Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
24 registered members (Bjornviken, Bighorn2500, Best F100, 53' Stude, Amenhotep, Aichiguy, 3 invisible), 1,196 guests, and 18 spiders.
Topics301,933
Posts5,205,762
Members70,801
Changing Fluid in Diff 2008 CRV AWD #5349160 02/13/20 04:55 PM
G
Gebo Offline OP
G
How often should I change the Diff fluid in a 2008 AWD Honda CRV?
It's the Honda DP 2.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349221 02/13/20 05:56 PM
G
GSCJR Offline
G
Maintenance minder will signal when it's time, IIRC.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 157KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349253 02/13/20 06:29 PM
N
nthach Offline
N
Honda recommended 30K intervals in the past. Which if I was caring for a CR-V/RDX or anything with the RT4WD system would be my recommendation too.
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349266 02/13/20 06:42 PM
G
Gebo Offline OP
G
I’ve seen some forums where they mentioned 15k. I was sorta thinking of doing every 30k when I do the ATF.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Changing Fluid in Diff 2008 CRV AWD [Re: GSCJR] #5349267 02/13/20 06:43 PM
G
Gebo Offline OP
G
I ain’t gonna use the maintenance minder.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349273 02/13/20 06:49 PM
H
hallstevenson Offline
H
But you'll take "advice" from random people on the internet....
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349292 02/13/20 07:03 PM
R
Ride_Red Offline
R
The maintenance minder is incorrect on these 3rd gen CR-Vs. There is a Technical Service Bulletin to change it at 15K or 20K miles (I cannot remember which, search the CR-V forum if you really need to know). If you wait too long, the rear diff begins to engage while driving/turning and you’ll feel vibrations.
If you think you are having problems, the TSB said to put the car in reverse and turn the steering wheel all the way to the right and drive in circles. Repeat this to the left, also. If you feel the rear diff grabbing, you need to flush the diff with thee fluid changes. This will correct the grabbing and vibrations.
If no grabbing/vibrations, do a single drain and fill.
I 1x drain and fill my rear diff every year or 15K. I use the Honda Dual Pump 2 fluid. It takes a little over one quart, so buy two. It’s also helpful if you get a pump that fits the top of the bottle. They’re pretty inexpensive and worth their weight in gold for this job.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: Changing Fluid in Diff 2008 CRV AWD [Re: hallstevenson] #5349326 02/13/20 07:46 PM
G
Gebo Offline OP
G
Affirmative. I trust you guys more than you realize. I use discernment. banana
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Ride_Red] #5349329 02/13/20 07:56 PM
G
Gebo Offline OP
G
A Honda guy told me to wait til it starts grabbing when turning left and right. Lol. Seems a little late for me. I guess I can go to CR-V forums. This is not my car but I am responsible for maintenance. 15k should be very satisfactory.
Thank you Ride_Red. Great info.
I watched Eric the Car Guy use a screw nipple on the DP2 bottle and squirt it directly in the diff. I may try that technique once.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349331 02/13/20 07:57 PM
G
Gebo Offline OP
G
I’m gonna do some backwards donuts in the church parking lot while slurping a Blizzard with my wife.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Ride_Red] #5349349 02/13/20 08:12 PM
H
H
Does the Honda TSB say replace the fluid 3x ? That doesn't make much sense... A diff doesn't have passages, secondary areas, tubing, etc where extra fluid can remain.
Re: Changing Fluid in Diff 2008 CRV AWD [Re: hallstevenson] #5349353 02/13/20 08:17 PM
R
Ride_Red Offline
R
The TSB applied all the way back to the 1st gen CR-V. I think the 3x flush also was because they changed from “Dual Pump Fluid” to the new “Dual Pump Fluid 2” and wanted to flush all the old fluid out.
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349366 02/13/20 08:25 PM
R
Ride_Red Offline
R
I tried the nozzle on the bottle. I couldn’t get all the quart in there because you can’t tip it up high enough. The pump worked much better for me. Been doing it that way for 10 yrs now.
Also, remember to open the FILL plug first. Then open the drain. It would be a bad day if you drain the fluid out and the fill plug is stuck!
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349506 02/14/20 12:30 AM
W
WhyMe Offline
W
i changed mine every 30k miles on my 2011. its just a drain and refill so not much to it. get one of those pumps that attached to the bottle i always wondered if i could go longer as every time i drained it , it looked pristine. never had any binding in the 115k miles on it
Re: Changing Fluid in Diff 2008 CRV AWD [Re: Gebo] #5349552 02/14/20 04:31 AM
R
Ride_Red Offline
R
Yep. Seems like a waste because the fluid looks so clean. But that’s the point, what’s in that diff that would make it dirty? The clutch packs! If the fluid is dirty, you are wearing the clutch pack.
I think the MM interval was 60K or something large like that. 30K is probably just fine. 15K-ish was easy for me because I change it in the fall before it gets cold outside. I work in my driveway, so many maintenance schedules get manipulated so I’m not under the car in the winter.
