Originally Posted by JohnG
Worked in oil delivery terminals since 1973. The tubes on the trailers were present then just as they are now, and I'm not just talking California. Pennsylvania, Ohio, WV, MD they were all the same. We are talking trailers though, maybe the small trucks would vary a bit, but stations are not normally delivered by trucks smaller than 8000 gallon tankers.
Not sure what you mean by smaller than 8000 tankers. A typical 18-wheeler fuel tanker trailer has between 9000 and 9600 gallon capacity. 10-wheeler straight trucks are closer to 5000 gallon capacity. Those trucks occasionally do gravity drops with the 4in diameter hose, but mostly use an on-board pump with a hose on a reel.
Dedicated oil delivery tankers would obviously need to cap their hoses and even isolate them from the environment...hence why most of them would have tubes on the sides. Whenever fuel tanker drivers make a diesel delivery, we just cap the hose that was used due to the residue diesel leaves behind in the hose. Road grime, etc obviously would stick to the "wet" residue like you would expect. If the delivery was gasoline, it simply gets tossed onto the hose tray.
Every fuel tanker trailer I've ever seen has open trays we sit the hoses in that are strapped down via a common bungie strap. Gasoline residue is often evaporated before I even get the paperwork signed and pull out of the store lot. Of the hundreds and/or thousands of fuel tankers I am around every day...I've NEVER seen one with tubes to store hoses in. Dedicated tankers for AVGas, jet fuel, kerosene, oil and other specific petroleum products often DO use trailers with those tubes. Not gasoline/diesel tankers.
