Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
76 registered members (brages, 4WD, Astro_Guy, 2002 Maxima SE, Bailes1992, 8 invisible), 1,483 guests, and 20 spiders.
Topics301,732
Posts5,201,619
Members70,766
Page 1 of 4 1 2 3 4
2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere #5347843 02/12/20 06:46 AM
wemay Offline OP
https://valvoline-eu.lubricantadvisor.com/eng/Recommendation/bae17c63b24de02c8054a6259b441c94
Only 5w30, 5w40 and 0w40. Some carrying aces C3. Granted, I couldn't find an engine that matched the 174hp output.
Is Budack only a North American thing?
2019 VW Passat Wolfsburg TSI
VW High Performance Genuine Engine Oil 0W-20
OEM
2013 Hyundai Santa Fe Sport 2.0T
Shell Rotella Gas Truck 5W-30
OEM
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5347965 02/12/20 09:45 AM
B
Boomer Offline
B
Just buy the Castrol at the dealer or get it online. Mobil has a VW 508 oil as do several other manufacturers. I have a 2019 Passat with the 2 liter gasser and I only use the Castrol 508 oil 0W-20.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5347967 02/12/20 09:48 AM
A
ARCOgraphite Offline
A
I'm not sure Buddak has anything to do with it,
0W20 ACEA A1 B1, 508 00/509 00 ( also a 2.0L Porsche C20 spec.)
The French Motul I bought for my VW 1.4t was just "OK"
a typical majority PAO that needed something
else with it before it worked well.
I added some Magnatec 5W30 with stunning results.
Absolutely transformational. No Kidding.
There is no reason why a M1 EP or Castrol Edge Extended Performance wouldn't do the trick.
But, for Warranty and that pesky tracer dye that VAG specs....
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348031 02/12/20 11:14 AM
wemay Offline OP
I guess i assumed the Budack Cycle was the reason for the spec and wondered if the EU Passat used this technology as well. I have no issue with it running 0W-20 VW508.00 especially since i've seen a few UOAs that show it holds up just fine.
OEM
OEM
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: ARCOgraphite] #5348033 02/12/20 11:15 AM
wemay Offline OP
Plausible indeed.
OEM
OEM
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348071 02/12/20 11:58 AM
B
benjy Offline
B
if an oil is REQUIRED it must be furnished FREE otherwise just meet the spec!! 200 thou on my 2001 modified 1.8T 300 ft tq + 275 hp using real synthetic 10-30 oils, not todays fake inferior but cheaper offerings
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: benjy] #5348077 02/12/20 12:05 PM
B
BMWTurboDzl Offline
B
They don't require an oil brand. They require an oil weight/spec. Lack of green dye doesn't mean voided warranty, but instead indicates a reason to test the oil for lubricant related warranty repairs.
435i
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348098 02/12/20 12:33 PM
T
tundraotto Offline
T
...and having the green dye is part of that VW spec - if it doesn't have it - it doesn't meet the spec.
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: benjy] #5348108 02/12/20 12:49 PM
J
Jimmy_Russells Offline
J
That's like arguing a car has 17" wheels but you only want to pay for 15" tires, so they should provide the tires for free.
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: ARCOgraphite] #5348124 02/12/20 01:06 PM
G
geeman789 Offline
G
There is no reason why M1 EP or Castrol Edge Extended Performance wouldn't do the trick.
But, for Warranty and that pesky tracer dye that VAG specs ...
Or you could just get M1 0w20 ESP. It includes that pesky green dye ...
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348139 02/12/20 01:18 PM
M
mattwithcats Offline
M
Liqui Moly, Top Tech 6200, 0W-20...
5 liters, 20238
https://www.rockauto.com/en/tools/engine,oil,++++++++++++++++sae+0w-20,1001839
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348152 02/12/20 01:28 PM
A
A
Please somebody trash me for putting 5W30 Magnatec on top of a sump of
Motul Specific 508 00 !
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: wemay] #5348161 02/12/20 01:41 PM
E
edyvw Offline
E
99% of engines in the EU since 2009 are specd for C3. It is A3 equivalent, just lower SAPS.
0W20 is American thing mostly. EU manufacturers are experimenting with it in EU for some time, but it is not gaining traction, mostly since CAFE does not exists in EU. EU calculates emission requirements differently and lighter oils are really no advantage in that case. So, yes, EA888 are still specd. for VW 504.00/507.00 and yes, you could use it in your engine.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: ARCOgraphite] #5348163 02/12/20 01:41 PM
B
BucDan Offline
B
Terrible idea. Not part of the spec. How dare you?!
I'd go Motul Specific as well out of fanboy-ism.
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
Re: 2018-19 Passat. Valvoline EU recommendations. 0W20 is nowhere [Re: edyvw] #5348200 02/12/20 02:33 PM
wemay Offline OP
We've beaten this horse a few times. The manual is pretty strict with respect to 508.00 being the oil used. Other 0W-20s and/or other VW spec'd oils can be used for top-up, but only half a quart.
OEM
OEM
Page 1 of 4 1 2 3 4
