Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
100 registered members (2015_PSD, 2003f7, 928, 2strokeNorthstar, 14 invisible), 2,387 guests, and 18 spiders.
Topics303,584
Posts5,237,758
Members71,094
Historical - Fuel Metering in SI Engines #5348925 02/13/20 12:24 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Before the advent of fuel injection systems various carburetor designs were used.
For V8's, the carbs of choice were either the Rochester 2-Barrel or the QuadaraJet 4-Barrel.
In the QuadaraJet,carburetor there was a small piston assembly sitting in a fuel well.
Q1: What was the name of this small piston assembly?
Q2; What was it's function with respect to the metering rods?
This question is NOT open to any Engineering Discipline.
Remember, your response goes into a queue so there will be a delay in the appearance of your response.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348936 02/13/20 12:38 PM
B
BigGee Offline
B
I always called it the power valve ,it lifted metering rods to richen the mixture at part throttle.The secondary top butterfly lifted the rods when the secondaries were opened.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348942 02/13/20 12:46 PM
I
Inspecktor Offline
I
Accelerator pump. Augment fuel flow during increased throttle opening where otherwise fuel/air ratio would go too lean for smooth engine operation.
2004 Mini Cooper 42,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 74,500 mi
2001 Buick LeSabre Limited 299,000 mi
2001 Subaru Outback 169,000 mi
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348954 02/13/20 12:59 PM
O
OLEJOE Offline
O
We called it an accelerator pump. It squirts extra fuel in when the metering rods are raised to give the fuel time to catch up with the extra air when the secondaries are actuated. To help with the fuel delivery delay.
Jack of All Trades. Master of some.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348961 02/13/20 01:11 PM
R
Ride_Red Offline
R
It's the accelerator pump. (or that is how I learned it).
It squirts gas into the engine when you step on the gas pedal. Without it, the engine would hesitate when you step on the gas.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348981 02/13/20 01:35 PM
old1 Offline
I think Big Gee had it right
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349018 02/13/20 02:28 PM
spasm3 Offline
As others stated, accelerator pump. Gives fuel as the air flow increases so fast when the secondaries open, prevents a lag when they open. Holley had a double pumper carb with 2 pistons.
The quadrajet spreadbore, when right really got decent mileage and ran well. I've rebuilt a few, but its been a while. Not everyone could get them right.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349044 02/13/20 03:34 PM
R
ragtoplvr Offline
R
The small piston sitting in a fuel filled well is called the accelerator pump.
The small piston sitting in the middle of the fuel bowl is the power piston.
your question is unclear. Hence 2 answers.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349104 02/13/20 04:38 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Looks like a Hint is in order:
This device prevents oscillation of the metering rods.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349128 02/13/20 05:02 PM
R
ragtoplvr Offline
R
There is a metering rod spring that prevents movement of the rods relative to the hanger in the primary power piston. Having rebuilt a lot of Qjets in the day, there is nothing to prevent the primary power valve piston from oscillating except the mass of the piston and the size of the passage feeding it vacuum. Well that and occasionally varnish from fuel builds up there. I never noted excess wear of the piston or bore, so it must not oscillate significantly.
Rod
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349951 02/14/20 02:17 PM
B
BigGee Offline
B
Power piston assembly is the correct name that I have found on a diagram today.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5351907 02/16/20 04:54 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Thanks for the many responses and I too have rebuilt quite a few Quadrajets myself for older Suburbans.
According to E. Obert in, Internal Combustion Engines and Air Pollution,, Section 11-10 where he describes Carburetors for High Output Engines and specifically he discusses the Quadarjet he says, "To prevent wavering and oscillations of the metering rods, a dashpot, a piston in a fuel well arrangement, is included."
I would have preferred the term damper.
Now the closest thing I could find to what is described as a dashpot assembly is Part 15 in the exploded view below for the 4MV of 1966..
https://quadrajetparts.com/-a-7.html
