5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
33 registered members (Char Baby, blufeb95, carlprop, Dave_Mark, ctechbob, 3 invisible), 1,099 guests, and 20 spiders.
Topics301,965
Posts5,206,610
Members70,808
Schaeffer's all supreme transmission fluid? #5349403 02/13/20 08:52 PM
Dragon44 Offline OP
Thinking about putting this in my 2018 RAM 2500. How does this transmission fluid hold up to the rest of ATF-4 fluid's?
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349467 02/13/20 10:53 PM
Z
zrxkawboy Offline
Z
It is not an ATF+4 fluid. The mfr simply recommends it for use in ATF+4 applications.
I'd stick with an approved ATF+4.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349496 02/14/20 12:05 AM
Dragon44 Offline OP
It is recommended for Chrysler vehicles that need ATF-4 so i wont have any problems. I'm just seeing how it compares to the rest of ATFs.
Re: Schaeffer's all supreme transmission fluid? [Re: zrxkawboy] #5349497 02/14/20 12:09 AM
dogememe Offline
+1.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349643 02/14/20 07:23 AM
J
JustN89 Offline
J
Impossible to tell how well it "holds up to" other, licensed ATF+4 certified fluids. Generally speaking, I've had a good experience running Schaeffer's products and I'd bet that their All-Trans Supreme wouldn't be any different. That said, I'm not going to recommend that you run something other than a certified fluid in your transmission, especially with a spec that's widely available on the aftermarket. Here is a great list of all ATFs holding the ATF+4 spec. Looks like there's 41 fluids to choose from, so pick your favorite brand, label color, or whatever you'd like and run with it.
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349647 02/14/20 07:26 AM
K
Kira Offline
K
I'm all for Schaeffer's but I'd stick with a real ATF+4 were I in your shoes....especially in a vehicle so new.
Whenever I go to any fluid catalog (auto store, Amazon etc.) jugs of genuine Mopar ATF+4 is always there.
Be glad for that.
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349711 02/14/20 08:30 AM
-SyN- Offline
I will throw this out there with a 2K lb chain & anchor.
After my first 12K lb towing advantage with our new 2017 Ram 6.7L w/68RFE @ the 1200 mile mark - (417 mile round trip).
I seen average temps of 181-195*F - Not a Fan of these higher temps!
At the 3K mile mark - with the help of a electric pump I sucked out 1gal through the dipstick & refilled with Red Line C+.
Drove for 200 miles & repeated the process - Did the Red Line C+ (transfusion)1 more time.
I then replaced the 68RFE Themal ATF by-pass with a ATS delete block - now my 68RFE temps stay around 157-164*F.
(I have a Constant flow of ATF to & through the cooler) -(Never by-passed).
With the piece of mind knowing that tiny little valve will never fail closed!
8K miles later - My 68RFE has performed flawlessly since the (3 Transfusions) especially during the much colder temps.
This spring I have plans on dropping the stock pan & replacing with a PML (with a drain plug) & swapping to All-Trans - Then swapping the cheap paper spin-on filter with a royal purple spin-on.
With this done - I will have Schaeffers Ultra 10W-30 flowing through the 6.7L & All-Trans within the Power Steering / Transfer Case / 68RFE.
Red Line gear oil in Front & Rear differentials.
Remember: Just because I run it with a positive success & U don't - doesn't mean I'm wrong!
Do I recommend this to other 68RFE owners - No! It's none of my business what others run.
Only sharing my personal experience & future plans.
17 Ram 2500 6.7L > -Schaeffers- Ultra 10W-30 w/LF16035
19 Edge ST 2.7L EB > Castrol Edge Euro 0W-40 w/MC Filter
17 Edge Titanium 2.0L EB > Castrol Edge Euro 0W-40 w/RP Filter
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349734 02/14/20 08:58 AM
G
Gebo Offline
G
I love Schaeffer. But in this situation, I'd stick with the OEM fluid. I only use OEM ATF, Coolant and PS fluids on my Toyotas.
Using a universal ATF may work fine for thousands of miles before it causes problems. "If" it causes problems. It may work
like a champ.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5349749 02/14/20 09:23 AM
O
ofelas Offline
O
Licensed ATF+4 in a truck under warranty.
No need to give FCA an excuse to deny coverage on the inevitable 68RFE failure.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5350466 02/15/20 03:44 AM
-SyN- Offline
Change of Mind: Local Schaeffers Oil jobber is retiring due to health issues - so looks like the MOPAR ATF+4 gets the nod.
With the Thermal By-Pass delete block installed the ATF will never again be stressed with Heat Issues - so the fluid should have a some what easy life.
Re: Schaeffer's all supreme transmission fluid? [Re: -SyN-] #5350900 02/15/20 03:33 PM
K
kstanf150 Offline
K
What about using Redline tranny fluid instead ?
Re: Schaeffer's all supreme transmission fluid? [Re: Dragon44] #5351244 02/15/20 10:51 PM
-SyN- Offline
Red Line C+ is flowing through its veins now! - I feel its the Perfect ATF for the 68RFE if worked hard 24/7. The cost per gallon is some what expensive compared to others!
Mine has it easy in the winter - NO Towing!
Just got off the phone with Ray - He stated he was only part time retiring and he would keeped me stocked with Schaeffers Ultra 10W-30 as well as All-Trans for my 68RFE & My SoyShield (diesel fuel additive).
So when the New PML pan goes on - Schaeffers All-Trans will be going in!
Old Threads like this: Make me feel alot better!
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=522531
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1663452/1
