maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
107 registered members (1978elcamino, 28oz, alex_at, 01VFR, 928, 53' Stude, 3 invisible), 2,385 guests, and 17 spiders.
Topics301,904
Posts5,205,129
Members70,798
Diesel Oil Drip - Cleaning the driveway #5348620 02/12/20 10:39 PM
B
Bongos44 Offline OP
B
The old E300D MB drips on the driveway. I think I got the leak stopped, but the driveway looks like a Dalmation.
Any tricks on getting that soot laden Rotella T6 off the concrete?
1999 E300 D
2012 ML350 Bluetec
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348622 02/12/20 10:42 PM
spasm3 Offline
Soak it with simple green.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348644 02/12/20 11:17 PM
StarCaller Offline
first wd40, let it sit awhile, then dawn dishwasher detergent, rinse it /
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348655 02/13/20 12:25 AM
M
mcrn Offline
M
Pressure wash
2012 Nissan Rogue
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348685 02/13/20 04:09 AM
M
mker Online Content
Online Content
M
Dawn liquid detergent.
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348748 02/13/20 06:48 AM
K
Kira Offline
K
This is what I do....with success
I put Purple Power (the same as Simple Green I suppose) FULL STRENGTH in a small 8 oz. spray bottle with an adjustable nozzle.
I use pin point spray.
Then I boil water and pour it on the stain to heat it up (obviously)
Then just apply the Purple Power to the stain. THis is pin point with little over-shooting.
Since most spots take multiple applications I rinse with hot water too.
One trick is to do this on a rainy day so the dirty water runs off cleanly. However, you can spray hose water downhill from the stain.
Do it 2 or 3 times then look the next day for reapplications. You'll be amazed how well it works.
I learned this on my parents snowy white concrete drive. I COULDN'T be the one who spotted it up. To this day it isn't.
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348771 02/13/20 07:26 AM
R
Ride_Red Offline
R
I take dishwashing soap and drizzle it over the oil spot/stain until covered and leave it. On sunny days it ends up drying on the cement. I've found this allows the soap to penetrate all the way down into the stain. If I spray it with the hose too soon, it only gets it half way clean.
Next time it rains, the spot goes away. Been doing this for years. It's like magic.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348794 02/13/20 07:53 AM
Donald Offline
Dawn
2015 Ford F-250 w/Powerstroke
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348866 02/13/20 10:05 AM
Danno Offline
I use Tide powder detergent, sprinkle it over the spot, step on it to embed it into the driveway, next day, sweep into dust pan and put in garbage.
Somewhat more environmentally friendly than power washing into the sewers and then into waterways.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348933 02/13/20 11:32 AM
O
OLEJOE Offline
O
I use fireplace ashes on mine. The ash is so dry and fine it sucks the oil right up. It also is used to make lye which is a cleaning agent. I spilled 3 gallons of used diesel oil on my shop floor and you can't even tell it. I spread out kitty litter to soak it up and then used the ashes mixed with a small amount of dry cement and it's all gone. Try it and see if it helps.
Jack of All Trades. Master of some.
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5348945 02/13/20 11:48 AM
I
ironman_gq Offline
I
I hose it down with brake kleen (green can) and stomp in the kitty litter while it's still wet. Come back in an hour and sweep it up, works pretty well on the black diesel oil.
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5349001 02/13/20 01:01 PM
M
m37charlie Offline
M
All the above suggestions are good.
Another: have a dirt/gravel driveway.
I apologize in advance for the “jest”.
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5349019 02/13/20 01:28 PM
G
Gimpy1 Offline
G
Purple Power concrete and driveway cleaner. Its stronger than simple green and purple power which btw aren't the same. We use it all the time on our warehouse floor. You can also use purple powerband Foca powdered detergent. You can get Foca at any Hispanic grocery store, it's great for getting oily stains out of fabric too. Just make sure to wear gloves, strong degreasers will hurt your skin.
Re: Diesel Oil Drip - Cleaning the driveway [Re: OLEJOE] #5350310 02/14/20 08:54 PM
spasm3 Offline
That's a cool method! I Wii have to try it.
Re: Diesel Oil Drip - Cleaning the driveway [Re: Bongos44] #5350332 02/14/20 09:27 PM
B
Bongos44 Offline OP
B
Great suggestions, thank you all so much. Just got the Harbor Freight pressure cleaner.
1999 E300 D
2012 ML350 Bluetec
