Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
92 registered members (alex_at, ajchien, asleepz, b1amgm47, 1978elcamino, aquariuscsm, 8 invisible), 2,373 guests, and 20 spiders.
Topics301,908
Posts5,205,191
Members70,798
Chevy 6.0L Spark plugs #5346584 02/10/20 06:57 PM
E
Eric Smith Offline OP
E
On the last trip in the RV on startup there was a slight miss, could clear up pretty quick (no codes). Only has 71k but is 15 years old so everything is factory. Rockauto nor OReillys list a AC-Delco Iridium plug so I figured it was a double platinum like our other cars around the same year. I was wrong! 41-985 is the factory plug but from what I've read 41-111 is the replacement. The problem is I've already ordered 41-962's off of Ebay. Also ordered AC-Delco's wires. Might of wasted a bit of money but everything has to come apart anyways since there's a broken manifold bolt on each side.. that may be for another thread.
Pretty sure I'm just going run the 41-962's as I doubt there will be any difference. Unless anyone can change my mind.. NGK from google research is what a few run in their 6.0L's but I really prefer to run AC-Delco plugs.
05 Chevy 3500 (Class C RV) 66k
04 Escape 166k
02 Focus 145k
00 Dakota 93k
91 Festiva 257k .. Rust bucket
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346594 02/10/20 07:08 PM
Chris142 Offline
The miss when cold is likely the intake manifold gasket.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346601 02/10/20 07:14 PM
P10crew Offline
If you have access to a mig welder and can get to the side of the heads with it the exh bolts are a simple deal once you get it apart.
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346603 02/10/20 07:15 PM
slacktide_bitog Offline
If the job is difficult on your RV, you may want to consider NGK ruthenium, so you never have to do them again. Pair them with the NGK wires which are numbered and come in a nice blue color smile
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346639 02/10/20 07:42 PM
M
mattwithcats Offline
M
RockAuto has the 41-111 AC Delco plugs, you just have to look for them...
https://www.rockauto.com/en/parts/acdelco,41111,spark+plug,7212
Look on NGK Canada web site for a list of plugs...
https://www.ngksparkplugs.ca/part-finder.cfm
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Chevy 6.0L Spark plugs [Re: mattwithcats] #5346645 02/10/20 07:57 PM
H
hedge1 Offline
H
Pardon my lack of know-how on where best to ask questions about my 5.3 AFM problem. When I found this site I read about similar problems others are having/had.
I recently bought a 2007 Avalanche with 5.3 AFM. Previous owner installed headers, removed catalytic converters and installed a loud Magna Flow muffler which I replaced with a fairly stock muffler to reduce the drone. I've had several codes thrown – obviously both O 2 sensor bank codes due to no catalytic (Check Engine Light); lean codes; and the latest being PO308--#8 misfire. It has been backfiring on deceleration/coasting. After reading everyone's posts, I assume I have a bad lifter. I also assume it would be best to not drive it until it's fixed--right? I plan on disabling AFM and ask for suggestions/advice on whether to buy my own tune device or pay the $200 fee to have it professionally done but with no future option to change things up like with the self-tune option. What's the current best way to go since most of the posts I read here were fairly old. If it’s best to buy my own--I know there are several—which one would be best? Diablo, Range, Hypertech, other? Thanks.
Also please advise on the correct place to ask my questions.
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346670 02/10/20 08:19 PM
ls1mike Offline
Eric,
If you have not done you intake gasket, it might be time. There is an updated one. Miss when cold in my old truck was the intake gasket.
Run the 962s you will be fine. I have ran all kinds of stuff in mine. I have settled on the NGK TR-55s in the WS6 and Caprice. The old truck had a set of 962s
There is a TSB about running the 962s in a nut shell it said they were good to go for LS applications.
As to the broken bolts. I like to fix stuff correctly too, but in the interest of time and in your case maybe lack of space you can use those brackets that screw into the head and apply pressure to the manifold. They work great, had them on my old 6.0 truck for 3 years. It was a lot easier than getting the bolt out. I know a few guy who have been running them for over 200,000 miles. Since it is only the RV these brackets are great. It is usually the front two or rear two on either side that break off. That is what these brackets are for.
Clamp Video
Amazon Clamp
First thing I did when I got my 2017 is pull the stock exhaust bolts and put ARP in. The new manifolds do have a better fastener and manifolds are split between ports to allow for expansion and contraction.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Chevy 6.0L Spark plugs [Re: hedge1] #5346673 02/10/20 08:24 PM
ls1mike Offline
What do you mean disable AFM? If you mean tune it out, sure, but it won't prevent a mechanical failure later down the road. It sounds like you already have one.
Your best bet is to find someone who can delete it mechanically then you are looking at 500 bucks for a correct tune.
Hand held tuners are fine for turning it off but it won't prevent a failure.
Here is a typical AFM delete kit.
AFM delete kit
You are looking at 2500 to 3000 dollars to have it done correctly, if you can't do the work yourself. If you have a bad lifter the heads have to come off.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346676 02/10/20 08:28 PM
ls1mike Offline
Found it.
date: May 21, 2013 Bulletin Number: 13D-070
Subject: AC Delco Spark Plugs 41-110 and 41-962 - Application Update
Description:
AC Delco announces that 2006 and older, as well as some 2007, spark plug service applications covered by the Iridium spark plug 41-110 have moved to the Double Platinum plug 41-962. For the older model years, GM used a Double Platinum spark plug in production, and these older applications are to be serviced with the Double Platinum plug 41-962. 2007 and newer applications used Iridium plugs in production and service requirements will remain assigned to the Iridium plug 41-110.
Both plugs meet original equipment specifications for the applications designated. Catalog changes for the Epicor and WHI systems will be updated in the June release 2013. AC Delco recommends you begin adjusting your stocking requirements for the
41-962 in preparation of the upcoming catalog updates. The estimated sales volume split between the two spark plugs is 50/50 based on these application changes and vehicles in your markets.
Effective Date Immediately.
General Information:
Reference bulletin attachment for year, make and model applications for each of these AC Delco spark plugs. Please refer to Electronic Catalog Provider for complete application information.
These plugs fall into the family pricing matrix for Double Platinum and Iridium plugs. The 41-962 will be less expensive for older applications and will keep AC Delco competitive in the IAM.
For these plug applications, there will only be one plug per application.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346705 02/10/20 08:56 PM
SteveG4 Offline
The 41-962 plugs will serve you beautifully. They should last as long as you'll want to drive that motor home.
This thread reminds me I need to replace my plugs and wires soon as well... with the same 41-962 plugs.
I'll defer to others on the manifold gasket...
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346708 02/10/20 09:03 PM
M
M
Sorry, 41-110, not 41-111
https://www.rockauto.com/en/parts/acdelco,41110,spark+plug,7212
2009 Smart Pure
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346717 02/10/20 09:25 PM
Snagglefoot Offline
Your double platinums will be fine. Iridiums are guaranteed for 100,000 miles, but that’s a lot of driving with an RV. If you have trouble with the passenger side, you can always take the wheel off, block the frame, and you’ll be greeted with this view.
If you want the job done right......do it yourself.
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346732 02/10/20 09:56 PM
Snagglefoot Offline
To further complicate matters AC Delco Professional plugs have two different sets of numbers on them. The 41-111 is 2621258. Also, the OP is correct about the 41-985 plug being the original. You can just make out that number on the original plug I removed from a 2008 6.0.
89995114-8069-43BB-B50D-608A508DA165.jpeg5F8BBF85-3059-45DF-A01D-152BA17C59F1.jpeg47E4F39F-B2D4-4778-8FC6-89C02847503B.jpeg
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346734 02/10/20 09:58 PM
G
GMguy84 Online Content
Online Content
G
Yup, Did my research and read that TSB that Mike posted.So in went 962's and walker wires on my 01 6.0 HD last summer right after I purchased the truck at dealer
No issues at all
Dave
01 Silverado 1500HD 5W30 RTG/XG3675
07 Suburban 1500 LTZ CQSHM 10W40/ M1-201A
09 Crown Vic Police SAP PKG 5W20 RGT/POBOSS
82 Trans Am (KITT) M1HM10W40/M1-102A
Re: Chevy 6.0L Spark plugs [Re: Eric Smith] #5346820 02/11/20 02:39 AM
G
GMBoy Offline
G
If you are doing the intake gaskets do yourself a favor and replace the knock sensors and the harness under there. Another common issue...
I run Autolite Iridium XPs in my Denali 6.0L - likely the last plugs I will ever need.
