Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
47 registered members (ArgleBargle, Amkeer, bbhero, BlakeB, AZjeff, bmod305, 5 invisible), 1,165 guests, and 25 spiders.
Topics301,934
Posts5,205,768
Members70,801
Shell Rotella T5 CK4 15W-40 and 10W-30 #5346513 02/10/20 05:54 PM
H
HDoilDude Offline OP
H
Here's a two'fer of T5 Rotella.
The 15W-40 I was testing for my truck and the 10W-30 for my motorcycle, trying to follow Honda's recommendation of no moly in the oil (yes I realize it's not JASO MA rated).
The 10W-30 indeed had no (significant) moly so I'll probably try it out after my Actevo runs its course.
The 15W-40 looks pretty solid all around, despite a slightly lower magnesium reading on my sample.
[Linked Image]
[Linked Image]
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5346528 02/10/20 06:05 PM
K
krismoriah72 Offline
K
Its been awhile since ive seen it but the T6 15w40 didnt look overly impressive next to the T4 15w40 voas.
I never understand the need for T5.. T4 is great, T6 is synthetic (but looks just as great).
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5346549 02/10/20 06:26 PM
T
tundraotto Offline
T
I remember the T5 15-40 looking better than the T4 15W-40 AND especially the T6 15W-40....
I definitely remember deciding not to bother with the T6 15W-40 at all.....their own T6 5W-40 looked better!
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: krismoriah72] #5346566 02/10/20 06:43 PM
J
jeff78 Offline
J
T6 tends to shear quickly in shared sump engines. The T5 not so much, and the advantage over T4 is that it's got some synthetic in it, if that makes you feel good.
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5346576 02/10/20 06:49 PM
Snagglefoot Online Content
Online Content
Thanks for the VOAs. They cost money. smile
If you want the job done right......do it yourself.
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5346680 02/10/20 08:33 PM
Cressida Offline
It looks to me like Shell may have modified the additive package for the T5 10w-30 from two or three years ago. That boron is showing much higher and the magnesium is much lower from my UOA.
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5348229 02/12/20 03:09 PM
A
Audios Offline
A
Thanks for the post. I run the 10/30 in my tdi, the add pack looks great, and its cheap on sale, $11 at Amazon last time. Ill be posting a UOA in about 2500 miles, we can see how they compare.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: Cressida] #5348289 02/12/20 03:59 PM
T
tundraotto Offline
T
Its because the CK-4 specification took effect, vs the old CJ-4
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5352268 02/16/20 10:46 PM
H
huntsonora Offline
H
My old 12 valve takes 3 gallons of oil. I live in northern Colorado and am thinking about 2 gallons of the T5 15w40 and 1 gallon of the T5 10w30 just to help with colder starts or just go 50/50
Thoughts?
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: huntsonora] #5352944 02/17/20 05:03 PM
J
JustinSL Offline
J
Why not just go with T6 5w-40 for cold weather?
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: JustinSL] #5353589 02/18/20 11:33 AM
H
huntsonora Offline
H
I’ve tried it and it seemed like I got more spots on the driveway with it coming from the tube underneath
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5357491 02/22/20 05:07 PM
SR5 Online Content
Online Content
Thank you for these two VOAs, it’s good to see the two viscosity grades side by side.
Both are healthy in zinc ~1200 ppm for the 15W40 and ~1100 ppm for the 10W30, so I could see both working for motorcycle or flat tappet engines. Both should have good shear resistance too.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Shell Rotella T5 CK4 15W-40 and 10W-30 [Re: HDoilDude] #5358677 02/24/20 07:35 AM
B
Bighorn2500 Offline
B
When looking at the Rotella 10w30’s, T4 conventional and T5 synthetic blend their really isn’t that much difference when reviewing the product properties detail. The only really difference is the dynamic viscosity based on the numbers. Everything else seems pretty evenly matched, must not be much synthetic base in the T5.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
