How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
115 registered members (1978elcamino, 2015_PSD, 28oz, Anduril, 750IX, 2013ecof150, 4 invisible), 2,475 guests, and 20 spiders.
Topics301,902
Posts5,205,056
Members70,798
Gate chain grease/lube #5347269 02/11/20 02:45 PM
BeerCan Online Content OP
OP Online Content
I have an automatic gate that has about 15 feet of chain that I think I should lube. It's looking a little rough.
Any ideas on what I should use on this? The gate operates all day during business hours. It rains a lot here and I would need something that won't drip down on to the pavement when its hot.
Thanks
[Linked Image]
[Linked Image]
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: Gate chain grease/lube [Re: BeerCan] #5347286 02/11/20 03:01 PM
I
Imp4 Offline
I
Blaster Chain and Cable Lube is pretty good stuff.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Gate chain grease/lube [Re: BeerCan] #5347288 02/11/20 03:05 PM
doitmyself Offline
I have zero experience with your request, but will start out the thread anyway! I would imagine that bicycle and/or motorcycle people will have good advice.
If that were my problem, I would figure out a way to clean the chain first. Either remove it or concoct a way to clean it as mounted. A bath in mineral spirits or WD 40 should do the trick. You probably should clean the chain annually or as needed.
Then, choose your chain lube of choice. I probably would avoid a graphite lube due to how dirty they are (black residue).
This one might work - water insoluble, goes on thin to penetrate, then thickens up, anti-fling: https://www.datocms-assets.com/10845/1562019086-specialistrollerchaintds.pdf
I'm interested on what others will recommend.
Re: Gate chain grease/lube [Re: BeerCan] #5347297 02/11/20 03:15 PM
A
ad244 Offline
A
What about some heavy duty moly based Grease? Low RPM but high pressure
Re: Gate chain grease/lube [Re: BeerCan] #5347325 02/11/20 03:46 PM
Chris142 Online Content
Online Content
Chain wax.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Gate chain grease/lube [Re: BeerCan] #5347341 02/11/20 04:07 PM
Convert Offline
Try Bel Rea motorcycle chain lubrication,It has a waxy substance that will dry similar to a lightweight Vaseline type consistency ,last pretty good on motorcycles doing a hundred miles an hour to change shouldn't have a problem and it doesn't wash off easily.
Can be purchased at motorcycle shops or at Cycle Gear motorcycle accessories,
Local.purchase or to their web site.
Convert
TOMB
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
USAF 1966-1970
Re: Gate chain grease/lube [Re: BeerCan] #5347358 02/11/20 04:24 PM
B
Bebop367 Offline
B
I would use Fluid Film.
Re: Gate chain grease/lube [Re: BeerCan] #5347367 02/11/20 04:34 PM
P
Panos Offline
P
Just apply some oil using a brush and repeat after every rainy day and you will be perfect. It won't drip if you don't use a ton. You can use used or new motor or gear oil. Your choice, it won't make a difference.
That's what I've been doing in my motorcycle chains for 6 years and 50K+ now. Zero cost, maximum protection.
Ford Fiesta 1.6 '05 - Motul specific 913D/Motul Gear 300 180K+ Kms
Kawasaki Ninja 250R '08 - Shell Advance Ultra 4T 10w40 75K+ Kms
Honda CBR600F pc41 '14 - Motul 7100 10w30 25K+ Kms
Re: Gate chain grease/lube [Re: BeerCan] #5347398 02/11/20 05:00 PM
spasm3 Offline
I would be temped to try this, can't be worse than what you have.
https://www.amazon.com/WD-40-Specia...ine+grease&qid=1581461965&sr=8-5
[Linked Image from images-na.ssl-images-amazon.com]
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Gate chain grease/lube [Re: BeerCan] #5347412 02/11/20 05:12 PM
DBMaster Offline
This works well for me...
Sprayon Chain Lube
The link is not necessarily for purchasing. I got mine on eBay. This is just to show the product.
Re: Gate chain grease/lube [Re: BeerCan] #5347443 02/11/20 05:50 PM
spasm3 Offline
Whatever grease you use, i would spray it down with a 50/50 atf/ acetone mix and wire brush it , get all the loose rust off you can. Rinse with diesel fuel or old kerosene. Other wise the grease is going to hold all the rust that's flaking off now and it will eat up the sprocket and chain.
Re: Gate chain grease/lube [Re: spasm3] #5347618 02/11/20 08:36 PM
F
faltic Offline
F
atf
19 Tacoma 3.5 2wd AT. Under 1K
17 Highlander 3.5 2wd AT 20k+
07 EX250 21k+
09 EN500 11k+
11 PCX 125 5K+
Re: Gate chain grease/lube [Re: spasm3] #5347791 02/12/20 04:12 AM
B
berlyn Offline
B
Couldn't agree more. Correct preparation is key in this case before applying the grease layer.
Re: Gate chain grease/lube [Re: BeerCan] #5348069 02/12/20 11:56 AM
N
nthach Offline
N
Motorcycle or bicycle chain lube - try Bel-Ray or Lucas for the former, and DuMonde Tech/Rock & Roll/Boeshield T9 for the latter.
Re: Gate chain grease/lube [Re: BeerCan] #5348474 02/12/20 07:12 PM
OP Online Content
Thanks guys. No way am I going to clean up this chain in any serious way 😁. I'm going to lube it up and hope for the best. It's a very old chain and has a bit of stretch. Eventually I will change it but wanted to care for it until I do. I seriously think the chain is from 1989
