Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
113 registered members (28oz, apollo18, 2013ecof150, 2012AccentSE, alchargo, Anduril, 5 invisible), 2,300 guests, and 19 spiders.
Topics301,901
Posts5,205,040
Members70,798
3.6L Pentastar Screeching W/Engine OFF #5347378 02/11/20 04:44 PM
M
Mathew_Boss Offline OP
M
Please watch the video for noise here
https://youtu.be/iUAC1kNH2F0
Engine has been off for about 45 Min and it's still making the noise. 67k miles on a 2015 Charger
1.7k Mile 2019 Toyota Highlander LE Plus AWD 3.5L 2GR-FKS. PP or EDGE EP 0W20 w M1 or RP Filters
66k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum, QSUD or EDGE EP 0/5W20, or 5W30
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347399 02/11/20 05:01 PM
B
buddylpal Offline
B
That is a common sound on many new cars these days. The Chevy Malibu, Hyundai Sonata, Dodge Challenger and Charger are all cars off the top of my head that have this documented noise. I haven't heard what actually causes it. Some theories on the R-1234YF refrigerant pressure expansion, the radiator cap, or the keyless access receiver. Doesn't seem to be an issue though.
My guess is the R-1234YF pressure expansion, these noise complaints started appearing on cars that use the new ac refrigerant it seems. Just my guess!
A couple GM's and a Hyundai.
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347423 02/11/20 05:32 PM
N
nthach Offline
N
Some cars will do an EVAP test when the engine is off and a amount of time passes. The HVAC system shouldn't make funny sounds when the car is not running with a stopped compressor, some cars don't have compressor clutches but will use a solenoid to vary compressor displacement depending on HVAC load.
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347473 02/11/20 06:19 PM
sloinker Offline
All of my cars make random noises when they are not running, sometimes as I approach with the fob. My TDI's sometimes will have the cooling fans run for up to ten minutes. Obviously in the regeneration phase when I parked. The noise the OP has is unlike anything I have heard on my Pentastar '14 model minivan.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347477 02/11/20 06:25 PM
Skippy722 Offline
My 300 makes a noise like that sometimes, usually within 5 minutes after I shut it off. It’s pretty quiet though. Everything still works, maybe it’s the circulation door moving?
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347479 02/11/20 06:27 PM
T
The_Nuke Offline
T
Both my Challengers made a screeching noise and so does my Charger, but none did it with the engine off. In fact they could only be heard when the engine was at WOT...
In my case the source of the screeching turned out to be my wife.
Not surprisingly, the screeching went away once I stopped taking her for test drives. grin2
As for this screeching, IDK...sounds like one of those surprise scenes in a horror movie. shrug
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347531 02/11/20 07:12 PM
dishdude Offline
Is this a new noise or has it always made it? Agreed it could be a test of the evap system.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: dishdude] #5347533 02/11/20 07:19 PM
M
M
I have never heard it before. It didnt do it about 3k miles ago when I changed the oil last. I though the neighbor was running a grinder when I was filling the washer fluid. Walked to the garage door and heard it behind me. Narrowed it down to the area of the engine I held the phone at to record it.
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347664 02/11/20 09:14 PM
dishdude Offline
What good is this forum if every time someone asks a question the only responses they get are bashing the brand?
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: dishdude] #5347675 02/11/20 09:27 PM
I
Imp4 Offline
I
Well I think the self evident answer is that the forum becomes a pretty bad place to ask a question about an FCA product with a quality concern.
Now, if there's all these people that are doing it, then at some point you need to ponder, even if it's only to yourself, whether or not the group is on to something...
One way around the whole topic is for FCA to produce such high quality cars across their entire lineup that the public has no other choice than to say:
Originally Posted by NearlyEveryResponsibleDadEver
Man, I gotta get me one of those FCA products! They're just so darn dependable. My teenager can just thrash the thing nearly to death and it just keeps starting every morning and I can still trust it to get the kid to school.
Until that day comes, people will post topics about their late model Chargers making screeching sounds nearly a hour after being turned off and, more importantly, I think FCA will continue to bear the yoke of the quality reputation they've earned.
Cheers!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347705 02/11/20 10:13 PM
sloinker Offline
The Mopar booster club used to meet every week. The problems started almost immediately as everyone knows that Mopar owners are always bad guys and swing a large pair wherever they may roam. The Toyota club fellas tried to sneak into our get togethers almost every week. We ex-filtrated them fairly quickly what with their mama's riding shotgun and their panty lines showing above their low riding jeans. The club was eventually dissolved when one Toyota driving imposter was overcome with testosterone fumes and had to be transported by his sister to the nearest whole foods to recuperate. RIP Mopar club of Badazzes.
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347716 02/11/20 10:26 PM
K
KrisZ Online Content
Online Content
K
Sounds like a servo motor to me. While I never heard this type of noise from my 15 Grand Caravan, my Mazda 3 will make a similar type of noise after shortly after being shut off from the drive by wire throttle body.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Imp4] #5347726 02/11/20 10:38 PM
O
OVERKILL Offline
O
It's how it's received, which actually played out like clockwork in this thread.
Literally 2nd post in this thread:
Which everybody completely ignored and the anti-FCA trolls showed up and then the pile-on begins. That's how it ALWAYS goes, even if its just a basic question about how somebody likes their vehicle, somebody's sister-cousin from the hills of Tennessee, her uncle-dad's first wife's father from the Hinterland once had a Dart, and it didn't have a big block, so it was a pile and nobody in that entirely branchless family tree ever bought another Chrysler product again.
Comparatively, there's a thread about a Toyota with a transmission that shifts like a tweaker on meth and "it's all fine" it's just "buggy software" Toyota will take care of you or "that's unusual my 1982 Corolla was perfect, Toyota is the best".
The direction the threads take are COMPLETELY different. It's not because the FCA topics are comparatively awful, it's because you have the same group of soiled knickers sliding in and turning it into the monkey cage at your local zoo.
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347731 02/11/20 10:48 PM
T
tiger862 Offline
T
Check the PCV valve. Some are building up pressure and released pressure goes past oil cap. Easy way to check is pull oil cap and see if excessive pressure when removed after shutdown. I know mine makes noises after it is shutdown but that is normal as ac motors reset to closed position but normally heard inside. Only other thing I think of is ac is overcharged so when shutoff it releases excess pressure.
Tiger862
2018 Grand Caravan
Re: 3.6L Pentastar Screeching W/Engine OFF [Re: Mathew_Boss] #5347761 02/12/20 01:57 AM
E
Exhaustgases Offline
E
Where is the noise coming from? In car, under hood, under the car? It all happened so fast. At first sounded like starter not engaging but not loud enough, and that was before reading.
