Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
2015 Forester - whine/Rough at specific RPM
by MoneyJohn - 02/19/20 09:06 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
111 registered members (92saturnsl2, 53' Stude, 94astro, 2003f7, 1978elcamino, 9 invisible), 2,350 guests, and 28 spiders.
Topics301,660
Posts5,200,121
Members70,748
Buying a 2001 4Runner LTD Tomorrow #5349965 02/14/20 01:33 PM
Speak2Mountain Offline OP
252K
Not leaking oil
Suggestions for oil?
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5349969 02/14/20 01:36 PM
A
ad244 Offline
A
Pennzoil Platinum 10w-30
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5349981 02/14/20 01:53 PM
Sayjac Offline
If it's the 3.4L timing belt engine, very easy on oil. Ime and imo, any 5w30 or 5w20 synthetic will work quite nicely. That includes but not limited to, ST Synthetic, QSUD, and Havoline Pro DS box to name a few.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: ad244] #5349983 02/14/20 01:54 PM
that's a good suggestion.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5349987 02/14/20 01:56 PM
A
ad244 Offline
A
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5349997 02/14/20 02:03 PM
O
OilUzer Offline
O
Curios what your OM recommends? My old Tacoma 3.4L V6 (same engine?) says 5W30 or 10W30 and doesn't like syn-blend. It does well with 10W30 dino ...
Re: Buying a 2001 4Runner LTD Tomorrow [Re: OilUzer] #5350000 02/14/20 02:06 PM
A
ad244 Offline
A
5w-30 every 5,000 miles, doesn't specify synthetic
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350006 02/14/20 02:10 PM
02SE Offline
I recently sold my '97 4Runner with the 5VZ-FE (3.4) engine. Except during the break-in period, it ran on synthetic (usually Mobil 1) 5w30 or 10w30 as long as I owned it. No issues.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350020 02/14/20 02:28 PM
E
e55amgbenz007 Offline
E
10W30 Maxlife. Do not put a 5W nor a synthetic in the engine at 250K if it has not been run with it for some time. Run the Maxlife to 5K with a Mobil One M1-209 oversized filter. Leave the filter on for three oil changes. This combo has served me well over the course of several hundred thousand miles on the Toyota 3.4.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: ad244] #5350039 02/14/20 02:52 PM
J
JustinSL Offline
J
I run these on my ‘04 Tacoma. Great value for a good filter.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350068 02/14/20 03:36 PM
A
ad244 Offline
A
I think we need a Tacoma/ T4R showcase thread. I'd like to see all these old tacomas still driving around! Mine has 235k miles
Re: Buying a 2001 4Runner LTD Tomorrow [Re: e55amgbenz007] #5350079 02/14/20 03:46 PM
N
nthach Offline
N
5W-30 or 10W-30 depending on the weather and a 3614/51348/90915-YZZB5 filter(an FL400s/3600/51516 will also fit space-dependent), a 5VZ-FE isn't going to complain.
FWIW, I ran a 1UZ-FE up until 297K with no issues on a non-HM 5W-30 and OEM filters. Running out of oil or not changing it enough is a bigger threat to a Toyota engine than oil and filter choice.
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350092 02/14/20 04:03 PM
G
Gebo Offline
G
I'm running 10W-30 PP HM in mine with stock OEM filter. I flop between Pennzoil and Quaker State. Valve cover gasket was leaking a little so that's why I'm using the HM. Probably won't matter either way.
I've run 5W-30, 10W-30 and 10W-40.
Years ago I might have been afraid to change from conventional to synthetic oil on a car with a lot of miles. I don't feel that way anymore because most oils they call "synthetic" aren't really true "synthetic."
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350122 02/14/20 04:38 PM
K
krismoriah72 Offline
K
Originally Posted by Speak2Mountain
252K
Not leaking oil
You said it doesnt leak oil..that doesnt mean it doesnt consume oil...
I would start out with Walmart or Costco or whatever 10w30 is the cheapest and monitor consumption before going with a higher cost oil.
Im sure you have looked it over nicely.. have you started it while cold does it smoke? Have you Pulled PCV while hot to see if it has blowby? Tailpipe soot?
Long test drive with multiple stops for CELs?
Re: Buying a 2001 4Runner LTD Tomorrow [Re: Speak2Mountain] #5350225 02/14/20 07:13 PM
1
14Accent Offline
1
She's got a few miles on her!
I assume your location is correct, so this is a southern truck? If so, it should suit you well. 10w-30 should, as well, and at that mileage I'd just use conventional with a good filter. Plus, the A340E is a great transmission. Sounds like a solid truck, if the price was right!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
