How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
139 registered members (14Accent, 4WD, 762fermeandyou, alphadog, Al, archibald2, 12 invisible), 1,933 guests, and 16 spiders.
Topics302,056
Posts5,208,222
Members70,826
Question about battery volts and outside temperature #5349235 02/13/20 06:10 PM
B
boostedtsiawd Offline OP
B
I was wondering is it normal for battery volts to drop when temps are 10F and below? I checked my car battery the next day while it was dead cold without it running and the windchill temp was -3F it read 12.15 volts is this normal considering the temperature was below zero or is that low? I started it up and checked volts as well and it was 14.5-14.6.
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349249 02/13/20 06:22 PM
W
Wolf359 Online Content
Online Content
W
Windchill doesn't affect inanimate objects like batteries. It only applies to body temperature.
https://en.wikipedia.org/wiki/Wind_chill
And yes, the lower the temperature, the lower the voltage. That's why many battery state of charge charts say no load at 70 degrees.
Mine has been as low as 11.5 volts at 20 degrees. Keep in mind that's also with a load. No load voltages are higher.
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349252 02/13/20 06:24 PM
supton Offline
Found this thread and it does show, 2/3's the way down, voltage against temperature. And shows that the battery voltage does drop with temperature.
Note, windchill affects how fast items cool down, by impacting how fast heat is wicked away. But windchill does not make an item colder than ambient. Your battery is (somewhat) insulated from the wind, and only cares about ambient temps (plus any residual underhood heat).
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349282 02/13/20 06:57 PM
T
tundraotto Offline
T
Yes.
This is why temperature compensating charging algorythms should be in every premium premium battery charger - but they are not.
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349323 02/13/20 07:45 PM
A
andyd Offline
A
Monday PM, I left the pkg?lights on. Tues AM just a click. Jumped it to run rubbish to road. and rigged up my charger for 2amp. 2hrs later I made a 60 mile round trip. I metered the battery at 12.3v when I got home. So I rigged up the HF 4.99 1/2 amp floater and left it going until This AM. 3 hrs later, I metered the battery and it was 12.76 V. That is 100% charge? Temps 30s 40s F
Thick oil is better grin2
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349378 02/13/20 08:36 PM
B
bbhero Offline
B
[Linked Image]
This table seems rather helpful...
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Question about battery volts and outside temperature [Re: bbhero] #5349504 02/14/20 12:27 AM
W
Online Content
W
A little. It's still open circuit voltage. You have to factor in the drop when the battery is connected in the car. And that will vary depending on the load a particular vehicle puts on the battery.
Re: Question about battery volts and outside temperature [Re: Wolf359] #5349549 02/14/20 04:15 AM
B
bbhero Offline
B
Still better than nothing...
And if a battery was 12.15 even at 0 degrees Fahrenheit... That seems possibly low....
My car was 12.57 the other day at 60 degrees... Still hooked up to the car still.
Re: Question about battery volts and outside temperature [Re: boostedtsiawd] #5349953 02/14/20 01:21 PM
W
wrcsixeight Offline
W
Charts can be helpful for general guidelines, but they are not to be taken as gospel.
I've had AGM batteries that rest truly fully charged days off the charger, at 13.16v, 0.4v above that chart @65f, making that chart on those specific batteries almost completely irrelevant..
Voltage alone is always misleading. It is not a fuel level gauge as so many seem to think.
How many volts can the battery maintain under X amount of load, at what battery temperature?
How does this compare to other temperatures?
How does this compare to when the battery was newer?
How does this compare when the battery has seen a plug in charging source applied overnight or longer?
How does this compare when blasting the stereo with the engine off for 10 minutes?
Its just a battery, they are rented, does it really matter? replace as needed.
A voltmeter with voltage sense leads directly on the battery terminals, every time the engine is started, will give the user much more information as to battery state of health, and state of charge, and give ample warning when a no start is becoming imminent. Such a voltmeter also unravels the mystery of the vehicle's voltage regulation, which nowadays can intentionally sacrifice the battery for tiny gains in mpg's.
Likewise when charging, knowing how many amps the battery is accepting at what voltage is paramount to understanding when the battery is indeed fully charged. 95% charged is good but only half as good as 100% in terms of keeping the battery happiest for the longest span possible. A battery charged only 30%, can still likely start your vehicle. Funny how many people think the battery which can start the engine is healthy and therefore fully charged.
Every battery Starting/deep cycle/ marine dual purpose maintainence free flooded or AGM I have taken off a 'smart' charger whose green light is on, has accepted more Amphours/watt hours from my adjustable voltage power supply set at 14.4 to 14.7v as amps taper further. Often it takes 3+ more hours at 14.4v before it can be considered fully charged via amperage or with a flooded battery, when the hydrometer's specific gravity reading stops rising . I usually get 10 to 15 more Ah into group 27 or larger batteries rated at 100Ah capacity and it takes hours and hours. Very rarely does my Adjustale voltage power supply's ammeter and voltmeter acree with teh smart charger, and when it does it is on a newish battery that was unintentionally discharged. Every time I charge an older battery the Adjustable voltaeg power supply is aboe to return 5%+ more into the battery
The Hydrometer does not lie. A voltmeter can. The green charger light does.
The older the battery the longer it takes to achieve full charge, and the more it needs that true full charge in order for capacity decline/performance decline, to not accelerate.
The deeper the discharge, the more important the proper recharge becomes, and it takes much longer than people expect, and may products, despite their marketing and owner/fanboys, are incapable of achieving a proper full recharge.
Good enough, is subjective....opinion, not fact.
If one does intend to achieve full charge of a lead acid battery, they need a charging source capable of maintaining 14.4v+ for as long as is required either for amperage to decline to a certain level, or for the hydrometer to indicate specific gravity of the electrolyte is no longer rising, and preferably both methods if possible
Full charge via amperage acceptance cannot be determined at lesser voltages, so a 'smart' charging source which keeps reverting to float prematurely is not doing the aged battery any favors, and none of them have hydrometer probes. So 'full charge' is a best guess algorithm for as wide a spectrum of starter batteries as possible. One size fits none, but any charging source applied to an undercharged battery is better than none.
