school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
99 registered members (53' Stude, 28oz, 92saturnsl2, AdditionalD, 6 invisible), 2,313 guests, and 27 spiders.
Topics301,661
Posts5,200,132
Members70,751
Boxer engine 3xUOA: fuel dilution #5348579 02/12/20 09:27 PM
Sportbiker Offline OP
Have been tracking my Subaru WReX Premium oil situation because there are so many that burn oil. Clearly my pattern here is dilution so I'm hoping for some guidance on what to do next. Regularly driven in 7mi chunks, which I suspect is the majority of the problem because during the second test I made an effort to take it on longer road trips, rather than just the local, short ones. She is fed PUP 5w30 to keep her in warranty, but that's ending soon. WReX is driven reasonably spirited-ly. Only 3 UOA's done on it attached. No oil burn or loss appears to have started to-date.
Here's my thinking on options for next steps. Any others to consider? Can anyone offer an order of preference and reasoning? TIA
  • Drop OCI's to 2k miles and start using really cheap oil. May only change filter every other OCI as well.
  • Go to 5w40 and retest @3k OCI intervals.
Attached PDF document
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348609 02/12/20 10:15 PM
R
Rand Offline
R
Its a direct injected turbo engine so they can have fuel dilution issues esp in the winter short tripping but yours seems excessive.
7 miles esp in winter is not going to get the oil to temp.. no where close.
I'd go with a 5w40 and also try to get it out at least once a week for 30 miles one way.
Its basically going to a thin 20wt not ideal for spirited driving with a turbo engine..
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348778 02/13/20 07:37 AM
T
Trav Offline
T
This is very common with Subaru engines driven on short trips in cold weather, it doesn't seem to have any effects on longevity though. The high copper I suspect is from an oil cooler as lead and aluminum is low which would pretty much rule out main or rod bearings as the source of the copper.
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348780 02/13/20 07:38 AM
A
ARCOgraphite Offline
A
I'd call subaru about it. Seems excessive for a factory tune.
But, Do you have a tune also?
If so, tune LEANER.
I would move to an ACEA B4 0W30 to get to a higher HTHS.
And plan some more HW trips ( at no boost) to burn that fuel off.
And Commute the 7 miles at higher rpm / high vacuum reading - no boosting.
-Ken
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348833 02/13/20 08:51 AM
Ded Mazai Offline
Possible causes:
1. Low octane fuel causing retarded ignition. Ethanol fuel adds to the problem.
2. Spark plug are not in great condition. Because you normally drive short distances there could be deposits on the spark plugs.
3. A leaking injector. You may want to try a fuel system cleaner before going to diagnostics.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348947 02/13/20 11:48 AM
B
benjy Offline
B
subaru is relatively new to DI use so their tuning + setup may be an issue, but with many 5-30 fake synthetics being cheap IMO 4 to 5 bucks a qt in 5 qt containers if you intend to keep your ride a while just change oil + filter more often, DIY is cheap! after warranty a switch to a 10-40 would do well unless its a very cold winter
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5348998 02/13/20 12:56 PM
B
bulwnkl Offline
B
RLI’s (Renewable Lubricants) 5W40 was the magic for reducing consumption and fuel dilution in Subaru’s turbocharged EJ-25 series. Might be worth a try on these newer ones, too?
I can’t see the UOAs, though.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Boxer engine 3xUOA: fuel dilution [Re: bulwnkl] #5349165 02/13/20 05:02 PM
B
bluesubie Online Content
Online Content
B
3 OAI uoa’s with one showing 4% and two showing “>5%” via GC.
OP at the very least I would be running an ACEA C3 5W-30 or an HDEO 5W-30 like Rotella T6 MV.
Also, the owner’s manual has hints about thicker oil with 5W-40 on the temp chart and language that a thicker oil is required in high temps.
As mentioned, the fuel doesn’t appear do be causing elevated uoa wear, although IMO that does necessarily mean that you’ll never have an issue. I would definitely give your dealer a copy and ask them to add it to your file.
If you dig up the 2015 WRX uoa thread in the Service & Maintenance forum on nasioc, there are quite a few 2.0DIT uoa’s there. IIRC, 2-5% fuel via GC isn’t out of the ordinary for short trips. Actually, the 2.0DIT forum at subaruforester.org has a sticky with a lot of high fuel uoa’s as well. Quite a few of those have lots of idling in winter for warm-ups.
Any mods/tune?
'20 Subaru Outback Onyx XT | FF Idemitsu 0W-20
'04 Subaru Forester 2.5XT | Edge 0W-40
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5349324 02/13/20 07:45 PM
STIcandy Offline
Drive it. Alot. At highways speeds without overdrive (6th gear). That car has an oil temp gauge. Get it up to operating temperature and sustain it for at least half hour once a week. Otherwise change it every 3k in the winter and leg it out more in the summer when it's warmer and you're driving more.
FWIW, I just did a UOA on my brothers 2017 WRX. 9500KM OCI, Stage 1 Cobb OTS tune. This one is all highway but it's not babied.... [Linked Image]
Re: Boxer engine 3xUOA: fuel dilution [Re: bluesubie] #5349425 02/13/20 09:23 PM
B
bulwnkl Offline
B
That’s certainly ‘too much’ fuel. OTOH, BSLabs might only report that as “TR.” smile
Okay, even they would probably figure out there’s enough fuel to show a percentage. smile
Re: Boxer engine 3xUOA: fuel dilution [Re: Sportbiker] #5350550 02/15/20 07:42 AM
Just the fantastic feedback I was hoping for all. I'll definitely look for the referenced thread and give it a good read and get the dealer my UOAs. No mods/tunes on this, the wife won't allow it and its hers smile Glad to hear I was on the right track wrt running her on longer trips routinely. And a switch up to something heavier sounds good, I like the Rotella option since I've run that in the past with my race bikes and am familiar. I'll checkout other options in threads too, though.
I'll try to return in a year or two with a new UOA andjchanges I made for reference/contribution.
