Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
45 registered members (carlprop, 74Widebody, blufeb95, Bjornviken, bachman, 6 invisible), 1,070 guests, and 19 spiders.
Topics301,812
Posts5,203,167
Members70,784
What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? #5348218 02/12/20 02:53 PM
J
Jeep_Riot Offline OP
J
Will be doing a brake fluid flush on my Crosstrek in a month or so and I'm starting to research what I need. This will be a two-person flush, with one braking and the other managing the bleeder screw. What size clear tubing will I need to fit over the bleeder screw?
Thanks.
Re: What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? [Re: Jeep_Riot] #5348227 02/12/20 03:04 PM
Snagglefoot Offline
Don’t know if your bleeders are are any different from any other but in one You Tube video the guy used 5/16 OD by 3/16 ID clear plastic tubing with a small cable tie to snug up the end. I found that size combo was easy to find. smile
If you want the job done right......do it yourself.
Re: What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? [Re: Jeep_Riot] #5348419 02/12/20 06:22 PM
Dave9 Offline
You should measure the nipples, on both front and rear just in case they're different.
3/16" ID is a common size. If you get clear vinyl it stretches (until years of UV exposure harden it) and seals quite well (except in winter, the cold hinders that but merely holding it in your hand to warm it (or storing it in a heated area) helps a lot). Using vinyl I don't need any clamp or tie to make it seal on a bleeder screw nipple in reasonably good (non-corroded or sanded smooth on the perimeter sealing surface) condition.
Re: What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? [Re: Jeep_Riot] #5348971 02/13/20 12:19 PM
G
GlennDa5id Offline
G
Silicone hose works well for brake bleeding.
If you can splurge $13, this is the greatest brake bleeder catch can I have ever used. Schwaben 007481SCH01A.
Re: What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? [Re: Jeep_Riot] #5349154 02/13/20 04:39 PM
E
eyeofthetiger Offline
E
Yank the tubing out of your aquarium. Do the brake job real quick before the fishes die. Maybe rinse out the tubing before you put it back? Probably should just buy new tubing, eh.
coffee
Re: What size clear tube for flushing brake fluid on a 2015 Subaru Crosstrek? [Re: Jeep_Riot] #5350896 02/15/20 03:11 PM
Snagglefoot Offline
You definitely need to measure the bleed screw. Another popular size requires a 5/16 ID “ tube unlike the 3/16 “ ID tube discussed.
