Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Dishwasher makes crackling noise
by jayjr1105 - 02/19/20 05:33 PM
what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
123 registered members (77GrandPrix, 1978elcamino, 53' Stude, 4WD, 55hambone, 9 invisible), 2,319 guests, and 21 spiders.
Topics301,663
Posts5,200,189
Members70,751
Traveler conventional 10w30 #5347739 02/11/20 11:28 PM
M
Mightymouse Offline OP
M
Did a search and found a little bit of info on it, mostly speculation about who makes it and all and nothing recent. Anyway I have a Ford 2.3 that was apparently taking in alot of unfiltered air (found a large hole torn in the fresh air intake hose). I figured I will just assume it's overly contaminated and do a few short intervals to help get rid of any extra dirt/silicone. Maybe do a few 3k intervals with a cheaply priced conventional and save the cost of having UOAs done. I saw this oil at tractor supply for $9 a 5 qt jug of 10w30. That's the grade I've settled on anyway for this car.
So anyways to finally get to my point, just curious if anyone has some up to date info on it? The jugs have a born on date of Jan 2020 so it's definitely the latest blender and formula.
Re: Traveler conventional 10w30 [Re: Mightymouse] #5347742 02/12/20 12:10 AM
O
OilUzer Offline
O
API?
Also what is the definition of latest formula? Date has nothing to do with formula. Sounds like it's a basic dino oil.
Re: Traveler conventional 10w30 [Re: Mightymouse] #5347774 02/12/20 02:28 AM
M
Mad_Hatter Offline
M
As cheap as it is you should consider doing a $15 VOA on it for BITOG?
Re: Traveler conventional 10w30 [Re: Mightymouse] #5347815 02/12/20 05:46 AM
P
passgas55 Offline
P
I bet it meets a SN spec and if it does I would use it for a 3k change without any worry. Just look on the back.
Re: Traveler conventional 10w30 [Re: Mightymouse] #5347958 02/12/20 09:38 AM
J
jeepman3071 Offline
J
The Traveller 10w30 conventional I've bought was rated SN. Used it in mowers/other small engines without issue, but can't comment on any other specs unfortunately. It should work well for 3,000 intervals.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Traveler conventional 10w30 [Re: OilUzer] #5348145 02/12/20 01:23 PM
M
M
Originally Posted by OilUzer
API?
Hmmm, not everything in life has to be complicated. Unless you think you always need to try and sound smart at the expense of others.
A jug dated less than a month from present would indicate to me that that product is probably what ever current formula is being blended by what ever current blender is blending it.
Re: Traveler conventional 10w30 [Re: Mightymouse] #5348150 02/12/20 01:27 PM
B
bullwinkle Online Confused
Online Confused
B
It's made by Warren Distribution, makers of Mag 1, (formerly in some cases) Super Tech, and plenty of other house brand oils, I'm sure there's nothing wrong with it, although a UOA after your recommended OCI is always not a bad test.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Traveler conventional 10w30 [Re: Mightymouse] #5348155 02/12/20 01:36 PM
T
tundraotto Offline
T
There are multiple VOAs here on Traveler branded oils and they have all looked fine.
Re: Traveler conventional 10w30 [Re: bullwinkle] #5348506 02/12/20 07:55 PM
M
M
Warren distribution is well regarded around here I've learned. so that's a plus.
I've used the supertech quite a bit. No noticable problems. Currently have it in the vehicle I was speaking about. Thanks
Re: Traveler conventional 10w30 [Re: tundraotto] #5348510 02/12/20 07:56 PM
M
M
Ok cool, I'll check those out. Thanks
