 1,635 guests, and 24 spiders.
Topics306,269
Posts5,289,342
Members71,616
2006 Accord electrical problem #5351482 02/16/20 09:12 AM
G
greenjp Online Content OP
OP Online Content
G
Wanted to see if you guys had any thoughts on a problem my 2006 Accord is having.
Occassionally (like a time or two a month) over the past several months, the car will momentarily lose electrical power if it's idling and the AC compressor kicks on. It doesn't happen all the time and I don't think it's happened when moving. The engine doesn't stop.
On Wednesday this week I left a light on and drained the battery, got a jump and it started right up and drove fine.
On Friday after I got home from work, went to switch cars with the wife and it was totally dead - 10 minutes after I had just driven it for 25 minutes. No lights or anything when turning the key. Jumped it and it started fine, then while sitting for a few minutes it shut down and again appeared totally dead.
I checked the battery with a multimeter and got 12.6v resting (I realize this doesn't necessarily indicate it's OK). A little while later I got in the car and the lights were back and it started up OK. 14v on the battery with the engine running. That was Friday afternoon and I haven't had to drive it since.
The car has 175k miles, the battery is a Bosch AGM that went in November '16 at 120k. The terminals and clean and the connections are tight.
The semi random totally dead behavior perhaps suggests there's some sort of intermittent connection problem? I imagine that would be hard to isolate. I thought about getting one of those $20 Harbor Freight analog battery testers.
Any ideas? Thanks,
jeff
Re: 2006 Accord electrical problem [Re: greenjp] #5351495 02/16/20 09:25 AM
ctechbob Offline
12.6 resting is low for an AGM. Have the battery tested, and check your body grounds. There should be one down under the battery that (if memory serves) continues on to the engine block.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 2006 Accord electrical problem [Re: greenjp] #5351506 02/16/20 09:35 AM
A
atikovi Offline
A
Check and clean battery cables and grounds.
Re: 2006 Accord electrical problem [Re: greenjp] #5351525 02/16/20 09:56 AM
W
whatnext Offline
W
Smells like a loose ground wire somewhere. Gonna be hard to find. Maybe the Honda forums can point to likely locations.
Re: 2006 Accord electrical problem [Re: greenjp] #5351527 02/16/20 09:57 AM
spasm3 Offline
If you jumped it and drove it, it still may need to be charged. I'm not convinced the stock charging system can fully charge a battery. I am not knowledgeable about AGM batteries, but i wonder if the 12.6 measurement was a surface charge. I would charge it with a separate charger.
Check the other ends of the battery cable, the one to ground and the one to the starter.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: 2006 Accord electrical problem [Re: atikovi] #5351544 02/16/20 10:09 AM
G
GSCJR Offline
G
+1
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: 2006 Accord electrical problem [Re: greenjp] #5351657 02/16/20 12:06 PM
L
Lasthope05 Offline
L
These cars have known charging issues stemming from the ELD. A faulty ELD will tell the ecu to turn off the alternator. Fixes are replacing the fuse box which houses the ELD,. Disassemble the fuse box and replace the sensor itself, bypass the ELD with a resistor to trick the ecu or depinning the white/green wire from the alternator plug to disable ecu control.
Re: 2006 Accord electrical problem [Re: greenjp] #5351680 02/16/20 12:22 PM
E
eljefino Offline
E
+6 on the grounds and cables.
Re: 2006 Accord electrical problem [Re: greenjp] #5353445 02/18/20 09:10 AM
G
greenfordtruck Offline
G
I have experienced a similar issue with my 2003 Accord. My problem was solved by replacing the alternator. Please save yourself time and frustration by using a remanufactured unit. Most rebuilt units are poor quality. If you have a local shop that specializes in remanufacturing alternators, please have them test it.
2017 Toyota Camry 2.5 0w20
2003 Honda Accord 2.4 5w20
2000 Ford F150 4.6 5w20
1969 Ford F100 360 10w30
Re: 2006 Accord electrical problem [Re: whatnext] #5353573 02/18/20 12:05 PM
W
WyrTwister Offline
W
I agree , sounds like a loose / intermittent connection . I also agree , check the grounds , every one you can find .
Wyr
God bless
Re: 2006 Accord electrical problem [Re: greenjp] #5355981 02/20/20 09:02 PM
Y
Yazmeister Offline
Y
I had a similar issue. For me it turned out to be corrosion build up in the positive cable under the wrap. Replaced the positive terminal connector and cut the cable back. I have read this is an issue with the positive cable on the Gen 7.5 Accords. Some owners just replace the positive cable with another OEM cable from the dealership.
2006 Honda Accord LX 2.4L (K24A8)
1997 Dodge Ram 1500 SLT 5.9L 4x4
1996 Chevy K1500 5.7L
2004 Buick LeSabre 3.8L
Re: 2006 Accord electrical problem [Re: greenjp] #5356114 02/21/20 12:36 AM
G
OP Online Content
G
Thanks for the feedback everybody, looks like I have several lines of investigation ahead of me. Fortunately it's been fine since the OP 'cause I've been driving all over the place for work this week.
jeff
Re: 2006 Accord electrical problem [Re: greenjp] #5364473 03/01/20 04:57 PM
G
OP Online Content
G
Been driving quite a bit for since the last post. I haven't had any problems, but it's failed to start for my wife twice. Once was a few days ago, she was out running errands and called to report that it was dead. I drove over to where she was, she was sitting in the driver's seat and as noted there were no lights or anything on. I had her hop out so I could get in and take a look. The moment I shut the driver's door, the lights all came back up and the car started fine. So that was weird.
Then on Thursday night, I get out of the car after a drive, hit the lock button on the key and the car does not respond. I open the door, no lights. Shut the door and hit the button again and it worked. Odd.
This morning my wife tries driving it and yet again it won't start for her. She tries the open and close the door trick and reports that the lights came on for just a moment when she shut the door but then were out and it wouldn't start. It was behaving normally and started just fine for me a couple hours later.
I suppose it's possible that something is loose that opening and closing the door has some effect on?
jeff
Re: 2006 Accord electrical problem [Re: greenjp] #5364497 03/01/20 05:32 PM
T
The_Eric Offline
T
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: 2006 Accord electrical problem [Re: greenjp] #5406764 04/18/20 07:53 AM
G
OP Online Content
G
Forgot to update this. Several weeks ago (pre-virus lockdowns) I gave the battery terminals and connectors a good scrub with a wire brush, also where the negative connects to the body. I think I put some dielectric grease over them and haven't had the problem recur since. So that must have been it.
jeff
