Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
33 registered members (bbhero, blufeb95, ArrestMeRedZ, carlprop, Black_Thunder, 5 invisible), 1,013 guests, and 24 spiders.
Topics301,684
Posts5,200,458
Members70,756
need help ordering metric wheel nuts #5350299 02/14/20 08:42 PM
CNT Offline OP
[Linked Image]
I need 5 new nuts for my car (1 each rim, 2 on photo one). I just want to make it look nice with all nuts same, the rust ones make it stand out. I couldn't find the exact nuts on local retailers, nor on amazon.com. As in photo, the nut cover says "METRIC I", where would I find those? Junk yards? The car manual doesn't say what thread size it is.
Re: need help ordering metric wheel nuts [Re: CNT] #5350307 02/14/20 08:50 PM
L
Lapham3 Offline
L
Ebay and Amazon have lots of sellers.
Re: need help ordering metric wheel nuts [Re: CNT] #5350314 02/14/20 08:58 PM
V
Vercingetorix Offline
V
Re: need help ordering metric wheel nuts [Re: CNT] #5350322 02/14/20 09:11 PM
W
WhyMe Online Content
Online Content
W
seems like its better to just get a whole new set. they are cheap
https://www.ebay.com/itm/20-Bulge-Acorn-Wheels-Rims-Lug-Nuts-12X1-5-Closed-End-Chrome-3-4-Hex/262311968147?fits=Model%3AToronado%7CMake%3AOldsmobile&hash=item3d1302fd93:g:csoAAOSw481dWZ6p
Re: need help ordering metric wheel nuts [Re: WhyMe] #5350339 02/14/20 09:35 PM
CNT Offline OP
Ture. Online ones are cheaper for sure. Local retailers are like $35+ for a set. That link you provide looks OK. I just thought to get the same matching nuts, but I can do the whole set, done once. Thanks for specific search (91 Toronado). I will look around online some more... if nothing else, I may order that link. Thanks again.
Re: need help ordering metric wheel nuts [Re: CNT] #5350350 02/14/20 09:44 PM
W
Online Content
W
i would bet those metric marked ones are not even original to the car. yeah just get the whole set.
Re: need help ordering metric wheel nuts [Re: CNT] #5350364 02/14/20 10:00 PM
bdcardinal Offline
McGard 84537 looks like a good kit too.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: need help ordering metric wheel nuts [Re: CNT] #5350374 02/14/20 10:27 PM
CNT Offline OP
WhyMe, those of the link you provide, are those solid one-piece nuts? Not "chrome covered" that become loose and fall off (as those rusted one are)? They looks solid to me, but need to ask. Also, they are not smooth shining, but that doesn't concern me for this car.
Re: need help ordering metric wheel nuts [Re: CNT] #5350404 02/14/20 11:27 PM
W
Online Content
W
reading the description it seems like they are solid
Lug nuts have two compatibilities, one to match the lug nut thread size to the vehicle's wheel studs and the other to match the lug nut style to the wheel. eBay's compatibility tool is used to match the thread size of the lug nut to the vehicle's wheel studs, it does not match the lug nut style to the wheel. Make sure you have chosen the correct style prior to placing an order, ask if you have any questions.
This style of lug nut is generally used on aftermarket wheels with exposed lug nuts that require a standard size conical seat lug nut.
Does not work with factory/OE wheels where the center cap, hub cap or wheel cover is held in place by the lug nut.
Made from Through-Hardened steel with a chrome plating.
Does not have a cosmetic sleeve over the lug like some factory versions
Re: need help ordering metric wheel nuts [Re: WhyMe] #5350442 02/15/20 02:21 AM
CNT Offline OP
Quote
Oh?
Quote
Isn't that all that matters?
Quote
Such as? "Style" as how it looks, nothing to do with its' function? Like the nuts on the Toronado, it says "METRIC I", is that the "style" also? FWIW, I think those nuts that are there now looks good (it doesn't have ordinary "extend" convex cap), it's more of concave looking and somewhat clean looking. Can you explain to me what you mean by this (the ebay link you provided) is not the style for this Toronado wheel?
I understand sometimes need to consider TYPES of lug nuts, closed caps (show offs) vs open exposed (use with wheel covers, center caps, etc).
Correct me with terminology:
LENGTH (don't want the bolt to hit inside the cover cap)
BULGE (the fat at the "V" part), it's something nice to have, but not required? The regular lug nut (w/o bulge) also have 60°, same as bulge 60°. The bulge would make it "stronger" since it's overly larger covering more metal of the rim holes. Correct?
CAP (the end covering of the bolt), mainly for cosmetic. Would also help prevent rust since no water/salt can reach the inside bolt. Correct?
SOLID vs COSMETIC SLEEVE
any other terminology? I don't know why I am going into this, oh well? I thought a nut is a nut (except locknut), a lug is a lug? I did look in the sticky thread, there is a broken link in there and does not have terminology definitions.
As I read, now people are starting to say NOT to put grease on the bolt when putting on the lug nut (to help prevent rust and help easier removal later). Because it would cause it to roll out? Even after 100lbs torque wrench?
FWIW, I am looking into buying this LINK and still have to yet buy a (probably Craftsman) 1/2" torque wrench!
Re: need help ordering metric wheel nuts [Re: CNT] #5350452 02/15/20 02:53 AM
F
FT92 Offline
F
why not go to a local tire shop ..they usually have or can get them for you...although the price might be a bit higher
Re: need help ordering metric wheel nuts [Re: CNT] #5350473 02/15/20 04:22 AM
L
Lapham3 Offline
L
I've found that the McGard product line is superior as they are very hard and the chrome is well done and doesn't chip loose. Some nuts look good new but don't age well. For recessed wheels such as yours, I've also used their splined nuts rather than hex. Good luck.
Re: need help ordering metric wheel nuts [Re: Lapham3] #5350592 02/15/20 08:21 AM
CNT Offline OP
https://www.ebay.com/itm/LUG-NUTS-SMALL-DIAMETER-TUNER-SPLINE-ACORN-12x1-5-CHROME-20-PIECES/260727959992?fits=Year%3A1991%7CModel%3AToronado%7CMake%3AOldsmobile&hash=item3cb498f1b8:g:COUAAOSwbv9d-Tnn:sc:USPSPriorityMailSmallFlatRateBox!53005!US!-1
Re: need help ordering metric wheel nuts [Re: CNT] #5350599 02/15/20 08:32 AM
Silverado12 Offline
I have McGard nuts on my Mustang and they are very well made. Not too expensive either; I think I paid 30 bucks or so for a complete set.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: need help ordering metric wheel nuts [Re: CNT] #5350710 02/15/20 10:22 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
www.ezaccessory.com
I've bought from them before.
