Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
76 registered members (askani79705, bbhero, 4WD, Astro_Guy, 2002 Maxima SE, 7 invisible), 1,487 guests, and 23 spiders.
Topics301,732
Posts5,201,620
Members70,766
Aluminum or Copper Washers #5350069 02/14/20 03:38 PM
G
Gebo Offline OP
G
From reading in another forum I now have a question.
Should we only use aluminum washers on our aluminum oil and AT cases?
I've seen where it seems most people don't think we should use copper anti-seize on spark plugs going in an aluminum block.
Should we not use copper washers between aluminum parts? If so, why?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Aluminum or Copper Washers [Re: Gebo] #5350078 02/14/20 03:44 PM
B
brages Online Content
Online Content
B
I gotta wonder, why are we using metal for a seal anyway...?
Re: Aluminum or Copper Washers [Re: Gebo] #5350081 02/14/20 03:48 PM
demarpaint Offline
I've had the best luck with these. Dorman Drain Plug Gasket I had copper and aluminum crush washers leak on my transmission drain plug, and an oil pan drain plug, that solved both problems.
God Bless Our Troops
Re: Aluminum or Copper Washers [Re: Gebo] #5350093 02/14/20 04:04 PM
Mr Nice Offline
Yep, low cost and works great.
Re: Aluminum or Copper Washers [Re: Gebo] #5350154 02/14/20 05:19 PM
T
Trav Offline
T
Most copper rings used as seals are not dead soft copper but a copper alloy and takes more torque to seal than aluminum which in most seal washer applications is very soft.
Many OE manufacturers use aluminum washers/rings for sealing on aluminum, steel and iron without any issues.
Re: Aluminum or Copper Washers [Re: Gebo] #5350206 02/14/20 06:38 PM
A
atikovi Offline
A
Use this style and you don't need no stinkin washer.
[Linked Image from images-na.ssl-images-amazon.com]
Re: Aluminum or Copper Washers [Re: atikovi] #5350233 02/14/20 07:26 PM
spk2000 Offline
Where you get these at? Are they self sealing by that design? Assume they last alot longer than crush washers.
Personally have reused many crush washer and none have ever leaked though. Also have some that have a built in flat washer that seems to work quite well.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Aluminum or Copper Washers [Re: Gebo] #5350252 02/14/20 07:40 PM
N
NormanBuntz Offline
N
The only two vehicles I've owned that called for copper oil drain plug washers were a 1996 Isuzu Trooper and a 1987 Alfa Romeo Spider. All the rest specified aluminum, except the odd Toyotas of the 1980's that used fabric washers.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 11K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: Aluminum or Copper Washers [Re: Gebo] #5350358 02/14/20 09:54 PM
R
Rand Offline
R
I usually use oem style.
Crushing type on subaru, Flat alum. on hyundai.
gasketed plug on jeep. etc.
My favorite are the subaru.. they physically crush (hollow) and its easy to tell when they stop crushing/fully tight.
The flat non crushing hyundai style is ok I just go hand tight with a short ratchet.
least favorite are the gasketed plugs.. I feel I always overtighten them.. but if you ever had one come off/loosen on you(I have) its an easy mistake to make.
Fortunately as long as you arent stupid they can take abit without failing/causing damage. ie they arent plastic.
Re: Aluminum or Copper Washers [Re: Gebo] #5350904 02/15/20 03:38 PM
H
hallstevenson Online Content
Online Content
H
If by mixing different metals, you're thinking of "galvanic corrosion", for all practical purposes it's not going to happen with a washer. Threads, i.e. a steel fastener into an aluminum tapped hole, are a different matter though.
Re: Aluminum or Copper Washers [Re: atikovi] #5350907 02/15/20 03:41 PM
H
Online Content
H
Be careful with those or be aware but the rubber o-ring can apparently fall out of those. My wife's Fusion would drip unless I really snugged down the oil drain plug, snugged tighter than I liked. I have some Honda aluminum crush washers and tried one of those - problem solved. Later, I looked to see if Ford uses a sealing washer or something and that's when I found that they use this type of plug with the built-in o-ring.
Re: Aluminum or Copper Washers [Re: Gebo] #5351193 02/15/20 09:30 PM
T
Triple_Se7en Offline
T
I get the aluminum Dorman gaskets (25 for $6.99) for our Hyundai and Kia over at Autozone.
Part # 095-147
Already replaced the OEM oil pan plug with a magnetic oil pan plug.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Aluminum or Copper Washers [Re: Gebo] #5351200 02/15/20 09:37 PM
P
painfx Offline
P
I just use OEM washers.
