Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
44 registered members (blufeb95, 74Widebody, 97prizm, Bjornviken, bachman, 5 invisible), 1,084 guests, and 23 spiders.
Topics301,812
Posts5,203,168
Members70,784
removing wheel arch molding #5348657 02/13/20 12:25 AM
W
WhyMe Online Content OP
OP Online Content
W
so my new civic came with wheel arch stick on molding. i want to remove it without messing up the paint. whats the best way? man they have a gall to charge $199 for it. LOL
Re: removing wheel arch molding [Re: WhyMe] #5348680 02/13/20 02:55 AM
Char Baby Online Content
Online Content
Well, I'll tell ya wut!
I saw your other post and pictures with the new car and I love it and I'd leave on the black arch moldings.
But, if you must remove them, try some heat with something like a hair dryer and see if they'll peel away. Then clean the adhesive with brake clean. It won't hurt the paint.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: removing wheel arch molding [Re: Char Baby] #5348694 02/13/20 04:43 AM
W
OP Online Content
W
yeah maybe i will hold off and see if it grows on me. i got all this overpriced BS for free . door edge guards , pinstriping and the wheel arch moldings. i can't believe some folks really pay for this stuff
Re: removing wheel arch molding [Re: WhyMe] #5348715 02/13/20 05:37 AM
Online Content
I know, right?
Easy enough to install yourself if you wanted to later.
Once again, a good looking car so, congrats & best of luck. smile
"Retired"
Re: removing wheel arch molding [Re: WhyMe] #5349079 02/13/20 03:04 PM
9
928 Offline
9
If they are on like emblems, try dental floss, making a back & forth motion and keep it to the arch side.
Re: removing wheel arch molding [Re: 928] #5349122 02/13/20 03:52 PM
Carbuff Offline
Yup, and since you are in Rochester NY, pick a warm day, perhaps warm it up some more with a hair dryer or heat gun. (You should always be able to hold your hand on the metal, don't make it too hot) crzy
Atwell Haines
NJ
Re: removing wheel arch molding [Re: Char Baby] #5349149 02/13/20 04:31 PM
1
1978elcamino Offline
1
I would not recommend removing the glue with brake clean. In the past I have done something similar and used wd40 that I had laying around, it worked great and a final wipe with a microfiber left it looking as if there were nothing ever there.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: removing wheel arch molding [Re: 928] #5349156 02/13/20 04:48 PM
K
kstanf150 Offline
K
Good point, I’ve always found fishing line to be stronger and work very well
Re: removing wheel arch molding [Re: WhyMe] #5349513 02/14/20 12:37 AM
J
J_mo Offline
J
If you let it get warm, more than likely it will pull some of the double sided adhesive tape off when removing the molding. If not, that's ok. Grab yourself an eraser wheel, it goes on the end of your drill. It will remove the double sided tape and is completely safe for your paint. It will not burn, it will not discolor. Makes the job a breeze. I've used them on every vehicle I've owned to debage and or de-mold.
ABN Rubber Eraser Wheel 4in Pad & Adapter 1-Pack - Pinstripe, Adhesive Remover, Vinyl Decal, Graphics Removal Tool https://www.amazon.com/dp/B018WG2XYE/ref=cm_sw_r_cp_apa_i_t.JrEb6G6VD7T
2015 cummins 6.7 - DBL7349- eabp100- M1 5-40 TDT
2006 F-350 6.0 - Lf3656 - eabp110 - Rotella t6 / 5-40 M1 5-40 TDT
2018 Wrangler JL 3.6 (The lady's) under warranty - mopar mo349 - Valvoline Syn 0-20
Re: removing wheel arch molding [Re: Carbuff] #5349547 02/14/20 03:30 AM
Online Content
I think you got the wrong member. I'm in ROC and 928 is in SAC
"Retired"
