drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
101 registered members (1978elcamino, 2015_PSD, 53' Stude, 750IX, andreigbs, 77GrandPrix, 10 invisible), 2,400 guests, and 17 spiders.
Topics301,750
Posts5,202,047
Members70,766
Cheap wheel hub assembly? #5346421 02/10/20 04:33 PM
M
Micahmcmeen Offline OP
M
I need to replace my wheel hub in my 2010 jeep commander 3.7. I was looking around at parts. The penny pincher in me tells me to swing it with something cheap. However I don't want to have to replace it in a year from doing so. Does anyone know any decent aftermarket brands they have used for wheel hubs? I have used Detroit axle before and was satisfied but their wheel hubs had poor reviews.
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346435 02/10/20 04:43 PM
B
Black_Thunder Offline
B
try Precision bearing
they are kinda priced inbetween the oem and cheap wheel hub assembly and I have had good luck with them.
I'd buy Callahan autoparts if I could.
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346440 02/10/20 04:51 PM
Chris142 Offline
Skf
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346472 02/10/20 05:27 PM
M
mattwithcats Offline
M
https://www.rockauto.com/en/catalog/jeep,2010,commander,3.7l+v6,1445122,brake+&+wheel+hub
Timken
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346501 02/10/20 05:45 PM
slacktide_bitog Offline
SKF or Timken
Re: Cheap wheel hub assembly? [Re: slacktide_bitog] #5346519 02/10/20 05:58 PM
M
M
What about moog?
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346522 02/10/20 06:00 PM
9
92saturnsl2 Offline
9
Detroit Axle sells utter garbage Chinese parts, avoid them at all costs. Go look through reviews for suspension components (on Amazon or Ebay) and you'll be disturbed how many review photos are of accidents their parts have caused.
I've had good luck with GMB brand hubs, they are a middle of the road to budget offering, but both times I used them they lasted a few years until I sold the vehicle.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346537 02/10/20 06:15 PM
I
Imp4 Online Content
Online Content
I
This is an instance where paying more for a quality product once will pay off for years to come.
SKF or Timken for wheel bearings.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346544 02/10/20 06:22 PM
Dave9 Online Content
Online Content
Another vote for SKF or Timken, though some have said their Timkens weren't up to snuff. You should see Timken engraved on the bearing if it's their top quality part.
Make sure you get the axle nut torque right using a torque wrench and replace the nut if it looks questionable.
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346550 02/10/20 06:26 PM
domer10 Offline
Never ever cheap out on wheel bearings, hubs, suspension parts....tire rods etc...you will just be doing it again in a years time if your lucky....ask me how I know.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346556 02/10/20 06:32 PM
1
14Accent Offline
1
Originally Posted by Micahmcmeen
What about moog?
Moog bearings are Chinese. Stick with SKF or Timken.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346557 02/10/20 06:32 PM
T
Trav Offline
T
Don't waste your money on cheap hubs or bearings, in the end it inevitably turns out to be anything but cheap. SKF is a good solid choice, Timken has gotten a bit sketchy with some of their reboxed numbers.
Detroit Axle and Moog are certifiable rubbish.
Re: Cheap wheel hub assembly? [Re: mattwithcats] #5346567 02/10/20 06:43 PM
M
M
Thanks for the link. Timken it is.
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346587 02/10/20 07:01 PM
J
Jarlaxle Offline
J
Haven't seen it mentioned, but I would be fine with Denso.
1979 Coupe de Ville, 542 stroker, parked for winter frown
2011 Crown Vic P71, 5W-20 NextGen, Super Tech
2011 Sportster 883, parked for winter frown I hate winter.
Re: Cheap wheel hub assembly? [Re: Micahmcmeen] #5346858 02/11/20 05:52 AM
W
WobblyElvis Offline
W
I bought a cheap wheel bearing from, https://ca.autoshack.com/search , a few years ago and it stayed on the car until I recently scrapped it. Worked for me but the choice is yours.
