Originally Posted by blupupher
Originally Posted by Ws6
Haven't vehicle manufacturers solved this years ago? I put 100K on my CX5 (DI) and had zero issues with carbon. Others have 2-3x as many miles. Runs fine. Older engines, it's just a known thing that walnut blasting is the only way to truly clean them.
No it is not solved (especially in TGDI applications, but SN+ helps some).
And if you use the cleaners regularly, ideally there will be no need for walnut blasting.
I have a can of the CRC cleaner sitting in my garage right now for my mom's '18 Kia Soul with just over 25,000 miles. Since hers is non-turbo DI, I was going to do it at 30,000 miles, then every 20,000 after that.
Same plan for my Santa Fe with just over 20,000 miles on it right now.
I am not overly concerned since I have not heard much of issues with these motors (H/K 2.0 Nu GDI and 3.3 Lambda II GDI) and carbon build up on the valves, but won't hurt to use it IMO.
I guess in t he hundreds of thousands of miles it takes for this to be noticeable, I'll probably be okay paying a few hundred bucks for walnut blasting then. My last DI car went 106K miles with zero alteration to performance or fuel economy. It wasn't turbo DI though, but at 30K now on my turbo DI with zero issues, will keep it in mind I guess. Those spray cans won't do much. I've seen cylinder scope vids of the before/after on some old VW engines I think, and it was very "meh".
