Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
66 registered members (bullwinkle, Astro_Guy, 2002 Maxima SE, 4WD, Bailes1992, 6 invisible), 1,446 guests, and 18 spiders.
Topics301,732
Posts5,201,619
Members70,766
2018 Odyssey 5w20? #5350280 02/14/20 08:24 PM
J
Jake777 Offline OP
J
Hi everyone. Wanted to get some thoughts. I have a 2018 Honda Odyssey and started to get concerned about long term DI issues. I’m considering using QSUD 5w20 for its PQI tested 7.1 noack results. Am I correct in assuming there is little to no difference using 5w20 in place of 0w20 as long as it’s a full synthetic? Or is there some flow issue where 0w must be used due to hydraulic purposes like VVT and or VCM systems. Any factual / functional differences between full synthetic 0w20 and 5w20?
2018 Honda Odyssey EXL
2015 Honda Accord
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350285 02/14/20 08:27 PM
P
parshisa Offline
P
No worries at all running it in florida. I’ve got plenty of 5w20 that i’ll be running in my ‘16 pilot with the same engine you have. Currently have 5w30 0w20 pennzoil mix (leftovers) and runs just as fine as 0w20
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350286 02/14/20 08:29 PM
J
JeffKeryk Offline
J
I doubt your engine will know the difference between 0w20 and 5w20 oils.
My understanding is fuel dilution is only an issues for cold weather climates and vehicles driven short distances only.
Good luck with your Odyssey.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350295 02/14/20 08:39 PM
A
ARB1977 Offline
A
Our 19 Pilot with the same engine is using Amsoil SS 0W20. Rather have this engine than the 1.5LT we had in our beloved 18 CRV.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2018 Odyssey 5w20? [Re: parshisa] #5350298 02/14/20 08:42 PM
J
Jake777 Offline OP
J
Thanks. I need to update my sig I’m now in western NC but the coldest it gets here is maybe 10 degrees and only for a few hours early in the morning. Anyway how many miles do you have on the Pilot? I love the van but like I said I was afraid of keeping it long term with all the horror stories about DI engines.
Oh also no worries about using 5w30 even with the oil being used like a hydraulic fluid for activating the VCM and valve timing? I guess not if you have been using it.
2015 Honda Accord
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350303 02/14/20 08:45 PM
B
blufeb95 Offline
B
Since it's an 18, I'm guessing it's still under warranty, so while 5w20 should do no harm, I'd stick with 0w20 because that's what the only oil the manual specifies and it's best the follow what the manual says just in case you have to make a warranty claim.
Re: 2018 Odyssey 5w20? [Re: blufeb95] #5350308 02/14/20 08:51 PM
J
Jake777 Offline OP
J
Good point on the warranty. Ya [censored].
2015 Honda Accord
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350320 02/14/20 09:07 PM
P
parshisa Offline
P
It has roughly 38K. Oil change every 4k or so, it’s being short tripped a lot. And no, not an issue with it (knock on wood) and it doesn’t care for higher grade, run the same if not better
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350359 02/14/20 09:54 PM
J
jayjr1105 Offline
J
Unless you live in Siberia, the more important number is the one on the right. I don't know that the DI V6's have fuel dilution issues. 5w20 or 0w20 and you're fine.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: 2018 Odyssey 5w20? [Re: Jake777] #5350506 02/15/20 06:34 AM
T
Triple_Se7en Offline
T
Pedal to the freeway-floor on occasion (short spurts) and run CRC Intake Cleaner spray every 10-15k. Best to stick with SN Plus / Dexos 1-Gen2 oils.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: 2018 Odyssey 5w20? [Re: Jake777] #5352206 02/16/20 08:59 PM
J
jayjr1105 Offline
J
Check out 0w20 Rotella Gas Truck as well... High Moly and very low NOACK as well (7 I think). On a side note, Have you thought about VCM muzzler for the vehicle?
Re: 2018 Odyssey 5w20? [Re: jayjr1105] #5352232 02/16/20 09:39 PM
J
Jake777 Offline OP
J
So I actually had the original muzzler for my 09 Odyssey. It worked great. But they really updated the VCM on this new Odyssey and I can barely tell when it’s on. Also I now live in a more mountains area and it hardly gets to activate. I guess I just didn’t Want to start messing with a brand new vehicle like that
2015 Honda Accord
