Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
110 registered members (1978elcamino, 2015_PSD, 4WD, 53' Stude, 07titan, 007, 12 invisible), 1,988 guests, and 17 spiders.
Topics303,501
Posts5,235,295
Members71,063
What thickness is Aluminum Beam for Wind Load 170mph? #5350047 02/14/20 04:07 PM
H
henni Offline OP
H
Can someone familiar with aluminum beam strength tell me, how thick is a beam rated for wind load strength at 170mph ?
This is a question for an outdoor aluminum frame with screens.
In reading the code requirement, I see the following "////...designs need to be able to support wind loads of 170 MPH Exposure “C” category II...."
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350076 02/14/20 04:43 PM
PimTac Offline
There is more to it than just thickness. At 170 mph don’t expect much anything to hold up.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350095 02/14/20 05:05 PM
R
ragtoplvr Online Content
Online Content
R
Aluminum is used on air planes, so a design in aluminum that can withstand the wind level you talk about can exist.
You did not supply any information, leading me to conclude you think this problem is trivial. It is not.
First you have to state the problem clearly, size, height etc. then you probable need to hire a certified structural engineer.
The force level depending on size can be considerable, like many tons in some cases. You may even need to study the ground to determine an appropriate attachment method.
Rod
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: ragtoplvr] #5350126 02/14/20 05:45 PM
E
eljefino Offline
E
Anyone who answers this who isn't an engineer is a fool.
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350130 02/14/20 05:48 PM
H
henni Offline OP
H
Not a trivial issue at all. Local building code for outdoor aluminum frames have evolved since last years hurricanes and I am in the process of shopping for new frame material with a plan to replace existing outdoor structure. Incidentally, it has withstood wind gusts up to 160 mph and not sustained any damage but it is 40 years old.
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350238 02/14/20 08:31 PM
P10crew Offline
24” section height. 1” web thickness. Wide heavy flanges. 6061T6 popcorn2
I got nuthin!
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350249 02/14/20 08:38 PM
sloinker Offline
.Re-read your post and realized I was answering, poorly, a different question than you were asking.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350395 02/15/20 12:15 AM
samven Offline
You will have to give all the particulars to an engineer to get a real answer. 1"x1/4" aluminium bar stock fastened to concrete with fibreglass screening will survive but the screen will be gone. I am not so sure it would survive with good sail stock stretched across it though.
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350613 02/15/20 09:41 AM
tom slick Offline
There is not enough information in your post for anyone to give you an answer. We don’t know what you are building, what size it is, what materials you are using...
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5350620 02/15/20 09:50 AM
A
Amkeer Offline
A
See a structural engineer. At 160 MPH winds that is some serious stuff.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 101000
2008 Toyota Tundra D Cab 5.7 M1 5-20 98000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 214000 miles
2014.5 Toyota Camry SE 2.5 M1 0-20 72000
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5351076 02/15/20 08:07 PM
M
madRiver Offline
M
I am schooled as structural engineer and if I understand your question what size aluminum to hold a screen. Seems more like aluminum supporting it self as 170 MPH wind would simple destroy the screen or rip it.
Am i reading this right?
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5351584 02/16/20 10:57 AM
H
henni Offline OP
H
Nothing new is being built. Existing 40 year old outdoor aluminum frame will be replaced by new standard aluminum.
Note that I did not ask anything about screens and do not care at all about screens. Multiple wind events in excess of 160 mph with wind gusts exceeding 200 mph have come and gone and old structure is just fine.
Replacing it despite all this "old strength" to match current standards of outdoor aluminum beams.
[Linked Image from i.postimg.cc]
Re: What thickness is Aluminum Beam for Wind Load 170mph? [Re: henni] #5351648 02/16/20 11:58 AM
M
madRiver Offline
M
Are you planning on doing DIY ? There may be some tables and charts to cover off the sizing from aluminum frame maker or the supplier has some software to help them out.
Good luck.
