War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
FlightRT, 74Widebody, mmmmmnnn, jjrockbush, eamerritt
70721 Registered Users
81 registered members (74Widebody, AC1DD, 4WD, Ag76, AcuraMDX2014, 97prizm, 12 invisible), 1,763 guests, and 56 spiders.
Topics301,545
Posts5,197,683
Members70,721
Update: 02` Ford Ranger issues #5349592 02/14/20 06:23 AM
NavyVet88 Offline OP
Hey guys,
Some of you may remember my issues I was speaking about with my ranger and its rough idle and converter slip issues.
The rough idle was cured with replacing the MAF sensor. After losing my mind trying to troubleshoot the issue for months, I turned it over to my mechanic who had it for a week and found that one of the two terminal stabs on the sensor was slightly bent so he straightened it and it almost eliminated the rough idle but not completely so he threw on a new sensor and solved the problem. He said the old one seemed to be a cheap aftermarket type and replaced it with OEM.
Thank you guys for all your help!
NEW THIS MORNING:
As I was pulling on to the exit ramp from the interstate, I noticed that the truck wanted to keep going as I was applying the brake to slow down for the yield. The RPMS stayed at 2k as I slowed down below 30mph until I felt I slight jerk in the truck and it settled back out to normal. I did just replace the IAC and TPS recently so im not sure if that may have something to do with it or not. When the original TPS went bad, it was jerking just like I felt this morning pulling in to work so I will look at that first then the throttle body.
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349599 02/14/20 06:30 AM
Char Baby Offline
Thanks for getting back with the end result.
GEE, I hope you find the culprit with your throttle.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349613 02/14/20 06:53 AM
K
Kira Offline
K
TPS = Throttle Position Sensor
IAC = Incoming Air....Valve?
Re: Update: 02` Ford Ranger issues [Re: Kira] #5349619 02/14/20 07:03 AM
Idle air control valve*
Re: Update: 02` Ford Ranger issues [Re: Char Baby] #5349620 02/14/20 07:04 AM
Thanks and I apologize for taking so long on reporting back.
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349622 02/14/20 07:07 AM
Snagglefoot Online Content
Online Content
Go over the throttle cable carefully and see if anything is jamming, corroded or worn. I can’t recall if you tried a Ford Ranger forum, but if not, list the problem there as well. smile
If you want the job done right......do it yourself.
Re: Update: 02` Ford Ranger issues [Re: Snagglefoot] #5349629 02/14/20 07:15 AM
That's the plan. Im gonna stop and grab a can of carb cleaner after work today too and take a tooth brush to the butterfly as well.
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349676 02/14/20 07:58 AM
DuckRyder Offline
Is it like a manual trans with the clutch still engaged? Had a sticking TCC onetime that acted like that. Did you use the recommended fluid when you serviced it?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Update: 02` Ford Ranger issues [Re: DuckRyder] #5349700 02/14/20 08:16 AM
Its an automatic 2x4. I did use the recommended mercon v when I did the trans flush and filter change back in September/august time frame.
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349755 02/14/20 09:27 AM
01rangerxl Offline
Did you use aftermarket parts for the IAC and TPS?
If you still have the original IAC, I would probably clean it out real well with throttle body cleaner and put it back on if it does it again. Some aftermarket ones don't work very smoothly.
Maybe just wait and see if the issue repeats...if it just did it once, it may have been a fluke.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5349763 02/14/20 09:32 AM
B
Blkstanger Offline
B
I have owned a few Rangers over the years. Check your floor mats! It's pretty common to have after market floor mats catch the gas pedal. It happened to me going to work one morning. Floor mat went right into the trash.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Update: 02` Ford Ranger issues [Re: 01rangerxl] #5350016 02/14/20 02:24 PM
I do not have the original. My luck happened to be that the tps went out about a mile and a half from my local autozone and all they had in stock was the Duralast brand so that's what I got.
Re: Update: 02` Ford Ranger issues [Re: Blkstanger] #5350017 02/14/20 02:25 PM
Interesting...I will give those a look as well.
Re: Update: 02` Ford Ranger issues [Re: NavyVet88] #5350140 02/14/20 04:59 PM
J
Jethro_Bob Offline
J
Did you do the idle relearn procedure, after clanging iac and maf sensors? If so you'll want to do it again after cleaning your throttle body. After you reconnect the battery let it idle three minutes with air conditioner off, kill it and restart it and turn the ac on max for 3 minutes before killing it again.
