It's NAPA time!
by SlavaB - 04/03/20 12:57 AM
Parts for a $1000 computer
by Toy4x4 - 04/02/20 11:45 PM
Bottle jack as jack stand?
by JHZR2 - 04/02/20 10:45 PM
Freedom 500
by earlyre - 04/02/20 09:41 PM
What would a missing egr valve gasket cause?
by 2009Caraman - 04/02/20 09:25 PM
2008 Accord 2.4L 4,044 PPHM 5w-20
by Brolly - 04/02/20 08:34 PM
Nu Finish
by rrretiree7 - 04/02/20 07:18 PM
Leases?
by wallyuwl - 04/02/20 07:04 PM
Ford A/C quick connects
by Colt45ws - 04/02/20 06:16 PM
Steel rims ; How good are ...
by odie - 04/02/20 03:42 PM
I'll be back hopefully
by 53' Stude - 04/02/20 02:09 PM
Mazda CX-5 Skyactive Transmission fluid?
by Drew99GT - 04/02/20 01:32 PM
Transfer pics / videos iPhone to PC
by diyjake - 04/02/20 11:47 AM
Valve train noise on start up
by NavyVet88 - 04/02/20 11:24 AM
Eezox vs Prolix?
by Gebo - 04/02/20 10:52 AM
Tool battery question
by supton - 04/02/20 10:36 AM
ebarker, Knop, AConstructionGuy, MPDano, ferdna
71079 Registered Users
19 registered members (Bailes1992, GarrettB32, Donald1953, Chesterr, GZRider, BretK, 3 invisible), 1,162 guests, and 20 spiders.
Topics303,501
Posts5,236,493
Members71,079
Historical - Fuel Metering in SI Engines #5348925 02/13/20 12:24 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Before the advent of fuel injection systems various carburetor designs were used.
For V8's, the carbs of choice were either the Rochester 2-Barrel or the QuadaraJet 4-Barrel.
In the QuadaraJet,carburetor there was a small piston assembly sitting in a fuel well.
Q1: What was the name of this small piston assembly?
Q2; What was it's function with respect to the metering rods?
This question is NOT open to any Engineering Discipline.
Remember, your response goes into a queue so there will be a delay in the appearance of your response.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348936 02/13/20 12:38 PM
B
BigGee Offline
B
I always called it the power valve ,it lifted metering rods to richen the mixture at part throttle.The secondary top butterfly lifted the rods when the secondaries were opened.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348942 02/13/20 12:46 PM
I
Inspecktor Offline
I
Accelerator pump. Augment fuel flow during increased throttle opening where otherwise fuel/air ratio would go too lean for smooth engine operation.
2004 Mini Cooper 42,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 74,500 mi
2001 Buick LeSabre Limited 299,000 mi
2001 Subaru Outback 169,000 mi
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348954 02/13/20 12:59 PM
O
OLEJOE Offline
O
We called it an accelerator pump. It squirts extra fuel in when the metering rods are raised to give the fuel time to catch up with the extra air when the secondaries are actuated. To help with the fuel delivery delay.
Jack of All Trades. Master of some.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348961 02/13/20 01:11 PM
R
Ride_Red Offline
R
It's the accelerator pump. (or that is how I learned it).
It squirts gas into the engine when you step on the gas pedal. Without it, the engine would hesitate when you step on the gas.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5348981 02/13/20 01:35 PM
old1 Offline
I think Big Gee had it right
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349018 02/13/20 02:28 PM
spasm3 Offline
As others stated, accelerator pump. Gives fuel as the air flow increases so fast when the secondaries open, prevents a lag when they open. Holley had a double pumper carb with 2 pistons.
The quadrajet spreadbore, when right really got decent mileage and ran well. I've rebuilt a few, but its been a while. Not everyone could get them right.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349044 02/13/20 03:34 PM
R
ragtoplvr Offline
R
The small piston sitting in a fuel filled well is called the accelerator pump.
The small piston sitting in the middle of the fuel bowl is the power piston.
your question is unclear. Hence 2 answers.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349104 02/13/20 04:38 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Looks like a Hint is in order:
This device prevents oscillation of the metering rods.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349128 02/13/20 05:02 PM
R
ragtoplvr Offline
R
There is a metering rod spring that prevents movement of the rods relative to the hanger in the primary power piston. Having rebuilt a lot of Qjets in the day, there is nothing to prevent the primary power valve piston from oscillating except the mass of the piston and the size of the passage feeding it vacuum. Well that and occasionally varnish from fuel builds up there. I never noted excess wear of the piston or bore, so it must not oscillate significantly.
Rod
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5349951 02/14/20 02:17 PM
B
BigGee Offline
B
Power piston assembly is the correct name that I have found on a diagram today.
Re: Historical - Fuel Metering in SI Engines [Re: MolaKule] #5351907 02/16/20 04:54 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Thanks for the many responses and I too have rebuilt quite a few Quadrajets myself for older Suburbans.
According to E. Obert in, Internal Combustion Engines and Air Pollution,, Section 11-10 where he describes Carburetors for High Output Engines and specifically he discusses the Quadarjet he says, "To prevent wavering and oscillations of the metering rods, a dashpot, a piston in a fuel well arrangement, is included."
I would have preferred the term damper.
Now the closest thing I could find to what is described as a dashpot assembly is Part 15 in the exploded view below for the 4MV of 1966..
https://quadrajetparts.com/-a-7.html
