Originally Posted by Dave1027
I don't see how that Gumout Regain can work. With an engine running, the stuff would simply blow right by the valves and the rushing air would dry off any small amount of solution that happens to hit the valve surface. Much more solution would hit the catalytic converter
If you do a little research you'll find plenty of documentation that shows the product works quite well.
