Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
43 registered members (Aichiguy, 97prizm, blufeb95, 74Widebody, Bjornviken, 4 invisible), 1,067 guests, and 23 spiders.
Topics301,812
Posts5,203,168
Members70,784
Engine oil filter used upstream of electric oil pump #5346969 02/11/20 08:49 AM
R
ReillyRacing Offline OP
R
Hello everyone,
I am developing a manual transmission cooler kit for a specific application. The transmission does not have any internal mechanical pump for an external cooler, so an external electric pump will be used.
I would like to filter the fluid BEFORE it goes through the pump, both for the pump's sake and the transmissions. For ease of serviceability, i would like to use a [high quality] spin-on oil filter (probably the smallest one I can find, such as from a motorcycle). I do not want to use the inline-style filters as i am pretty sure you have to remove oil lines and completely uninstall it to take it apart & clean it.
I am researching what the downsides / risks are associated with PULLING oil through a filter rather than PUSHING it through.
Some considerations:
- The manual transmission fluid used is a 90 weight gear oil, which, when up to temperature, is essentially the same viscosity as 30 weight motor oil.
- The electric pump with be on a temperature switch, so it will not turn on until the oil is at / above normal operating temp.
- The filter and pump will both sit below the fill line of the gearbox, so they will always be full of oil when the pump turns on
- The electric pump pushes a low volume of fluid (compared to an engine oil pump), approximately 1.0gpm
So I'm looking for:
-Specific data on what happens when you PULL oil through a filter instead of PUSH it.
-Any other suggestions for an inline filter that is easily serviced without taking the whole thing apart.
Re: Engine oil filter used upstream of electric oil pump [Re: ReillyRacing] #5346985 02/11/20 09:02 AM
A
ARCOgraphite Offline
A
deleted
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Engine oil filter used upstream of electric oil pump [Re: ReillyRacing] #5346986 02/11/20 09:04 AM
T
tcp71 Offline
T
How about a metal can, 3/8” nipple magnefine transmission filter. Should do fine regardless of pull/push configuration.
https://magnefinefilters.com/
[Linked Image]
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Engine oil filter used upstream of electric oil pump [Re: ReillyRacing] #5346996 02/11/20 09:19 AM
R
Ride_Red Offline
R
Most pumps are rated to deliver pressure.
You will need to make sure whatever pump you purchase is rated for suction and self-prime.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: Engine oil filter used upstream of electric oil pump [Re: ReillyRacing] #5347013 02/11/20 09:44 AM
CT8 Offline
A PH8a sized filter base kit would be a good size and the simplest design would be a Differential cooler kit.
2015 F150 2.7
2018 F350 6.2
Re: Engine oil filter used upstream of electric oil pump [Re: ReillyRacing] #5347051 02/11/20 10:27 AM
M
Mightymouse Offline
M
Interesting,
Probably best to go with a hydraulic filter that has high pore density.
Re: Engine oil filter used upstream of electric oil pump [Re: Ride_Red] #5347227 02/11/20 02:10 PM
Z
ZeeOSix Offline
Z
I'd suggest setting up a simple bench test to see how the pump performs while sucking gear oil at temp.
Re: Engine oil filter used upstream of electric oil pump [Re: ZeeOSix] #5347701 02/11/20 10:09 PM
R
R
Good idea.
The pump I'm considering using is designed to be an electric turbo oil scavenge pump, so I think I'm on the right path
