Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
33 registered members (Black_Thunder, alcyon, BlueOvalFitter, blufeb95, bachman, 928, 2 invisible), 1,406 guests, and 22 spiders.
Topics303,658
Posts5,239,293
Members71,106
Craftsman 4 ton floor jack #5351393 02/16/20 06:50 AM
M
mirvingm Offline OP
M
My Craftsman floor jack will not release the pressure to lower? I've investigated the internal parts looking for o-rings to replace? There are none. Yet? With most of the internal parts removed I still have to jump on the lift plate to get it to reluctantly go down?
I'm at a loss where to go from here? I've included pictures to help tell the story. The ATF was used to try to flush the system out? With no results.
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351413 02/16/20 07:40 AM
skyactiv Offline
With how dirty that jack is from leaking fluid and the fact you don't know how to fix it properly, take it to someone who can or throw it out.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351452 02/16/20 08:40 AM
J
JC1 Offline
J
Not sure how much you took apart based on your pictures.
Did you check Youtube?
https://www.youtube.com/watch?v=G3YimmBeRSw
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351569 02/16/20 10:34 AM
doitmyself Offline
Welcome to our asylum mirvingm from Chassel, MI. I spent a bit of time up there while at MTU and have some fond memories of Baraga, Lanse, and Alberta.
I would join up at Garagejournal.com tool threads and seek out the wisdom of a respected gentleman there that goes by the name of Hiball. He rebuilds jacks for a living.
Stay warm!
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351574 02/16/20 10:44 AM
Donald Offline
Have you cleaned all the dirt & grime off the areas of the jack that move and then lubed them? Maybe it's just binding a bit and needs to be cleaned & lubed.
2015 Ford F-250 w/Powerstroke
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351598 02/16/20 11:08 AM
P
philipp10 Offline
P
One of two things. Either a mechanical binding or the hydraulic valve is not allowing fluid to drain back. And I don't agree it needs to go in the trash pile. It does however probably need new seals with all the leaking that looks going on.
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351631 02/16/20 11:39 AM
KJSmith Offline
A long body jack like that is very expensive to replace.
If you can't fix it, find somebody who can.
https://www.hcrcnow.com/shop/seal-kits/craftsman-sears
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351645 02/16/20 11:56 AM
F
Farnsworth Offline
F
Nice links in thread. You may have a USA made Walker jack. Worth fixing. May be a clogged bleeder circuit. Holding steady is better than coming down. Something like this new is probably over $500 and it’s only assembled inUSA with some USA parts and some fromChina.
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351650 02/16/20 12:01 PM
W
Wolfshead Offline
W
Try to save it,Many will direct you to Harbor Freight for their Asian Junk !
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351709 02/16/20 01:01 PM
K
Kira Offline
K
Friend went to automotive school.
A friend of his had a Dad who worked in a bus garage.
The Dad alerted the guys that there was a BIG (10 ton?) floor jack in need of repair.
Friend rebuilt it and welded cracks in the body.
He said, "Don't paint it. Let people see that it's repaired".
Soon thereafter the jack was painted and back in service.
It really twisted my friend up. He wanted to hit an alarm but......
Re: Craftsman 4 ton floor jack [Re: mirvingm] #5351855 02/16/20 04:00 PM
Yah-Tah-Hey Offline
Probably bound up mechanically from lack of maintenance over ?? years. Start with the two main pivot points shown in #3 photo. Too nice of jack to throw away. You can't purchase a jack like that today without spending big bucks.
Re: Craftsman 4 ton floor jack [Re: JC1] #5352353 02/17/20 06:51 AM
M
mirvingm Offline OP
M
Completely different hydraulics on mine. I did watch it. Thanks.
Re: Craftsman 4 ton floor jack [Re: Yah-Tah-Hey] #5352355 02/17/20 06:54 AM
M
mirvingm Offline OP
M
I have greased the main pivot points on the handle pump side of the jack.
Re: Craftsman 4 ton floor jack [Re: skyactiv] #5352357 02/17/20 06:58 AM
M
mirvingm Offline OP
M
The fluid is from dumping out the old oil. It has no leaks.
