what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
117 registered members (55hambone, 4WD, 1978elcamino, 53' Stude, 97prizm, 8 invisible), 2,307 guests, and 19 spiders.
Topics301,661
Posts5,200,168
Members70,751
Page 1 of 3 1 2 3
Honda Owner's Manual Gripe #5347389 02/11/20 04:52 PM
G
Gebo Offline OP
G
I know very little about newer Hondas. Say from 2000 up. I am working on a 2008 CR-V doing the oil change, PS change, ATF change, spark plug change at this moment in time. This is my first experience with a newer Honda. I go to the Owner's Manual and I can't find diddly squat. I can't find what spark plugs, what ATF, maintenance schedule, timing belt (?), etc.....
I am not stupid. I do often recognize my ignorance. Is there something wrong with me not being able to find out when to change the spark plugs? I did see to change the ATF at 30K if you tow so that means every 30K to me.Is there a maintenance schedule in the manual? Maybe the owner is missing a book???
I will be keeping up with this maintenance for a long time so it would be nice if I had a piece of paper in this cars maintenance folder in my basement.
Maybe I have been spoiled by having Toyotas (albeit older ones) where they gave you all this info. Maybe now the mfr try to make you bring it into a dealer. IDK??
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347392 02/11/20 04:55 PM
DBMaster Offline
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347393 02/11/20 04:58 PM
skyactiv Offline
Some vehicles come with a supplemental booklet regarding maintenance intervals and technical bits.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347394 02/11/20 04:59 PM
slacktide_bitog Offline
Your 2008 CR-V doesn't have a timing belt. It has a timing chain, so it doesn't have to be replaced at regular intervals happy
Honda uses the maintenance minder, which derives the right OCI for you from your driving conditions. It also tracks when it's time to change the transmission fluid, spark plugs, coolant, air filter, cabin filter, and the timing belt on cars that have one (but thankfully, yours doesn't).
They started using the minder around 2006 or so. A few years ago, Honda added brake fluid to the MM, but before that, and including your 2008, it just says to change the brake fluid every 3 years regardless of mileage, but realistically, you can get away with doing it when you replace the pads and rotors.
Honda does not publish a set schedule anywhere. Dealers worth going to for service will tell you this. The shadier ones will make up a schedule to get you in there more often.
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347407 02/11/20 05:05 PM
J
Jim_Truett Offline
J
Doesn't the maintenance section start on page 271 in your owner's manual? It's all detailed in there. Notifications come through the maintenance minder.
2008 F250 6.4 PowerStroke 52k
1963 Nova SS 84k
2008 GMC Yukon Denali 195k
2013 Mahindra 3016HST 128hrs
2008 Honda CR-V 96k
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347438 02/11/20 05:46 PM
J
JeffKeryk Offline
J
Gebo, you have the largest, most completest, most everythingest user manual in the known universe right here on BITOG.
BITOG will answer everything with all kindsa answers. No worries.
Forget what Honda sez; we know better.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347454 02/11/20 06:02 PM
G
Gebo Offline OP
G
My man, JeffKeryk....
XOXOXO in a very heterosexual way. cheers
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347458 02/11/20 06:06 PM
G
Gebo Offline OP
G
Now I get it. There is no written schedule. It's all through the "maintenance minder". Do the new Toyotas have the same type setup? The newest car I have is a 2007.
I ain't letting no car tell me when it needs to be maintained. Might was well break out my legal pad and get to work setting up "my" schedule.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347459 02/11/20 06:07 PM
J
JeffKeryk Offline
J
AA meetings for me Gebo. Maybe some dead coffee....
Have fun with that rock-n-roll CR-V.
You are doing your neighbor a good turn.
2018 Lexus RX450h
2006 Acura TSX
Re: Honda Owner's Manual Gripe [Re: JeffKeryk] #5347464 02/11/20 06:13 PM
G
Gebo Offline OP
G
I don't drink alcohol either. I was an alcoholic. Let's just pretend it's root bear.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347495 02/11/20 06:41 PM
J
JeffKeryk Offline
J
Not a drop in 33 years...
2018 Lexus RX450h
2006 Acura TSX
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347522 02/11/20 07:02 PM
B
benjamming Offline
B
Our 2016 Toyota Highlander lists the maintenance schedule in the owner's information.
Are you going to buy a factory service manual (Helm) for that vehicle?
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347545 02/11/20 07:36 PM
H
hallstevenson Offline
H
But a piece of paper (from the manufacturer) is any different ?
Re: Honda Owner's Manual Gripe [Re: Jim_Truett] #5347549 02/11/20 07:38 PM
H
H
"Like"
Re: Honda Owner's Manual Gripe [Re: Gebo] #5347599 02/11/20 08:24 PM
B
Brybo86 Offline
B
I have the service manual for my 2008 Accord 2.4, same engine as the crv, not sure how I could get it to you, BitTorrent mb?
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Page 1 of 3 1 2 3
