Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
110 registered members (762fermeandyou, 4WD, alanwayne1908, 53' Stude, Aichiguy, 13 invisible), 2,642 guests, and 38 spiders.
Topics301,519
Posts5,197,184
Members70,712
what to use in '18 dodge journey 2.4 in warranty #5347347 02/11/20 04:14 PM
K
kmrcstintn Offline OP
K
'18 dodge journey, 2.4L, in warranty, currently using dealer free oil changes; afterward I gonna do DIY oil changes in warmer weather...gonna stick with ms-6395 certified oils (QS, Pennzoil, Valvoine...conventional or synblend 5w-20 for 4.5k-5k mile oci); what oil filter would you use in this application? thanks...
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347355 02/11/20 04:22 PM
I
Imp4 Online Content
Online Content
I
Opinions will run the gamut from soup to nuts.
My advice is to do some research, choose something that's not the cheapest and not the most expensive.
Carry on with your life.
Cheers!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347365 02/11/20 04:34 PM
N
nthach Offline
N
For 5K intervals, use OEM, Fram EG/TG, Wix, doesn't matter. I assume that Mopar engine uses the same PH3614/Wix 51348/Puro 10241 sized filters they've been using for a while on their non-Mitsu 4-cylinders but don't quote me.
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347472 02/11/20 06:18 PM
K
K
oem nomenclature escapes me...the fram nomenclature is 10060; best i remember mopar oem is 'puro-tear-alot' which is why i am asking for opinions on what to use
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347486 02/11/20 06:31 PM
K
K
oem nomenclature escapes me...the fram nomenclature is 10060; best i remember mopar oem is 'puro-tear-alot' which is why i am asking for opinions on what to use; supertech claiming 10k mile filter life but no dedicated bypass valve...guess its a combo bypass/anti drain back; ac delco is similar with actual fram type bypass valve...but also the crazy offset base plates;
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347492 02/11/20 06:36 PM
doitmyself Offline
Wix 57060/NAPA Gold 7060 or Fram XG10060 (Overkill @ 5K OCI) will both work fine. If you are budget minded, watch for NAPA sales and stock up. Mopar OEM filters seem to go back and forth between Purolator and Wix, so maybe check one out at Wally World.
I use Pennzoil Platinum 5w20 in my 2.4L GEMA engine (not Tigershark). I almost always get a $10 rebate and it works well beyond 6K OCI's. This somewhat "sewing machine" noisy engine runs great on the PP.
FYI, this Dundee Michigan built engine is very reliable and oil consumption is nil. It is considered dated compared to more modern engines and doesn't put out the performance of more modern engines. I'll take reliability over performance every day.
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347642 02/11/20 08:51 PM
M
Mightymouse Offline
M
Mopar can be had at Walmart.
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5347672 02/11/20 09:24 PM
K
K
i believe mine is also the older 'world' engine with mercedes-bases vvt...lots of thermo polymer parts on top;
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5348110 02/12/20 12:49 PM
N
nthach Offline
N
It's the GEMA engine - which was a collaboration between Mitsu and Hyundai. I think it's now called the Tigershark by FCA.
Interestingly, the Hyundai/Mitsu engines uses a PH9688/51334 filter with M20x1.5 threads and different control systems - a GEMA variant on the Mitsu side made its way into the Lancer Evo.
Re: what to use in '18 dodge journey 2.4 in warranty [Re: kmrcstintn] #5348246 02/12/20 03:28 PM
SlavaB Offline
If you’re concerned about the warranty just use OEM parts. Whatever they say, in case of a claim it’s gonna be you vs dealer and good luck trying to get some help from oil filter manufacturers
17 Kia Sportage EX 2.4 GDI / Castrol Magnatec 5w30, OEM filter
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
